BeckyD@RodgersChevrolet
Old 01-04-2010, 07:18 PM   #1
Genious
Army EOD Tech
Genious's Avatar
Drives: 2010 Camaro SS
Can this be done
I have searched the forum to find out if i can add the interior ambient lighting to my 1SS, everything i found is about changing existing lighting...i want to know if it can be put in if it was never there to begin with
Genious is offline   Reply With Quote
Old 01-04-2010, 07:25 PM   #2
shroomjohn
shroomjohn's Avatar
Drives: Golden Eagle
I think so http://www.camaro5.com/forums/showth...&highlight=DIY
Loving this car!
shroomjohn is offline   Reply With Quote
Old 01-04-2010, 07:35 PM   #3
Genious
Army EOD Tech
Genious's Avatar
Thanks but again thats changing existing lighting
Old 01-04-2010, 07:37 PM   #4
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
Uhhhh no it's not... It's adding ambient lighting all the way across the dash where none existed before...
Old 01-04-2010, 07:48 PM   #5
Alain
Alain's Avatar
Drives: 2010 SS, RS, Manual. 2012 F150, FX4
Originally Posted by shroomjohn View Post
that seems so difficult to do man. wish i had the balls to try it on my 1ss
Alain is offline   Reply With Quote
Old 01-04-2010, 07:54 PM   #6
Genious
Army EOD Tech
Genious's Avatar
you se this panel he is pulling off...my car doesnt have that panel lights behind it or not. where that plastic panel is in that car there is a solid mesh material in mine
based on that panel he's pulling and the 4 gauge cluster this is a 2ss so i dont know why there was not already a light behind that panel.
Old 01-04-2010, 08:00 PM   #7
Genious
Army EOD Tech
Genious's Avatar
My interior looks like this
notice the plastic panel is not even there, nor the gauge cluster
Old 01-04-2010, 08:04 PM   #8
Alain
Alain's Avatar
dude i've been wondering the same thing since the day i bought my car. i think that those of us that have a 1ss are screwed when it comes to this ambient lighting.
such a shame cause i think it's a sweet option.
Old 01-04-2010, 08:33 PM   #9
Jeanius
Jeanius's Avatar
Drives: Blk/Blk LS3 SS
Wow I never knew that, that really sucks for you guys. Someone will probably come up with something down the line
Jeanius is offline   Reply With Quote
Old 01-04-2010, 09:16 PM   #10
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
WILL someone please pull their gauges off of their LS, 1LT, or 1SS already to see if the plug is there?
skuttduck is offline   Reply With Quote
Old 01-04-2010, 09:40 PM   #11
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
The plastic panel is replaced with a cloth panel. It's there, and I'd be willing to be it can be removed in the exact same way
TommyTSquared is offline   Reply With Quote
Old 01-04-2010, 11:42 PM   #12
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
No camaro has the ambient lighting across the dash from factory. Yes the car is a 2SS, but it only has the lighting on the door trim.
Your trim is covered by a streched and glued mesh/cloth material, and I'm almost sure can be removed in the same manner as described in the link givin above.
Old 01-05-2010, 12:02 AM   #13
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
if ou really want ABL, you need to buy the 2LT/2SS trim panels, total is around 500. You need those panels because they are not completely painted. There is an ouside border that is left clear to let the light seap through.
Originally, the 2LT/2SS were supposed to have "complete" ABL, but then due to problems, they did it on the doors only.
Its a simple mod but the LS/1LT/1SS peeps gota pay to play.
Others have taken the cloth off their existing panels and had them painted, but i doubt you could do ABL that way because the panels would have probably been painted from the outside and it would just be a hassle. The panels we have are painted from behind.
The best method for you guys would be to get the replacement panels, go on to Camaroricks DIY thread and do the EL wire method, would be the easiest method
