Elite Engineering
Old 01-05-2010, 11:31 AM   #1
Metalman412
Drives: 2010 CGM 2SS/RS
Ground Effects Question...
So I got the Ground Effects option and the dealership put them on Thursday. I have been noticing, however, that there are gaps close to the wheel wells on the front spoiler. The rest of it looks kinda strange, like parts of the ground effects are overlaping the original front piece and parts are under it. I know I need to take pictures, and I ment to this morning but forgot. I will try to get some posted tonight, but wanted to see if anyone could help. Thanks!
3300: 11/25/2009 TPW 12/07/2009
3800: 12/11/2009 VIN# 176633
Available to ship from Osh: 12/11/2009
Rail Car Unloaded in GA: 12/22/2009
Dispatched and Delievered to Dealership: 12/30/2009
Picked up and have PERMAGRIN: 01/02/2010
Metalman412 is offline   Reply With Quote
Old 01-05-2010, 11:40 AM   #2
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
The front goes onto the stock bumper, so there's overlap, I think.
Old 01-05-2010, 11:45 AM   #3
Metalman412
Yeah, its real hard to explain. Just looks strange. If it is messed up though, its the same on both sides. I will have to get some pictures up...
Old 01-05-2010, 12:00 PM   #4
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Not messed up, thats just the way they fit.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 01-05-2010, 03:26 PM   #5
scythezo6
scythezo6's Avatar
Yea I see what you mean on mine too. Unless you install yourself and use lots of double-side tape and extra mounting holes or hover over the installers at the body shop it probably wont be completely-pletely flush with the stock bumper.
Old 01-05-2010, 06:03 PM   #6
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
I have installed 4 myself and none have ever fit tight in all spots. But pics would be helpful to tell if it's just a bad install.
thiggin2 is offline   Reply With Quote
Old 01-05-2010, 06:10 PM   #7
Sevn86
Sevn86's Avatar
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 01-06-2010, 10:36 AM   #8
Metalman412
Originally Posted by Sevn86 View Post
Finally got a few of the front, I guess its called an Air Dam... As I said, just kinda looks off. Thanks for the help!
Old 01-06-2010, 11:37 AM   #9
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
mine does the same thing in the front... theres nothing you can do about that.
But the sides are way too loose. It will only get worse with time. I have had mine installed twice.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 01-06-2010, 11:56 AM   #10
chef5330
Drives: 2010 Aqua Blue Metallic
GFX falls off
Your pictures do not look right. My front GFX came loose on the Turnpike doing 80 mph and draged for miles before someone went buy me and slowed down to tell me that I had a problem up front. All the rivets and metal pins were torn out from the wind resistance. I also noticed some small air gaps between the bumper and the GFX. When all was said and done, the dealer had put the GFX on wrong and did not follow the 6 page directions properly. Thats right 6 papes just for the front GFX. They apparently tried some short cuts and the car has only 1500 miles on it. So after the dealer reserched where the problem came from they replaced it under warranty. It looks much better and tighter fit this time. I think that you should take it to the dealer and have them replace it. There is no fixing the problem once installed, it has to be replaced due to the way the GFX has to installed to the front end. Good Luck
chef5330 is offline   Reply With Quote
Old 01-06-2010, 11:59 AM   #11
The money these GFX cost's, the dealer should make sure their installed correctly even if it calls for more tape or mounting holes.
Old 01-06-2010, 12:08 PM   #12
Metalman412
You would think... But my Dealer out-sourced it. The worst part is the Dealership is 70 miles away. Guess I need to call my salesman and see what he can do.
Old 01-06-2010, 05:21 PM   #13
michael's maro
RAM'S CAMARO
michael's maro's Avatar
Drives: 2010 camaro ss
Mine did the same thing, on the sides by the wheel wells. I removed the sides and added more 3m tape, then clamped it using a small c-clamp. Let it set up overnight, and everytime you don't drive it..Did this for about a week
michael's maro is offline   Reply With Quote
Old 01-06-2010, 05:35 PM   #14
thiggin2
thiggin2's Avatar
Yea, the front tip is never flush and is going to have a small gap. In the picture it doesn't look like they might have installed the rivets. Normally you can tell were the rivets are because it pulls that part of the GFX tight against the fascia and gives the gap a kinda wavy appearance, but it could just be the pic. The sides should have some tape there. It look likes you might have had the older style installed that didn't have any tape on the sides. There's a bulletin about adding tape to the edges of the older design.
Ground Effects question jonm38 Cosmetics and Lighting Modification Discussions 1 10-12-2009 10:13 PM
Ground Effects Kit question raad Cosmetics and Lighting Modification Discussions 5 09-21-2009 02:19 AM
Want my ground effects? Lettin' em go gzartman USA - Northwest / Pacific Northwest 1 06-17-2009 10:27 PM
Front ground effects issue demomaster 5th Gen Camaro SS LS LT General Discussions 3 06-10-2009 10:50 PM
