SDTW Custom Wheels & Tires
Old 01-06-2010, 01:34 PM   #1
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Lowering springs and rear gears V6 information
After much research i found the V8 Camaro was lowered roughly 3/4 inch lower then the V6. This meant when using EIbach springs If I used the V8 Eibach springs it would be close to the 1.5 inch drop springs Eibach decided not sale. Eibach was correct in stating a 1.5 drop was to much on a V8 but on the V6, since the struts have same travel distance a 1.5 drop can be achieved with new struts.
On ride smoothness the V8 springs will be a slightly stiffer ride but not by much since the springs are made to compensate for an additional 400 pounds, roughly 2 adults. Now one question I did not answer was on placement and yes the Placement of springs is identical. The result I had them installed on my RS about two weeks ago. Simple install, new alignment and they are great. They made a vast improvement on corning compared to stock springs.
Next up Rear gears. I was told the V6 and V8 gears are different. Well this is trus if you have a automatic V6 but if your V6 is a manual then the gears and axle shafts are identical to a V8. While the case is different further digging will show the important parts, inside guts, are the same. My Gm parts dealer and I spent a few hours comparing numbers and specs. When you match up a a SS camaro with a automatic 3.27 gears to the V6 manual 3.27 gears the ring and pinion are the same number so are the axle shafts. After that it gets easier since almost all numbers match between the V8 automatic and V8 manual rear end.
So now I can get gears but what about programming? I talked to SLP today and they are trying to get gear ratio changes into their V6 programmer, once that is done, ring and pinion swaps will be possible.
macwest is offline   Reply With Quote
Old 01-06-2010, 02:08 PM   #2
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
Great info
mdinferno is offline   Reply With Quote
Old 01-06-2010, 03:47 PM   #3
mydreamcar
My Dream Car
mydreamcar's Avatar
Drives: 2011 SIM LS3 1SS
thanks for getting all that info
mydreamcar is offline   Reply With Quote
Old 01-06-2010, 04:57 PM   #4
macwest
I added a picture of the camaro as an attachment. It was tough finding any of this information. On the pinion gear I was lucky my parts guy is real patient and willing to look into the questions i asked. It took some digging to find the numbers. On the springs Eibach just seemed like they did not want to give out begging and after height measurements from the wheels.
Heres the numbers:
The stock height of a v6 is 440mm while a V8 is 420. using V6 Eibach Lowering springs springs for a V6 spring drop is 406mm in front and 408 in the rear. using Eibach V8 lowering springs the spring drop is in front is 393mm while the rear is rear 398. Since the RS has same travel on struts and shocks as the V8 and placement was the same. I knew they would fit. Question was on ride. Eibach spring rates were V8 159-222 for front springs and 252-485 for the rear. The V6 spring rates were 159-191, front and 285-396 in the rear. In the end they are great now I just need the bigger sway bars to complete the package
Old 01-06-2010, 08:58 PM   #5
mdinferno
mdinferno's Avatar
can you post a side view
Old 01-06-2010, 08:59 PM   #6
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
more pics
Old 01-07-2010, 05:52 PM   #7
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Cool stuff...
As for programming... May want to check with Vince at Trifecta and see if he has access to the gear ratio... unless you are set on SLP/Diablo...
Also, has anyone checked in the the install price for gears in an IRS?
Now... can we swap a manual rear into an auto car? LOL
scrming is offline   Reply With Quote
Old 01-07-2010, 06:48 PM   #8
gwbates3
Ruby & Blu Imp
gwbates3's Avatar
Drives: 2010 LS3 2SSRS M6 & LLT RS A6
I test drove a 1LT @ City Chevy in Charlotte a few months back that had aftermarket (dealer) rims and tires and it had a noticeably bigger rear rim/tire setup. It made the stance and driver sitting angle more aggressive. I loved the feel and look!
Ruby
2SSRS M6 - Blown & LLT RS A6
gwbates3 is offline   Reply With Quote
Old 04-30-2010, 05:35 PM   #9
NXC1978
NXC1978's Avatar
Drives: 1LT/RS
So, did you ever swap gears? If so, what size?? Also, were you able to use V8 gears in your V6 M6 like you thought??
NXC1978 is offline   Reply With Quote
Old 04-30-2010, 09:32 PM   #10
chvyman
chvyman's Avatar
Drives: 2SS 45TH,gfx,blade spoiler,h grille
I got the part no's off a 3.27 limited slip diff. for sale on e-bay, 92246989 and plugged the no. into gm parts direct. bingo $919.xx that should be an entire center section with posi and gears set up from GM. now if I can get the #'s for the 3.45 lsd. should be about the same price. get lsd and a gear changefor the price of gears and install... if the axles fit as mentioned above.
chvyman is offline   Reply With Quote
Old 04-30-2010, 09:35 PM   #11
chvyman
chvyman's Avatar
my bad, v6a are different?
Old 04-30-2010, 11:44 PM   #12
NXC1978
NXC1978's Avatar
Drives: 1LT/RS
As I understood it, the v6 cars with manual trans have compatable dif parts with the v8 cars and the v6 cars with auto do not....
Old 04-30-2010, 11:58 PM   #13
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
V6 manual has limited slip like all the V8 cars, V6 auto just has a standard rear diff, (single slinger)
Now I wonder why the housing is different from V6 manual than V8 if the gears are the same?
two_wheel_mayhem is offline   Reply With Quote
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
Eibach ProKit Lowering Springs in Stock | FREE S&H! AJ@ECSMotorsports Suspension / Chassis / Brakes 139 11-17-2010 03:23 PM
H&R Sport Lowering Springs IN STOCK NOW!! AJ@ECSMotorsports Suspension / Chassis / Brakes 25 10-13-2010 11:35 AM
SLP Lowering Springs, Swaybars and Brake Packages tbyrne Suspension / Chassis / Brakes 0 12-21-2009 03:01 PM
