Cold Air Inductions
Old 01-06-2010, 03:49 PM   #1
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
Lowering Alignment Issue
Lowered my SS this past Saturday using the Pfadt springs with 1.25" drop. I had the car aligned yesterday and asked the shop to set front camber at -0.8 and rear at -0.6. The front was no issue but the rear adjustment maxed out at -0.9. Has anybody else had an issue getting the rear camber adjusted?
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected
obe1 is offline   Reply With Quote
Old 01-06-2010, 06:59 PM   #2
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
That is a problem on the camaro, the lower it goes the more adjustment it needs.Pedders makes a cam kit that helps get more adjustment.If needed pm me we have them in stock.
Bruce@raymondsperformance is offline   Reply With Quote
Old 01-07-2010, 12:43 AM   #3
obe1
obe1's Avatar
Thanks Raymo1. I'm going to watch my tire wear and if becomes an issue I'll pick up the adjustment bolts.
Old 01-07-2010, 01:04 PM   #4
toehead93
Drives: 2014 2SS/1LE
I thought the camber kit was only needed if you drop over 1.25. I didn't think it was an issue with a 1.25 drop.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 01-08-2010, 07:29 PM   #5
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
It is an issue with any drop. I have seen
Camaros only able to get -1.3 degrees as the lowest negative cambers.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 01-08-2010, 07:34 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
If lowered....does is need to be adjusted to -0.8 and -.06? Is there any issue with it being set at the max of -0.9?
Build Journal
Old 01-08-2010, 07:46 PM   #7
Info@PeddersUSA.com
With only drop coils or coil overs, we have found by testing, the best handling can be obtained by putting the front cambers to -1.0 and he rears to -.5. This seriously helps the understeer concerns.
Plus adding more front caster is a big help as well.
mike
dms
Old 01-09-2010, 01:44 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
mike
dms
What does that do to tire wear?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-09-2010, 09:46 AM   #9
Cruz-lo
Drives: 2010 2ss RS
I had the same issue. In fact even with the pedders alignment kit I could only get - 1 degree or so.
I ground out the toe and camber slots to get that last little bit. Then I sectioned my BMR lowers to pull the camber in more.
Now its OK! I can get to about - .3 if I need to.
Cruz-lo is offline   Reply With Quote
Old 01-09-2010, 02:37 PM   #10
Info@PeddersUSA.com
We have NEVER had an issue getting cambers more positive than -.5 with our Pedders eccentrics. I have been involved with quite a few installs. I was unaware of length variations with the BMR units.
How low did you drop your rear and what else have you done to the suspension upgrades? If you lok at the WD40 Camaro, we dropped the back end over 2 inches, and could have set the rear cambers to 0.
One last note is that the trailing arm really does not have much influence on camber. Toe definetly, but not camber
mike
dms
Old 01-09-2010, 06:44 PM   #11
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
DMS so you reccomend the alingment kit with your spring and coilover kits??????
Gotthat02fire is offline   Reply With Quote
Old 01-09-2010, 06:48 PM   #12
Info@PeddersUSA.com
Yes I do. With the exception of our coil spring drop kits, all other lowering kits include the adjusters
mike
dms
Old 01-09-2010, 06:52 PM   #13
Gotthat02fire
Thanks for the info Mike nice to have vendors that take care of us!!!!!!!!!!!!!!!
Old 01-09-2010, 08:09 PM   #14
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
dms,
I am about to install 1" drop springs. What are the alignment specs for the whole car I need to give to my alignment guy. I only street drive my car if that makes a difference. Thanks in advance.
bpoirier is offline   Reply With Quote
Eibach ProKit Lowering Springs in Stock | FREE S&H! AJ@ECSMotorsports Suspension / Chassis / Brakes 139 11-17-2010 03:23 PM
Help!!! - Paint issue not being resolved by a local dealer c0rsa180 5th Gen Camaro SS LS LT General Discussions 29 04-23-2010 01:20 AM
Suspension guys..Issue after Eibach install Luvpilot Suspension / Brakes / Chassis 18 12-18-2009 08:53 PM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
Please Think before you post 35th02ss Off-topic Discussions 35 08-02-2009 10:38 AM
