Emblempros
Old 02-18-2010, 02:58 AM   #15
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
Originally Posted by dms View Post
We have NEVER had an issue getting cambers more positive than -.5 with our Pedders eccentrics. I have been involved with quite a few installs. I was unaware of length variations with the BMR units.
How low did you drop your rear and what else have you done to the suspension upgrades? If you lok at the WD40 Camaro, we dropped the back end over 2 inches, and could have set the rear cambers to 0.
One last note is that the trailing arm really does not have much influence on camber. Toe definetly, but not camber
mike
dms
Maybe I'm missing something in this thread, but where did "I was unaware of length variations with the BMR units" get mentioned by anyone???????????
LPE Brotherhood
Old 02-18-2010, 09:08 AM   #16
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
That makes two of us.
IPS Brandon is offline   Reply With Quote
Old 02-18-2010, 12:53 PM   #17
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
BMR guy is offline   Reply With Quote
Old 02-18-2010, 01:14 PM   #18
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
I take it this drop affects both models(V6/V8), or only V8(lower than the V6 already)?
Old 02-18-2010, 09:16 PM   #19
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
I installed eibach lowering springs on my SS. My specs are all in the green now and with the settings they said I should see little to no wear more than before but anyways....
Left Front Camber: -0.7
Right Front Camber: -0.9
Left Front Caster: 6.0
Right Front Caster: 6.1
Left Front Toe:0.02
Right Front Toe: 0.06
Front Total Toe: 0.08
Steer Ahead: -0.02
Left Rear Camber: -0.9
Right Rear Camber: -1.0
Left Rear Toe: 0.05
Right Rear Toe: 0.12
Total Toe: 0.18
Thrust Angle -0.03
It came with a warranty. They did mention they got it as close to stock allignment specs as possible which I dont know if that is standard practice but the Eibach did not come with any preferred settings so...... It drives better than stock so as long as my tires done eat up I guess ill be satisfied.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 02-18-2010, 09:50 PM   #20
Cruz-lo
Drives: 2010 2ss RS
There was no issue with the length of the BMR trailing arms! They were exacly the same length as the stock ones!
The trailing arms had to be shorter to pull the tire forward and in. I am running pretty low.
I already had the BMR arms and they were much better suited to a modification compared to the stock ones.
The trailing arm is almost 35 degrees in its angle.
So if it is shorter two things happen.......
The tire to moves forward to the center of the wheel well and also in to improve the ability to achieve a more positive camber.
They custom made me a new set for this purpose since I sectioned mine. The pic below is of the modified arm installed. The new purpose built arm will be installed soon. It is shown below with the new toe links
Cruz-lo is offline   Reply With Quote
Old 02-19-2010, 12:58 AM   #21
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
YOU DID NOT HEAR THAT FROM ME
Rereading this post, and this is the problem being on hundreds of posts every day, is I thought you were saying or indiczting there is a problem with lengths of their arms. I misread it,m and apologize for it.
MIKE
DMS
Info@PeddersUSA.com is offline   Reply With Quote
Old 02-20-2010, 01:37 AM   #22
Blue70SS
Blue70SS's Avatar
MIKE
DMS
Read your own post #10! Not putting words in your mouth - would Never do that.
I think you owe BMR an apology. Let's keep it professional.
Mike, Thanks for your edit
LPE Brotherhood
Last edited by Blue70SS; 02-23-2010 at 10:10 PM. Reason: Mike, thanks for your edit
Old 02-20-2010, 03:59 PM   #23
Cruz-lo
Drives: 2010 2ss RS
I bought the Pedders alignment bolt kit and the price was not to bad when I bought the Drag bushing kit. I wanted the other bushings for the subframe and diff any way.
If you are running low (2.5 inches or so) you need more adjustment than stock. This is what I found on my car. Both toe and camber are hard to get to the recommended specs. (-.5 camber zero toe for me.) Even with the Pedders alinment bolts I was maxed out on the toe and camber adjusters.
Now if you want to run - 1.0 to -1.3 degree camber then you may be OK.
IMO if you have the shorter BMR trailing arms and the adjustable toe links then you can keep the stock alignment bolts no problem.
I installed these today and I am aligning the car now.... Pics later.
Old 02-20-2010, 07:14 PM   #24
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
I am lowered just one inch all around with my Eibach springs and bars. I also have BMR rear trailing arms. Even with just one inch drop I needed an alignment and I was able to align with stock eccentrics no problem. My technition told me I was about to the limit using factory travel limits. So, if you do a larger than 1 inch spring drop you will need additional help to align. Also, as a side, my technition asked me to sit in the driver seat while he set the alignment specs with me in the car. Just a little something extra I have not heard of before my alignment. Car looks and drives much better as you might expect.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 02-23-2010, 02:43 PM   #25
toehead93
Drives: 2014 2SS/1LE
I plan on installing my Pedders coilovers next week with a 1.5" drop. I'm confused, I hear some say I'll be fine without the alignment kit...is this true?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 02-24-2010, 12:59 AM   #26
Info@PeddersUSA.com
You have not heard this from me. Our coil overs respond seriously well with the following align:
Front:
camber: -1.0 each
caster, add 1.0 to 1.25 with our front align kit
toe at .1 toe out each wheel
Rear
-.5 camber each wheel
.05 toe in each wheel.
You cannot get the addiitional caster without our front kit, nor can you get to -.5 rear camber without them
Now you can get the car to within factory specs. But that does not mean it is the opportune alignment
mike
dms
mike
dms
Old 02-24-2010, 02:56 AM   #27
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
So what is the best specs for to keep tire ware to a minimum (no uneven tire ware)? factory specs? Going to be dropping my car to around 1.25-1.50 inchs, so do i need the alignment kit?
gotpball44 is offline   Reply With Quote
Old 02-24-2010, 10:03 AM   #28
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
This is called "weighting". It is how all performance alignments should be done, IMHO. And is how I did them all when I was wrenching. I will have mine done this way if I ever get my damn CO's. Not gonna say names but you know who you are
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Eibach ProKit Lowering Springs in Stock | FREE S&H! AJ@ECSMotorsports Suspension / Chassis / Brakes 139 11-17-2010 03:23 PM
Help!!! - Paint issue not being resolved by a local dealer c0rsa180 5th Gen Camaro SS LS LT General Discussions 29 04-23-2010 01:20 AM
Suspension guys..Issue after Eibach install Luvpilot Suspension / Brakes / Chassis 18 12-18-2009 08:53 PM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
Please Think before you post 35th02ss Off-topic Discussions 35 08-02-2009 10:38 AM
