Caryle Racing
Old 01-07-2010, 12:19 PM   #1
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
DIY FACTORY GROUND EFFECTS INSTRUCTIONS
here's the factory GFX instruction's
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 07-12-2010, 11:55 PM   #2
10_SS
10_SS's Avatar
Drives: 2010 2SS/RS
OEM GM SS Front Cladding (GFX) requires front rivets
Thanks for posting the GM instructions for GFX mounting.
I now see when the dealer installed my 2010 "Camaro SS Front Cladding" they failed to install the four rivets shown on sheet 12 of 50.
I was driving my two-day old 2010 SS/RS today and the very tip of the front spoiler dropped from the car. It was only being held by the two wheel well bolts and the eight push-pins. I noticed the double-sided tape across the front had not adhered properly.
I thought the SS Front Cladding (GFX) was a little heavy to just be held in place with double-stick tape, so these instructions solved the mystery. Four pop rivets are missing.
Per the GM instructions, it seems only the SS front cladding requires rivets. The rivets are difficult to install, the entire front fascia needs to be removed in order to install the rivets.
I hope my experience helps someone else.
10_SS is offline   Reply With Quote
Old 08-17-2010, 08:14 PM   #3
Ph4r
Top Down Fun
Drives: 11 2SS/RS IOM Vert
Looks good, but word of warning for anyone who may be using this... The torques are listed in inLbs not FtLbs [pound force inches, not pound force feet]. These are very low values, if you try to apply it as Lbf Ft / FtLbs you will most likely damage material and/or snap fasteners. It is literally a factor of 12 different between the two. If available and capable it is always recommended to reference the Nm (Newton Meter) Values Given.
2011 Chevrolet Camaro Convertible 2SS RS M6 IOM Vert! IO Interior, Factory Hurst, Painted GFX, Black Rally Stripes, Front/Rear/Bowtie Blackouts, QTP Cutouts, Extra Cupholders!
LED Tails, LED DRL's (always on!), Ghosted "Concept" LED Side Markers, LED Tag Lights, Tinted LED Reverse Lights, Chrome Front Turn Signal Bulbs!
My Build Thread
Daily Driver: 2016 Ford Fusion Titanium with 2 car seats in the back!
Ph4r is offline   Reply With Quote
Old 08-17-2010, 08:59 PM   #4
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
I wish my dealer would have taken the time to read that... mine went to the dealer 4 times before they even tried to fix thier sorry installation. The front and rear peices were literally falling off. They finally took a crack at it, and it is better now.... but the fit still isn't what is expected to be a factory fit.
and for $2200, you should expect better...
if you can find an aftermarket kit that you like, get it instead.
end rant
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 08-17-2010, 09:03 PM   #5
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Nice to know!
Old 08-18-2010, 12:00 AM   #6
10_SS
10_SS's Avatar
Drives: 2010 2SS/RS
Due to my front spoiler coming off after 200 miles I have done quite a bit of investigating with the help of Camaro5. Take note that the original "SS Factory Front Spoiler" in the August 17 DIY has been replaced by a SS Service Spoiler and you can find the pdf in one of the posts located here: http://www.camaro5.com/forums/showthread.php?t=78097&page=2
The major distinction is, the original GM factory SS Front Spoiler uses four rivets to secure the front lip whereas this new GM Service Front Spoiler uses two plastic brackets secured by 13 rivets. You need to remove the front fascia to install the original factory SS front spoiler and you do not remove the front fascia to install the SS Service Factory Spoiler.
Old 08-18-2010, 01:19 PM   #7
JoeFire
JoeFire's Avatar
Drives: 2010 2SS/RS Transformers Edition
Thanks for the post. Now I just need to order the parts!
JoeFire is offline   Reply With Quote
Old 08-18-2010, 07:00 PM   #8
10_SS
10_SS's Avatar
Drives: 2010 2SS/RS
I uploaded photos to show the new revised SS Front Spoiler installation process on my 2SS/RS. Just follow the GM instructions included in the kit. Tape the plastic brackets to the front fascia, drill holes and secure using aluminum pop-rivets in the kit. Be very careful to align the tip of the passenger side bracket to the very tip of the fascia nose to insure the spoiler will align properly. Remove the tape and snap off the alignment tabs per the instructions. After this, the front spoiler snaps into the plastic brackets. IMO this is a very secure mounting system. Thanks GM!
Old 10-14-2010, 04:50 PM   #9
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
any modes to back pipes
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 10-14-2010, 07:23 PM   #10
10_SS
10_SS's Avatar
Drives: 2010 2SS/RS
No, just the GM rear GFX with the stock SS exhaust tips.
Old 10-27-2010, 08:37 AM   #11
x626xBlack
ARMY of one.
x626xBlack's Avatar
Drives: 2011 Black SS/RS
Why is the abbreviation for Graphics being used for Ground Effects?
Graphics = GFX
http://www.all-acronyms.com/GRF/Graphics/1117353
See the Also.
http://www.abbreviations.com/GFX
Some where someone decided it stood for Ground Effects and it is misused on many sites.
x626xBlack is offline   Reply With Quote
Old 11-01-2010, 12:19 PM   #12
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
As 10_SS mentions above, the service front lip is revised and more bullet proof. I just did the install this weekend. The install is a bit nervous if you do not perform this sort of work. The lip is also cumbersome to get over those brackets. Take some time and massage the back side of the lip engagement edge outwards so that its not wavy and tucked under. That will save a bunch of muscling and digging around with a screw driver cautiously
Here is a pic of the backside of the bumper cover showing all the rivets down low
I opted to install the lip with the cover on the car, then take the cover off to do the Heritage brille
f5journal is offline   Reply With Quote
Old 12-10-2010, 04:25 AM   #13
jeffgtx
Drives: sosltice
am i reading this correctly that the GFX is an irreversible install? it appears that if you take it off, you are going to have holes in at least the fascia, if not other places?
jeffgtx is offline   Reply With Quote
Old 12-10-2010, 11:04 AM   #14
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
Thats true. There will be holes left in it.
thiggin2 is offline   Reply With Quote
Ground Effects Question... Metalman412 Cosmetics and Lighting Modification Discussions 26 06-01-2012 10:42 PM
Factory painted ground effects? Rollie25 Cosmetics and Lighting Modification Discussions 20 06-22-2010 08:25 AM
Dealer's Ground Effects and Install Wvallediego Exterior Parts & Accessories 0 12-03-2009 06:27 AM
For those of you who have ground effects sledhead 28 5th Gen Camaro SS LS LT General Discussions 5 07-03-2009 02:25 PM
Request: Black with Ground Effects??? Rollie25 Camaro Photos | Spyshots | Video | Media Gallery 6 04-21-2009 06:30 PM
