BORLA
Old 01-07-2010, 05:16 PM   #1
braddirt1
Drives: trailblazer ss
Has Anyone Swithched Seats Yet
Curious to see if anyone has changed seats yet. I have cloth and I can get a set of leather ones and I know they will fit fine but not sure how to get the heated part to work. Has anyone tried this yet? Looking for a little help. Thanks Brad
braddirt1 is offline   Reply With Quote
Old 01-07-2010, 07:02 PM   #2
henri26900
henri26900's Avatar
Drives: 2010
We switched the seat covers in the Camaro we did for Legend. I am not sure if his car had heated seats, but i don't think it would be a problem.
BTW: He has his old leather seat covers " Black" If you didn't have yours yet, he may consider selling them.
One thing i think you have to make sure you disconnect the battery before taking the seats out, or you'll have a airbag code and your car will not start. This is just what i heard.
henri26900 is offline   Reply With Quote
Old 01-08-2010, 10:50 AM   #3
CleanCutCreations
CleanCutCreations's Avatar
Drives: 2010 camaro
This is true...The cars computer knows that you have disconnected anything and will throw a code. Best way to get a leather upgrade is to upgrade using Katskins replacement seat material. PM me and I can get you pricing on a kit along with color and option availability. We are also a licensed installer for Katskins if anyone would want us to do a leather upgrade.
CleanCutCreations is offline   Reply With Quote
Old 01-08-2010, 11:48 AM   #4
braddirt1
What I really want to know is if the whole seat can be changed not just the cover. I can get a set of seats out of a wrecked SS and wondering about the problems I might have changing them. Thanks Brad
Old 01-08-2010, 12:04 PM   #5
CleanCutCreations
Drives: 2010 camaro
From 2010 Camaro to 2010 Camaro is ok, it's just replacing the OE ones with aftermarket or with the seats from another car other than a camaro that will cause problems. The seats have passenger sensors and wiring that will throw a code if not plugged in on startup.
Old 01-08-2010, 03:16 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I think the bigger question he seem to have is, what about the heated seats. Seeing that the button is on the temp and fanspeed controls, how would one go about turning them on and off and is there a plug in already there for it to get power?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-08-2010, 04:07 PM   #7
CleanCutCreations
Drives: 2010 camaro
I don't believe there is a plug for power on the standard cars. We have used this company for installing heated seats into a car (non camaro) that did not originally have them. If you look at the parts page you can purchase a control module, wiring harness and switches without having to buy a whole heated seat kit, since you will have seats that have the heaters in them already. Go here for the parts page: http://www.heatedseatkits.com/heated...rts/index.html
Their buttons look OE and come in dedicated driver and passenger.
Old 01-09-2010, 06:21 PM   #8
55Designs
Drives: 2010
These guys replaced the seats and disconected the airbags. I WANT TO KNOW HOW it was done.
These are SEIBON Seats. I have a pair of sick Recaro seats I want to use but I dont know how to get around the airbag.
55Designs is offline   Reply With Quote
Old 01-09-2010, 07:19 PM   #9
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I drive my Camaro so staying with stock seating but looking to add my own flavor to them but it has to wait till after taxes and Camaro5Fest!!!
Gotthat02fire is offline   Reply With Quote
Old 01-10-2010, 12:27 AM   #10
CleanCutCreations
Drives: 2010 camaro
I know how it was done...We have done it on other cars with airbags. You have to disconnect the battery, disable the SRS, stare at an SRS fault light while you drive and have hard codes in the computer that have to be removed by the dealer. These cars are meant not to be modified in any way and throw codes when parts are changed or removed. It all depends what you want to live with to have a modified computer monitored car.
This is a 2004 Colorado that we disabled the SRS on to install an aftermarket steering wheel. All the problems listed above happened on this truck. Anti lock brake dash light was also on because we scrapped the chevy front suspension in favor of a Mustang II style setup that didn't have the rotor sensors for the computer.
Changing Out Seats. stovt001 5th Gen Camaro SS LS LT General Discussions 3 03-21-2009 05:57 PM
the seats breetison 5th Gen Camaro SS LS LT General Discussions 17 03-02-2009 06:33 PM
Seats futureZ 5th Gen Camaro SS LS LT General Discussions 7 05-12-2008 04:09 PM
Seats!!! Omega94 5th Gen Camaro SS LS LT General Discussions 8 02-29-2008 10:40 AM
