| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: "SINISTER" Join Date: Jul 2009
LG g6x3 or Super Charger Cam!!! Your Thoughts
The Mods will start this coming week!!! My Richmond 4:10 gears have been ordered. I have been racking my brain all weekend because I am torn between going with the LG g6x3 Cam or just doing a smaller cam that will support a Super Charger that I "MIGHT" one day decide to do later down the road. Both cams including install will cost about the same.
Obviously with the smaller Super Charger cam, I will not get as much Horsepower and Wumpity.-Wump sound as I would with the g6x3. On one hand, I like the coolness factor of an Old School N/A build with that Wumpity-Wump Cam, Heads, Intake etc... and just may decide to stay N/A and if so.... the SC Cam may be a mistake. On the other hand I may decide that I want more HP and the SC route would be an easy option to fill that need w/o killing driveability. Like I said The Super Charger is a "Maybe One-Day" Mod. I guess I could always swap Cams if I decide to Super Charge but that would be a costly mistake. ![]() Your opinions are greatly appreciated. |
![]() Drives: 2010 RS/SS2 Join Date: Jul 2009
The cam swap along with the supporting mods will make just as much power for alot less money. Put a bottle on it and the blower cars will cry a river.....
I like my 530 rwhp N/A car along with the 740 rwhp on a 150 pill. Pm replied
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block. First to run 11's cam only First to run 11's all motor First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous) First to run 10's (10.55) on motor in 2010 Camaro First to break into the 5's (5.97) 1/8th mile First to cut a 1.5X sixty foot First to cut a 1.4x sixty foot First to car to cut a 1.3x 60ft |
I've been lost...
Drives: 2010 SW 2SS/RS W/IOM LSA Swap Join Date: Nov 2009
I plan to use a a Comp Cam 238/244 @.050 .610/.610 112 with a procharger
I FARTED
Drives: 2010 2SS/RS Join Date: Nov 2009
Look into latemodel racecraft's Slayer cam.
I am going with the LG 6 x 3 and 4:1 gear in next month!
#6 | |
#7 |
Est. 1993
Drives: Ignition Orange G8 GT Join Date: Jul 2009
#8 |
#9 |
#10 |
Est. 1993
#11 |
Apprehensive Optimist
Drives: '10 SS/RS SIM Join Date: Sep 2008
I'm gonna sound like a Vengeance sales rep pretty soon...but obviously I'm pretty happy with what they did for me...and tennessee can be a short drive to Atlanta...
OCCASIONALLY I'll think that I will want to go the FI route...but it's ALWAYS when I'm reading the forums and NEVER when I'm behind the wheel. You asked for opinions...that's mine. And my car sounds just flat out mean.
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary: Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back Suspension: Pfadt Sport Sway Bars, Pfadt drop springs Other: MGW Shifter, Custom Paint my build journal ---->http://camaro5.com/forums/showthread.php?t=30057 |
#12 |
The dyno numbers I posted with the spray are also Nano assisted. Nitrous Daves and Nano together make KILLER power and one hell of a stock "bottom end" killer power.
My car's power is still supported by the stock fuel system......even on nitrous. Blower cars cant do that so add another 800 bux to the blower tab for the fuel system upgrade you'll need to make the kind of power Im making with stock stuff.
2010 SS/RS SIM
#13 |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
What is nano assisted?
#14 |
Est. 1993
#15 |
![]() ![]() ![]() ![]() Drives: Camaro Join Date: Apr 2009
You guys need to carefully check piston to valve clearance with some of the camshafts your discussing in this thread. Just because a shop sell it doesn't mean it automatically is going to work without any issues. .020" pistons to valve clearance isn't allowable by any stretch of the imagination... When we designed our LS3 camshafts we used our engine dyno to test numerous camshafts side by side. We also took time to check piston to valve clearance on each camshaft to insure what we found work well, also cleared properly....
If guys checked they're install properly you'd be how little clearance some of these camshafts have.... |
#16 | |
I have watched your video multiple times. Your car is an inspiration and it sounds totally Bad Ass!!!! Thanks a lot for the advice. ![]() I have heard some really good things about Vengeance but I have already been working with Cincy Speed. They are great guys to deal with. |
#17 |
#18 | |
#19 | |
Est. 1993
Rick is planning on coming back to us for a Nitrous Kit install along with 4:10s. His SS is going to be one bad mofo!!As for yours, just imagine your louder exhaust with the same thump...Do your neighbors like you?? Too bad Matt put his away for the winter. He has the same Headers and CB you are getting installed along with Nitrous. Once the roads are clear, hopefully soon, he will be back for some final tweaks and a few pulls on the roller with the spray! Its going to be sic.
#20 | |
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++ |
#21 |
LSX Tuner at Cincy Speed
Drives: 1988 GTA Trans Am Join Date: Nov 2009
Darrel we can custom spec a cam that will have that great cam sound sound, good wheel hp and still be S/C friendly if you want. Trust me no voodoo here just solid experience, know how, good parts and very particular tuning strategies.
Tracey Scott Lead GM Tech and Tuner -Cincy Speed 513-821-2221 |
#22 | |
There is just something about a 427 and Camaro that goes together like Peanut Butter and Jelly!!! The LS-7 427 option has also crossed my mind.
#23 | ||
You Guys at Cincy Speed Kick ASS!!!! BTW Craig, My neighbors Ride Harleys, Raise Hell, Shoot Guns and Drink Beer all night!!!! They are my Kinda Scum Buddy!!!! Last edited by Mr. Brownstone; 01-10-2010 at 02:55 PM. Reason: Text Edit |
#24 | |
I've been lost...
you think there will be an issue running a 238/244 @.050 .610/.610 112? |
#25 | |
2010 SS/RS SIM
| Thread Tools | |
| Super Charger for the Camaro??? | Triton2110 | Forced Induction - V8 | 5 | 05-06-2011 09:20 AM |
| ProChargers Super Charger COMING SOON!! | FoxMarketingCars | Forced Induction - V8 | 11 | 03-29-2009 09:14 PM |
| Vortex Super Charger Huh!?!?! | DarkDragon85 | 4th Generation Camaros | 4 | 03-10-2009 05:13 PM |
| 2008 Shelby GT Super Snake (600-725 HP) | .Hack | General Automotive + Other Cars Discussion | 15 | 03-21-2008 06:54 PM |
| Shelby Super Snake | KILLER74Z28 | General Automotive + Other Cars Discussion | 18 | 07-23-2007 07:12 PM |
