Hines Performance (HPE)
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 01-12-2010, 10:43 AM   #1
PiratePete
PiratePete's Avatar
Drives: 2010 Camaro SS,RS,CGM,M6
Skip Shift?
Hey Guys & Gals,
I just joined Camaro5.Com today and am posting for the first time.
I'm a long time Camaro owner (1994 & 2000 Z28's and currently a 2002 SS, M6). Yesterday I ordered a 2010 SS/RS, M6, CGM.
Does anyone know if the 2010, M6 has the "Skip Shift" that needs to be disabled like on the older models so you can shift to the gear you want when you want?
Thanks,
PiratePete is offline   Reply With Quote
Old 01-12-2010, 10:47 AM   #2
CynAgain
the Gunner's Wife
CynAgain's Avatar
Drives: InVerted
Welcome to C5
Yes the M6 has skip shift. There are a lot of threads about it. Here is one for your review Skip Shift Eliminator
Old 01-12-2010, 11:03 AM   #3
Russell James
Russell James's Avatar
Drives: '12 SS/RS LS3 IBM
Yup, exactly the same. I eliminated mine 30 minutes after taking delivery. It never even activated once.
The same 2.2K Ohm resistor trick still works or any of the aftermarket modules.
Old 01-12-2010, 11:09 AM   #4
Chevyg1rl
Chevyg1rl's Avatar
Drives: Chevys
You can get the part from your dealer. It's @ $30 and they installed mine for free.
'10|Yellow/Black|2SS/RS|M6|Transformer Edition NMFBD9 / NVMY2SS '01|White/Black|Z28|A4
Chevyg1rl is offline   Reply With Quote
Old 01-12-2010, 12:47 PM   #5
cterry
So Cal Race Team
cterry's Avatar
Drives: 2010 Carmaro SS/RS
I do not like the Skip Shift either and plan on eliminating it soon.
cterry is offline   Reply With Quote
Old 01-12-2010, 01:05 PM   #6
Edrock
Edrock's Avatar
Drives: '10 Camaro 2SS LS3
Originally Posted by PiratePete View Post
Hey Guys & Gals,
Thanks,
Another way to eliminate it is with a "tune" that modifies the car's computer settings. CAGS (Computer Aided Gear Shift) can be disabled in the tune. This method also pvents the 1-4 Shift message from showing up in the DIC (Driver Information Center) window. Manually disabling CAGS with the resister at the transmission will disable it but the 1-4 shift message still flashes up in the DIC...so I've been told. Downside of modifying the factory tune....you guessed it...risk of voiding 5 year/100,000 mile power train warranty. If you plan on getting a performance "tune" anyway at some point (like many do to gain more HP, TQ, and reduce Torque Management), you can eliminate CAGS at the same time quite easily.
DT Shorties, Solo hi-flow Cats, X-pipe, resonator delete, Flowmaster Super-44s, VMAX TB, Stronger MAF, C.A.I. Intake with race scoop, and JRE Tune!
WOT is my happy place!!
Edrock is offline   Reply With Quote
Old 01-12-2010, 03:17 PM   #7
PiratePete
PiratePete's Avatar
Excellent thanks for the fast input!
I did find the SLP part ( http://www.slponline.com/view_product.asp?P=21008 ) and
LM Performance part (SLP anyway), http://www.lmperformance.com/53552/119.html both for about $30.00
Thanks again,
Pete
Old 01-12-2010, 03:44 PM   #8
Alfieboy
Madman
Alfieboy's Avatar
Drives: Black 2010 2SS 6sp man w/IOM stripe
Skip Shift elim is a quick 5-10min job that wont void anything, and can alwas be unplugged(removed)....
Some people have issues with it,mine wasnt toooo bad, but I eliminate dit anyways.. Will still show the waring on DIC..but you'll be able to shift the way ya want to..low or high rpm
Alfieboy is offline   Reply With Quote
Old 01-12-2010, 03:44 PM   #9
boxmonkeyracing
juggernaut
boxmonkeyracing's Avatar
Drives: VRSCF, 2011 SS vert
Send a message via AIM to boxmonkeyracing Send a message via Yahoo to boxmonkeyracing
wrong section but welcome to the forum.
We do not want to use the Z28 moniker on a car that does not deserve this hallowed name.
boxmonkeyracing is offline   Reply With Quote
Old 01-12-2010, 11:10 PM   #10
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
No problems with mine so far. Has only come on 2 times in a 1000 miles and I was driving like a spode. Drive it with a little throttle and it won't come on. Mine has only come on when taking off at low RPM and it went right off when I gave it a little clutch and some more gas. If you don't drive it like a little old lady you won't even notice this "feature". Its a muscle car so drive it like one!
gotroost is offline   Reply With Quote
M6 Owners and Skip Shift Beware! DkknightX 5th Gen Camaro SS LS LT General Discussions 173 01-26-2010 04:14 PM
Skip shift function, or malfunction? AMERICANMADE 5th Gen Camaro SS LS LT General Discussions 53 09-18-2009 08:38 PM
SLP Skip Shift Eliminators Available @ MarylandSpeed! MarylandSpeed V8 Bolt-Ons & Tunes 0 09-18-2009 01:50 AM
Camaro Skip Shift Eliminator.... southerncarparts V8 Bolt-Ons & Tunes 0 08-31-2009 12:01 PM
Avoid skip shift in the break-in? Vash Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 7 05-27-2009 10:39 AM
