| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() Drives: 2010 2SS Camaro Join Date: Dec 2009
Cross drilled slotted rotors
Just received my new cross drilled slotted rotors from brakeperformance.com They coated mine black and it cost $400.00 for the front & rear shipped to NY. They look great. 818-772-5540 The rotors came all black i didn't put enough miles on the car to wear off the coating yet!
I'm not totally useless..
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies Join Date: Sep 2009
![]() Just sayin... ![]() PS Do you know if they were cryo treated? Are the holes chamfered? Zinc plated? Inquiring minds need to know... EDIT: I went to the site and see they are zinc coated. But nothing about cryo or chamfered holes...
i dont even see the 2010 model year on there list
top 10 reason why real men drive stick. 10. A manual transmission is the ultimate in control 9. You can use automotive jargon and not sound like a total tool 8. You can't spell "manual" without "man" 7. Manual transmissions prove you can do more than one thing at a time 6. You can't drift in an auto 5. You can't pull fancy moves in an automatic 4. You get better fuel economy with a stick 3. You’ll never look like a chump if you can drive stick 2. Manual transmission cars are faster 1. Women like a guy who is good with his hands. |
Nice.
#6 | |
Do your home work!!!! All the info you need is on there site or call them.....Just trying to help you guys out!!!!!!!!!!!! |
#7 |
![]() Drives: 2004 CTS, Arrived! 2ss/rs ABM! Join Date: Sep 2009
any pics of them on your Car? would love to see them
2010 Camaro 2SS / A6 / Aqua Blue Metallic / Gray Int. / Sunroof / NPGB4Q / 2G1FK1EJ6A9160475
1100 - 09-24-09 1st Step3800 - Born 10-27-09 6000 - 11-11-09 ![]() |
#8 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
no pics, didn't happen
#9 | |
Plus, you have them in your possession! What better source for homework can we get?
#10 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 1SS, RS, Manual Join Date: Dec 2009
dude, no pictures?
they look pretty nice on the web site. hope you take some shots of them mounted on your ride |
#11 |
#12 |
Took photos last night, but can't post them. If someone knows how to post photos i can email them to you.
#13 |
The easiest way is to upload them to a hosting site like Photobucket, Flickr or the like. Then you copy the direct link to it from the site and use the "Insert Link" button above and paste it in.
#14 |
Madman
Drives: Black 2010 2SS 6sp man w/IOM stripe Join Date: Jun 2009
PM sent Vinny
#15 | |
Thanks for the info. I will email the photos to Alfieboy and he will post them for me. This weekend I'll try to figure that out. Thanks Vinny |
#16 |
#17 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
I think you have the rotor on the wrong side of the car. Slotted rotors should be installed so that the end of the slot on the outer edge of the rotor enters the brake pad first. Your pic shows that the inner end of the slot is entering the brake pad first. The pic below shows Racing Brakes instructions:
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#18 |
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
What it the torque for the rotor bolts?
thanks, Also, thanks for the info above! The front set of my Stillen rotors doesn't have the left right on them!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; Subthump; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
#19 | |
I also just edited my above post with a pic. Also remember to wear in the pads to the rotor as follows: 1. make 6 - 10 stops from aprox 35 mph applying medium pressure 2. make an additional 2 -3 hard stops from aprox 45 mph 3. DO NOT DRAG BRAKES! 4. quickly get back up to speed between stops while doing this procedure so the brakes don't cool off too much 5. allow 15 minutes for brake system to cool down 6. after step 5 you are good to go!
#20 | |
#21 | |
Brembo Sport Slotted Rotors Brembo Sport slotted brake rotors are for drivers who want to improve the looks and performance of their vehicle’s original braking system without having to change additional brake components. Brembo Sport slotted brake rotors provide excellent stopping power in everyday traffic, as well as high performance street and track driving. Brembo Sport slotted brake rotors match the vehicle’s Original Equipment rotor’s dimensions and are fully compatible with its hubs, brake calipers and road wheels. Front and rear Brembo Sport slotted brake rotors are available to provide a matched appearance on all four corners of the vehicle, and employ one-piece vented or solid rotors depending on the vehicle’s Original Equipment specifications. Starting with select castings, Brembo Sport slotted brake rotors undergo the race-born practice of machining multiple shallow slots into the disc’s front and rear surfaces to provide paths to disperse built-up heat and gasses and assist in refreshing the surface of the brake pads. Compared to cross-drilled rotors, machined slots have been widely adopted for racing and street use because they minimize the cracking caused by repeated, high stress, high temperature brake applications. The slots are angled to use the rotors’ direction of rotation to enhance their performance, which makes the rotors side-specific with left and right side rotors. Brembo Sport slotted brake rotors are sold in axle pairs and the easiest way to verify correct usage is to install the rotors on the side of the vehicle that results in the end of the slot nearest the outer edge of the rotor always contacting the brake pads first. Brembo Sport slotted brake rotors are coated for corrosion resistance to help eliminate rust and offer a bold, aggressive appearance to enhance the look of the vehicle’s road wheels. NOTE: Light Truck and SUV rotors with studs or bearings are uncoated. Brembo Sport slotted brake rotors are designed to meet the challenges of high performance street driving while adding an authentic, race-ready look. NOTE: Brembo Sport slotted brake rotors can be used in conjunction with race compound brake pads on the track for drivers’ schools and lapping days. IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use. While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if any products are used on the track they are not warrantable.
#22 | |
Thanks, Michael J.
#23 |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
this pic of a slp zl575 shows the rotors opposite of what post #21 says??, but these are drilled and not slotted.
#24 |
This is a picture of my rotors straight from Stillen. "L" means driver's side, "R", passenger:
That matches MtcWby's descriptions... Oh, still need all (but the lug nut) torque values! ![]() Thanks...
#25 |
To the OP, thanks for getting the pics posted up.
I had these on my RX7 and never had a crack in them thanks to the chamfered holes!! I ran em hard at the track several times too. Good to see that they are making them already for our cars!! Do they have the black zinc coating as an option?
| Thread Tools | |
| DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 49 | 11-13-2010 03:57 PM |
| Front Ground Effects Lip Problem | Lucky SOB | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 131 | 03-08-2010 03:53 PM |
| 2010 Camaro SS Brembo Heavy Duty Cross Drilled Brake Rotors In Stock Ready To Ship | Tim@Lingenfelter | Suspension / Chassis / Brakes | 4 | 12-07-2009 08:26 PM |
| Slotted or cross drilled rotors | Fogey | Wheels and Tires Talk Sponsored by The Tire Rack | 15 | 06-03-2009 09:10 AM |
| Are the SS Brakes Drilled? | Scott@Bjorn3D | Wheels and Tires Talk Sponsored by The Tire Rack | 19 | 11-16-2008 04:47 PM |
