SDTW Custom Wheels & Tires
Old 01-13-2010, 11:29 PM   #1
ThunderSS
ThunderSS's Avatar
Drives: 2010 CGM 2SS/RS
DIY Raptor Dual Stage Shift Light.
I have seen several post/threads about people asking how to hook this particular shift light up.
After several emails back and forth with Raptor Performance I was able to get the correct wiring and correct pin on the PCM to install this correctly.
here goes.
material
1 Raptor shift light w/accessories
Wire loom about 20ft.
Butt-splice connectors 16-14 guage
16-14 gauge T_Tap connectors.
16-14 Spade connectors
1- 16-14 gauge d-ring connector for 5/16 bolt
One 5/32 machine screw and nut, about 3/8" long
zip ties
shrink wrap
16 or 14 gauge wire white and green
Tools you will need
heat gun
Drill
1/2 drill bit,
5/32 drill bit
Electrical tape.
10 mm socket with ratchet
1. First thing to do is decide where you would like to mount your shift light.
I chose the far upper corner of the driver windshield, as it is out of site, but yet still in my peripheral. I did have to drill 1 5/32 hole and obtain a machine screw, and nut to fit the corresponding hole.
So now that the decision to mount it here has been made, Place the light with the base attached, and hold the light in it's position. Once you like it. make a mark along the base of the stand.
Next remove the A-pillar cover, and align the base up with the line you made( with out the shift light in the base). Once you have it lined up, take a Sharpie and make a mark for the hole. Now drill out the hole. Bolt the base to the A-pillar cover.
Now take the light, and mount it back in the base. Remove the Fuse panel cover on the side of the dash, and re-install the A-pillar cover, while doing this fish the wire down behind the cover, and down into the Fuse Block area on the side of the dash. Snap the A-pillar cover back into place, making sure that you don't have any excess wire hanging out. Just enough to not put a lot of tension on the connector on the back of the light.
Now comes the fun part.
Disconnect the Negative side of the Battery
Strip the black protective coating back as far as you can ( I stripped mine till about 6inches before it went up into the A-pillar. I had already had tapped into the fuse block on the secondary side of the fuse( protected side) in a previous install. So I had an available switched hot circuit available to me. If you don't you will need to locate one. whether it be from the ignition source, or some other spot.( Cut the red wire to fit, save the excess you will need it later). I would stay away from anything that has to do with Onstar, or any safety aspect of the car.(airbags etc.)
Now for the Ground there is a bolt here. (Cut the black wire to mount here. (save the excess wire you will need it later).
Use this for your ground.
Now that we have 2 out of the 4 wires hooked up, we need to get the White, and Green wire around to the PCM.
You will need to get the 2 wires into the engine compartment. I had drilled a 1/2 hole (once again from a previous install, but you will probably need to drill one here to get the wires through the firewall. unless you can find some other way.. It was just easier to drill.
To do this remove the kick plate cover, and the threshold cover. Using a 1/2 drill bit drill your hole.. You will need verify you aren't drilling into the brake booster, or anything else here. I would give measurements, but don't wont to be held accountable if they are different for you. YOU WILL NEED TO MEASURE OUT WHERE A CLEAR SPOT IS.
Once your hole is drill using some wire loom snake the to wire through the hole, concealing the wire as much as possible to make a nice clean setup.
From here I took the 2 wires around the driver front of the car. along the radiator, and out right past the radiator fluid level check cap.
This is where your excess red, and black wire comes in. You will need to splice on some additional wire. If you want you can go obtain some more Green and white wire, but I felt the black and red was sufficient, and just used it. Remember if you do use the red, and black wire, remember which color you spliced together.
I spliced white with red,
and Green with Black.
Now here is where everyone is getting confused on where to hook the white, and green wire up..( if you only bought the shift light, and not the dual launch light, then you only have to worry about the green wire, you wont have a white wire)
Now once you have the 2 wires over to the PCM, you need to remove the 2 connectors. Here is a nice little video on how to do this.
http://www.motorz.tv/blog/1330/how-t...-chevy-camaro/
Once you have the connectors off.
the black Connector is X1,
and the Gray Connector is X2
Remove the black plastic cover. it is held on by a tab on either side of the connector.
Now take X1, what you are looking for is Pin 71. It is a Gray w/black stripe wire.
This is your VSS Signal wire.
Using a 16-14 gauge T-Tap attach your white wire to here.
Now for the X2 Connector You are looking for Pin 20. It is a tan wire. Located here.
repeat what you did for X1 here.
Almost done.
replace the 2 black plastic covers on the connectors. Then reinsert the connectors into the PCM.
Once everything is back together is should look similar to this.
I would advise using the covers supplied with the light.. as at night the Red LED lights are very blinding without the cover.. with the cover on it is still very visible but doesn't light the whole cab of the car up.
couple of pics
with the cover light on
With out the cover on
I hope this helps everyone is trying to figure out what wire goes where, with installing a Raptor Shift Light.
Daniel.....
2010 Camaro SS/RS HKE Forged 416 CID
http://www.fquick.com/ThunderZ28
510 HP/485 Ft. Lbs
ThunderSS is offline   Reply With Quote
Old 01-14-2010, 12:39 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2010 2SS IOM ,2014 Z/28, 66 Nova
Nice work i was hoping some one did this now i can order the light.
Thank you.
Old 01-14-2010, 02:24 AM   #3
tom692010
Drives: 4 wheels
finally,finally.....Black10 will also be happy someone finally found the answer to this question!
tom692010 is offline   Reply With Quote
Old 01-14-2010, 08:01 AM   #4
BLACK10
BLACK10's Avatar
THANKYOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
Old 01-14-2010, 08:54 AM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Nice writeup.
I piss excellence
and fart awesomeness
Old 01-14-2010, 03:33 PM   #6
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Thanks for the write up I know what I'll be doing this weekend.
Old 01-15-2010, 12:17 PM   #7
FRCBobby
FRCBobby's Avatar
Drives: 2008 Corvette
Very nice writeup.
FRCBobby is offline   Reply With Quote
Old 01-15-2010, 04:47 PM   #8
ThunderSS
ThunderSS's Avatar
Thanks guys...
510 HP/485 Ft. Lbs
Old 01-16-2010, 06:45 PM   #9
BLACK10
BLACK10's Avatar
BTW- LS3 or L99, set shift light to "1 cylinder" mode (reads off injector wire).
Old 01-16-2010, 07:48 PM   #10
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Hat. Thunderss. What is the other gauge on your dash?
Cool write up. Thanks for the info.
Retired
cowboy1948 is offline   Reply With Quote
Old 01-17-2010, 02:00 AM   #11
ThunderSS
ThunderSS's Avatar
Thats my digital A/F guage. A must have when tuning your vehicle.
the only way to accuratley dial in your A/F when tuning. you want your A/F around 12.7 @ WOT. and to run 14.7 when cruising..
It lets me see what the computer is doing while driving.. More than once I have caught a problem, before it became a major problem by noticing the PCM was pulling fuel.
510 HP/485 Ft. Lbs
Old 01-30-2010, 12:52 PM   #12
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Nice wirte up and install. . .
I just hooked my shift light up, its not the dual mode. I used the signal from injector 7 control and the light will blink every time I blip the throttle and also intermittenly at low RPM's. It will also light and stay lit when the desired RPM is hit.
Do you have this problem? I called raptor and they said they saw this happen on 350Z's and a few other cars. They now are sending me somthing so I can hook the light up to a coil control wire.
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter
www.e85lsx.com
E85LSX is offline   Reply With Quote
Old 02-21-2010, 04:56 PM   #13
BLACK10
BLACK10's Avatar
this happens to me too. even if i turn off the launch light feature(dual mode) , it still blinks sometimes
please keep us updated
Old 03-01-2010, 09:24 PM   #14
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
The light can not use an injector for its signal. The injectors somtimes fire multiple times per cyl event and this will cause the problems.
You have to use a coil control wire for the signal. A voltage amplifier has to be used as well because the coil control is very low voltage.
Call Raptor and they shuld send you the voltage amplifer for free then use any one of the coil control wires.
Raptor should comment here and take care of everybody who already bought the light as they did for me. They really should send the voltage amplifier to you for free.
www.e85lsx.com
Manual shift - 1-4 ? calflan V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 27 01-19-2015 11:39 PM
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 11:34 AM
Speed inc. skip shift harness installed Ringo V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 09-21-2009 03:21 PM
Anybody get a shift light yet. what brand? mstrfdsstr Dragstrip and Launch Techniques Discussion 2 09-20-2009 07:38 PM
