| Suspension / Brakes / Chassis All suspension, brakes and chassis discussions. |
Thread Tools |
![]() Drives: CGM 2SS Roto-Fab CAI, Mach XL CAT Join Date: Oct 2009
PLEASE HELP!!! Remove Calipers for Powder Coating
I'm wanting to remove the calipers for powdercoating.
Question 1. Does the entire brake fluid need to be drained to remove calipers or can you quickly remove the hose and clamp it off so as not loose all the brake fluid? .2 Do you just remove the star bolts on the back of the caliper and spread the calipers apart and them to reinstall use a c clamp to press the cylinder back in? 3.How in the hell do you get those 18 mm bolts off of the back of the caliper. Ive tried everything. Is there something you can recommend 4. What parts of the caliper need to come apart if I ever do get these damn things off The car is on blocks now with the tires off so I wanted to remove them asap so i can get them to the painters any help would be greatly appreciated Last edited by kismyss; 01-14-2010 at 09:47 PM. |
![]() Drives: 67 Camaro 350, 2010 2SS Join Date: Apr 2009
I know some of this, but I would really like to know to from the pro's to.
and how in the hell do you get those tight ass 18 millimeter bolts off of the back of the caliper. holy crap those things are tight. I've tried a socket, crescent, pipe wrench. please somebody help. I know theres gotta be some [pros that know how to do this shit
![]() ![]() Drives: 2010 Camaro, 2SS/RS Join Date: May 2009
Well first off, pictures would help.
Second... you should always try an impact... it does the most work with the least collateral damage. IE your knuckles! If you dont have an impact gun, then use the biggest ratchet you have and then take the box end of a huge wrench and slip it over the end of the ratchet to extend the handle out further, this will give you more torque to turn the bolt loose.
2010 2SS/RS CGM American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount |
NuptualNemesis
Drives: Silver 1SS M6 - 480hp 11.57/120.79 Join Date: Jul 2009
You are going to have to completely disassemble the calipers to powder coat because they have to bake them. I would recommend a mechanic take apart and put back together. The powder coater must be very careful not to coat any parts that have tight clearances on the inside.
You would probably be better off buying some already powder coated and sending yours in as a core. |
#6 |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
To remove the 18mm bolts: I Turn the steering wheel all the way to the left,(with car on stands and wheels removed) then with wheel turned left you can get to the bolts on the passenger side caliper easier. I used a shallow 6 pt 1/2" drive socket and breaker bar, and I used the handle of my floor jack as a cheater bar slipped over the breaker bar. Worked great (impact wouldn't touch it). Then turn the steering wheel all the way to the right and do the drivers side.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
| Thread Tools | |
| Why do my front Brembo Calipers have stick on wheel weights on them? | 55Designs | Suspension / Brakes / Chassis | 7 | 01-07-2012 09:31 AM |
| colored brake calipers ? | BELLSS | Suspension / Brakes / Chassis | 5 | 12-29-2009 11:46 PM |
| Custom Powder Coating Services | ProdigyCoatings | Exterior Parts & Accessories | 9 | 09-18-2009 07:58 PM |
| Glossy Black Calipers | ChevyBoiSS | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 02-17-2009 09:05 AM |
