Solo Performance
Old 01-15-2010, 12:22 PM   #1
GFORCE1320
Drives: 05 GTO
New Aluminum and Carbon Fiber Driveshafts coming soon
That's right folks, more products coming out of design stages.
I'm working on our Camaro Driveshaft designs and will have 2 driveshafts out on the market by late winter or early spring.
These will be one piece driveshafts and will be different then anything on the market.
We supply billet pinion yokes with our driveshafts, that way it gets rid of all the adapters and couplers to provide a nice smooth ride with no vibrations.
We have had great success with our GTO one-piece driveshafts and will carry on the one-piece designs with the new Camaro. I encourage anyone to go see how our one piece carbon fiber driveshafts are working out for the GTO guys http://www.ls1gto.com/forums/showthread.php?t=307526
Don’t let anyone tell you that a one-piece shaft won’t work, ours work perfect!
As far as strength, our carbon fiber driveshafts are SFI approved and have been dyno tested to 2800 ft lbs of torque and 10,000 rpms!
Carbon Fiber driveshafts also greatly reduce driveline shock and will help your driveline live a long life
Our Aluminum shafts will have a 850hp rating and our Carbon fiber shafts will have a 1000+ hp rating.
No pricing as of yet but will be out soon.
I'll get some photo's up soon, these shafts are a really innovative design and I'll be proud to show them off.
Thanks
Chris @ Gforce Engineering
GFORCE1320 is offline   Reply With Quote
Old 06-02-2010, 08:21 AM   #2
Autobot
More than meets the eye
Autobot's Avatar
Drives: 2SS RS M6 V.R. & 2006 Jetta TDI
Autobot is offline   Reply With Quote
Old 06-02-2010, 12:20 PM   #3
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
This has probably been asked/stated a few times since you first started talking about them, but can we expect any weight savings from either of the two driveshafts offered?
Also a general question- Are one piece or two piece usually lighter?
Kyle2k is offline   Reply With Quote
Old 06-02-2010, 01:53 PM   #4
GFORCE1320
Drives: 05 GTO
One piece shafts are lighter.
The Carbon fiber shafts will be about 2-3 lbs lighter.
The aluminum shafts will be about the same.
Big benifits will be major strength improvement and the carbon fiber shafts will have a much higher speed rating then the stock shafts.
Thanks
Chris
Old 06-02-2010, 02:20 PM   #5
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
Thanks
Chris
Cool, can't wait to see some of these installed and at the track!
Old 06-02-2010, 03:27 PM   #6
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
I'll be (im)patiently waiting for one of these!!
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 06-02-2010, 06:31 PM   #7
Autobot
Autobot's Avatar
Me too
Old 06-06-2010, 08:45 PM   #8
55Designs
Drives: 2010
G Force when will these be ready? I am ready to buy it now because my 2 piece GM driveshaft is driving me nuts with the vibration. My local dealer has had over 60 cars with the same issue and they just replace the shaft and coupler but the problem of the vibration creeps back. I think a solid design to eliminate the 2 piece design and one that is balanced in house before the customer installs will solve this issue. I think you will have a huge market for guys like myself beside the power hungry owners who want strength. Please PM me with more details if you can.
55Designs is offline   Reply With Quote
Old 06-06-2010, 09:36 PM   #9
GFORCE1320
Drives: 05 GTO
I'll have to see where were at on them. Shouldn't be too long now before we can put one together.
Our billet pinion yokes are now done, still waiting on a couple parts to be made.
Thanks
Chris
Old 06-10-2010, 07:15 PM   #10
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
you guys are too slow.
SSTony is offline   Reply With Quote
Old 06-10-2010, 08:01 PM   #11
Dentyneice
Drives: 2010 Camaro 2ss
What's the benefit of a one piece DS over the stock 2 piece?
I snapped some driveshaft bolts a few months ago... will this DS prevent them from snapping?
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 06-10-2010, 08:23 PM   #12
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Weight reduction and strength.
Old 06-10-2010, 08:47 PM   #13
GFORCE1320
Drives: 05 GTO
Strength for the most part, a little weight savings as well.
Which bolts did you break? Our driveshafts come with a billet pinion yoke for the diff to replace the OEM rubber donuts and those bolts. It uses a big 1350 series u-joint.
Thanks
Chris @ Gforce
Carbon Fiber Cowl Hood, Trunk, and more! PHASTEK Peformance Sean@Phastek Exterior Parts & Accessories 3 01-29-2010 02:44 PM
cut some weight? jordan 572 5th Gen Camaro SS LS LT General Discussions 65 04-06-2009 03:54 AM
New Bugatti Veyron Pur Sang AConn General Automotive + Other Cars Discussion 7 09-14-2007 02:47 AM
