Cold Air Inductions
Old 01-15-2010, 04:42 PM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
Question w/alignment and springs
I remember reading that if you put on lowering springs (1" drop) that you should have it to align to (I think) -.8/-.6? Something like that. But I also remember that with the factory bolts that only about -.9/-.9 could be acheived.
So, without buying the kit to allow the extra for alignment, should I go with the -.8/-.6 setup or go back with the stock specs since I can't quite get to the recommend specs?
Refraze: after lowering since I can't get to the recommended alignment specs should I just go back to factory settings or get as close to the recommended setting as possible?
Edit: I found the thread and it said to use -1.0 front and -.5 rear but that you can only get about -.9 out of the factory setup.
Build Journal
Old 01-15-2010, 04:46 PM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
The difference between the 2 specs you listed are negligible. I can infer you are talking about camber?
Personally, for handling reasons I would be going the other way... -.50 to -1.0 for camber and .0625 to .125 toe in
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-15-2010, 06:50 PM   #3
hypurone
hypurone's Avatar
That's more like it. You just need to make sure the alignment shop does a "dynamic" setup. This means to have you in the car as your weight will change the settings left to right and they need to assess how much the front end changes toe under compression. This is really important, 'cuz when you have that much weight and weight transfer to the front you need to compensate for it.
As an example, if they pull down on the front end while on the rack, they can see if it likes to toe out or toe in under the slowing/stopping load which is greater than just whizzing down the road. I usually divide that in half and add/subtract that to the total setting.
As a rule to keep the tire wear even, if you run -1.0 camber you should add 1/16 to 1/8 inch toe IN plus factor in the change when loaded.
And yes, I did this for many years as a paid tech...
Old 01-15-2010, 07:55 PM   #4
caverman
caverman's Avatar
Hmmm....good idea to be in the car....especially since I'm weighing in at 270 (6' 5").
Build Journal
Old 01-15-2010, 11:34 PM   #5
Rob@WretchedMS
Drives: His Wife Crazy
With the amount of understeer in the Camaro, setting the front camber to -.5 and the rear camber to -1.0 will increase the understeer, and make the car handle worse.
Setting the front to -1.0 and the rear to -.5 or even 0 will help the understeer that the car has,
The front toe should be toed out a bit, or set to 0 if your looking for handling, toed in a bit for tire wear.
Rear toe should be toed in a bit.
Rob@WretchedMS is offline   Reply With Quote
Old 01-15-2010, 11:41 PM   #6
Rob@WretchedMS
edit: you may need our bolt kits to get the alignment where you want it to be.
If your feeling brave adding a bit of caster will help a ton, but requires a bit of labor to do that.
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
Best prices on Eibach pro-kit springs & question on camber adjuster kit topgun1 Suspension / Brakes / Chassis 4 10-14-2009 07:00 PM
Springs performance question mr_desmo Wheels and Tires Talk Sponsored by The Tire Rack 2 09-18-2009 02:48 PM
Lowering springs question newgenss Wheels and Tires Talk Sponsored by The Tire Rack 14 09-07-2009 01:46 AM
