Old 08-18-2008, 01:05 PM   #1
smike07
smike07's Avatar
Drives: 1998 convertible Camaro RS
Hot Cam!
Whose going to replace their stock cam for the GMPP hot cam? It's a painful job, but I know I'm game! That's one sweet way to get the Camaro up to 472 ponies! It'll cost about $500.00 but it's relatively cheap considering many other alternatives. After that I'll add an intake. I may tack on a set of Kooks headers and an X pipe, and Corsa mufflers. They're expected to add an additional 30 horses. I don't want anything to look obvious when I open the hood, so I may just drop in a high flow filter into the stock box. It may only add 6 horsed or so, but it still equates to a 508 horsepower engine without a blower. I won't add one of those until she's paid for.
smike07 is offline   Reply With Quote
Old 08-18-2008, 02:52 PM   #2
ckellyme3
ckellyme3's Avatar
Drives: 1986 IROC 406 stroker
Thats actually a really good idea i plan on doing something similar. If i find a new cam for $500 at the time i will def opt for that but i wont settle for the new camaro without a blower. I've had my heart set on a supercharged V8 (nothing like that whining sound to accompany the high revs) since i first heard about this car. How come you dont want it to look obvious you had work done when you open the hood? Haha you have to be one of the only people I've ever heard say that.
ckellyme3 is offline   Reply With Quote
Old 08-18-2008, 03:14 PM   #3
Sizzox
Most Known Unknown
Sizzox's Avatar
Drives: 08 Vette
Send a message via AIM to Sizzox
I will prob be doing the same thing as you guys but yeah i want ppl to be afraid when i open the hood
Sizzox is offline   Reply With Quote
Old 08-18-2008, 03:22 PM   #4
69Firebird
69Firebird's Avatar
Drives: 2010 Black 2SS/RS LS3
Installing a Hot Cam would be on the top of my list for Mods, but I live in MA and we have strict Emissions testing. I've done a little searching regarding Corvettes with Hot Cams passing emissions testing but haven't found much.
Does anyone here have an experience with Hot Cam swaps and Emissions testing?
Thanks
69Firebird is offline   Reply With Quote
Old 08-18-2008, 03:25 PM   #5
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
If it doesn't void the warranty then I'll definitely install a hot cam if not for the performance boost than the awesome lopey sound once you couple it with a custom exhaust.
nUcLeArEnVoY is offline   Reply With Quote
Old 08-18-2008, 03:34 PM   #6
smike07
smike07's Avatar
Because when I stomp the Mustang GT500 and Challenger SRT8 on the track, I want them to wonder why the Camaro that only has an exhaust system and a heavy-footed driver just left them in the dust! No, not really, I'd tell 'em.-- I personally like things to be left the way they are. I suppose later on down the line, shortly before adding the blower, I'll bore the throttle body, and possibly send the heads, lower, and upper intake to be ported and polished. That'll be after the warranty is void. She'll still look stock, but she sure as hell wont run like it. That'll be a minimum of 550 horses and counting. Toss on a blower and she'll likely do what the ZR1 does... only a butt-load heavier. Carbon fiber can only go so far without cutting her all up. The bumpers, fenders and hood will certainly be replaced. Good God this is getting expensive!
Old 08-20-2008, 07:21 PM   #7
GOT PSI
GOT PSI's Avatar
Drives: SRT-4
I'm planning to do the same mods as you exept for different brands. Once it's out of warranty, bring on the procharger and plates that read " KR THIS".
I am a power junkie,
and forced induction is my fix.
GOT PSI is offline   Reply With Quote
Old 08-20-2008, 08:12 PM   #8
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
if you have a dealer install it
Old 08-20-2008, 08:31 PM   #9
shank0668
shank0668's Avatar
Part Description Duration Maximum Lobe Technical Notes
Number @ .050" Lift (in) Separation
Lift (deg) (1.7 rocker) (deg)
The original Chevrolet small-block inspired enthusiasts at all
levels, and rapidly became the preferred engine of serious
builders. The basic architecture was so well-thought-out, that
other than a few tweaks, very little needed to be improved.
Displacement and power numbers continued to rise as bigger
bore sizes were offered, and head, piston and intake technology
improved, leading to gains in durability and performance. But,
the basic engine remained: an iron block, iron-head, pushrod
driven, naturally aspirated model of efficiency.
The bore potential of the small-block was aided by two innovations—
green sand casting (a Pontiac process) and Siamese cylinder
walls, which eliminated coolant channels between the block’s
cylinders; both advances allowed for more “cutting.”
These two agents helped push the small-block dimensions from
the original 265-cubic-inches to 283, 302, 327 and eventually 400.
But, if size is one measure of performance, weight is another, and
ultimately GM engineers knew that to keep the Chevy small-block
on the leading edge, a serious re-design was in order.
While the Gen II engines were little more than a face lift (reverse
cooling flow). The Gen III and IV engines of the LS series were
a radical departure. Iron blocks were replaced by weight-saving
aluminum blocks with cast-in iron sleeves. Recognizing the
monumental torque and horsepower ratings these engines would
see, the block was designed with six-bolt main bearing caps.
Improved intake technology and hotter camshafts also greeted the
buying public.
The Gen IV series also brought in variable valve timing and displacement
on demand technology that allowed the user to shut down
half the cylinders for fuel savings when the power was not needed.
The LS series now has culminated in the introduction of the
LSX block, a marvel of engine technology co-designed by GM Performance
Parts and NHRA legend Warren Johnson. The iron block can
be bored and stroked to big-block dimensions at 454 cubes.
Today, as has been the case since 1955, the sky is the limit for
enthusiasts at all levels, with crate engines and components
available to take a builder anywhere they might want to go!
Living up to the promise
Cutaway illustration of
the 2006 7.0L V-8 LS7
crate engine for the
Chevrolet Corvette;
done by Rick Kimble.
12565308 2002–2004 LS6 Cam I: 204 I: .550 117.5 Cam requires valve spring P/N 12586484
E: 218 E: .550
12560950 2001 LS6 Cam I: 207 I: .525 116 Cam requires valve spring P/N 12586484
E: 217 E: .525
12480110 ASA Cam I: 226 I: .525 110 Cam requires valve spring P/N 12586484; “ASA” cam for off-highway use.
E: 236 E: .525
12480033 Hot Cam Kit I: 219 I: .525 112 Kit includes 16 LS6 valve springs P/N 12565117 and retainers
E: 228 E: .525
88958733 LS Hot Cam I: 219 (1.7 rocker) 112 Same cam as in kit P/N 12480033
E: 228 I: 525
E: 525
88958606 Showroom Stock I: 239 I: .570 106.5 Showroom Stock racing design; requires hollow stem intake valves P/N 12565311, hollow stem exhaust
Cam E: 251 E: .570 valves P/N 12565312, valve springs P/N 12586484, and aftermarket notched pistons OR machine stock pistons
12571251 LS7 I: 211 (1.8 rocker) 121 Stock LS7 camshaft
E: 230 I: .591
E: .591
12561721 LQ9: 2002–2006 I: 196 I: 467 116 Stock cam for 2002–2006 LQ9 and 2001-2004 LS1 engines
LS1: 2001–2004 E: 201 E: 479
88958722 LS Stage 2 Cam I: 227 (1.7 rocker) 108 Max lift with 1.8 rockers .583/.583
E: 239 I: 551
E: 551
88958723 LS Stage 3 Cam I: 233 (1.7 rocker) 107 Max lift with 1.8 rockers .630/.630
E: 276 I: 595
E: 595
Old 08-20-2008, 09:21 PM   #10
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
^ Good Info.
Old 08-20-2008, 09:25 PM   #11
shank0668
shank0668's Avatar
^ Good Info.
could you read it? its the gmpp catalog
Old 08-20-2008, 09:48 PM   #12
GTAHVIT
Blessed
GTAHVIT's Avatar
Reads fine
Old 08-20-2008, 09:54 PM   #13
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
guess Ill be heading over to the gmpp site next!
TFord is offline   Reply With Quote
Old 08-20-2008, 09:55 PM   #14
shank0668
shank0668's Avatar
download parts catalog and look at page 1 for ls parts theres intakes heads cams and more
HOT ROD ARCHIVE SERIES features Camaro z28camaro2471 General Automotive + Other Cars Discussion 4 12-14-2009 01:22 PM
Can a Superchagered Z28 have a lumpey CAM, and sound like a NA heads and cammed LS3 D-Unit Forced Induction - V8 12 07-29-2008 04:34 PM
New Cam GCguy2169 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 07-22-2008 06:36 AM
Parts from GM (cam and heads etc) blackgloves Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 06-19-2008 11:48 PM
Hot Rod Pump Gas Drags z28camaro2471 General Automotive + Other Cars Discussion 9 09-02-2007 07:41 PM
