Old 01-16-2010, 05:54 AM   #1
honeybucket99
Drives: 2SS/RS CGM CAMARO BEAST
diconnecting battery after tune
If I tune my car, then I have to disconnect the battery? Does this have to be don at the battery? Or, does disconnecting this jump post under the hood perform the same function? Thanks.
honeybucket99 is offline   Reply With Quote
Old 01-16-2010, 09:26 AM   #2
06MonteSS
Drives: 2006 Monte Carlo SS
disconnecting the jump post won't do it... that's just a remote jumper cable location - power will still be going through everything because the battery is connected...
you need to do it at the battery itself...
06MonteSS is offline   Reply With Quote
Old 01-16-2010, 10:31 AM   #3
Russell James
Russell James's Avatar
Drives: Camaros
Tune doesn't affect how you would handle a battery disconnect. If you disconnect the battery the only thing you will have to mess with is the window indexing, and there is directions in the owners manual on how to reset that easy.
To disconnect any car battery - do it at the battery, negative cable first.
Then when reconnecting - negative cable last.
Old 01-16-2010, 12:07 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
are you using hptuners,, if you get the latest beta they have this issue fixed.
Old 01-16-2010, 06:13 PM   #5
honeybucket99
don't want to say if I tune or not I guess I will disconnect at battery if I decide to tune
Old 01-16-2010, 06:27 PM   #6
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
When BOTH positive and negative cables are OFF of the battery, touch the two cables together a couple times to down power the keep alive feature in the ECM.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 01-23-2010, 10:25 AM   #7
Mark-HD
Mark-HD's Avatar
Drives: 2010 Inferno Orange SS
I have the latest beta and it still has the problem. I have to disconnect...
2010 Camaro SS, M6, MTI shifter and sway bars, GM quarter flares, Corsa catback, Roto-Fab CAI, 30% tinted windows, Lloyd's custom mats, Hawk ceramic pads, Pedders lower coils, Magnuson supercharger with 3.6 pulley, BMR trailing arms & toe rods, Kook's LT's1 7/8 w/cats, Lingenfelter/SLP billet pedals, KW V'3 Coilovers, RevExtreme catch can, ---Ordered--- IconZ LS7 9 & 11" polished wheels!. Dyno'd 563.05 HP, 543.86 Torq.
Mark-HD is offline   Reply With Quote
Old 01-23-2010, 10:46 AM   #8
camaro1
camaro1's Avatar
strange, i also did the 2.5bar maf upgrade when it came out so i could tune the actually ve table and have complete fan control, and i havent had to disconnect any thing after doing the upgrade
Old 01-23-2010, 12:08 PM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Yeah, I disconnected my battery and it had no affect on my tune. But yes, my windows had a little trouble indexing. But that corrected itself.
Old 01-23-2010, 03:44 PM   #10
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
just unplug BOTH cable to the ecu. does the trick everytime
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 01-23-2010, 08:08 PM   #11
MorePowerMike
MorePowerMike's Avatar
Drives: me crazy
If you decide to go the tuned route, SCT's programmer will reset the trims/learning for you. No need to disconnect the battery or ecu. Which in my experience does not immediately clear anything. I've disconnected it, logged the car and still saw the same learned values. After using the SCT I don't have to worry about any of this.
MorePowerMike is offline   Reply With Quote
Old 01-25-2010, 01:45 AM   #12
03ss
Drives: 03' Silverado SS/ TBSS 06'
Intersering, how did the 2.5 bar tuning go. What sensor you use?
03' Silverado SS
03ss is offline   Reply With Quote
Old 01-25-2010, 07:40 AM   #13
camaro1
camaro1's Avatar
stock sensor, you can scale the ve table to whatever sensor you want to use, 1,2,2.5bar
Old 01-26-2010, 08:55 PM   #14
Mark-HD
Mark-HD's Avatar
Is it safer to disconnect the battery? Wondered if unplugging the ecm runs any risk of a voltage spike. It would be more convienent to just unplug the ecm.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Supercharger tuning: Why shop tune instead of tune with the S/C? JProberts Forced Induction - V8 10 12-28-2009 04:54 PM
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 02:03 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
