Caryle Racing
Old 08-19-2008, 04:12 AM   #1
Kelton00912
Kelton00912's Avatar
Drives: Blue 2005 gmc sierra denali
Manual Trans in The ls3 v8 ??
so like i know the camaro will have a cheaper v8 and a more expensive v8 thats has allot more power... so what i was wondering is that can you get the manual transmission (6speed) in the cheaper v8 ? cause by reading the specs on it you cant by my understanding? if so im screwed! cause its 3 peddles or nothing lol
Theres No Point Of Driving A Sports Car Without 3 Peddles
Kelton00912 is offline   Reply With Quote
Old 08-19-2008, 04:34 AM   #2
Jamestwilliams
junior member
Drives: Grand Am
I don't think the engine with les power will actually be cheaper. The manual will be standard equipment with the auto as an option. http://www.camaro5.com:80/forums/showthread.php?t=6040. Also you'd have to consider what that "cheaper" engine does, it has cylinder deactivation and the auto comes with paddle shifters of some kind.
Jamestwilliams is offline   Reply With Quote
Old 08-19-2008, 08:14 AM   #3
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
there's no such thing as a "cheaper" V8 model at launch... the L99 is the 400hp cylinder deactivation engine that only comes with the automatic transmission... the 422hp engine is the LS3 and is only available with the manual... do not be surprised if the manual transmission option is a price adder, as GM is wanting to sell the heck out of the autos.
also dont be surprised if these numbers, much like the 361hp in the G8, are way low for what the car is actually producing.
got tequila?
SilverTurtle is offline   Reply With Quote
Old 08-19-2008, 08:29 AM   #4
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
I would imagine the automatic transmission would be more expensive than the manual..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 08-19-2008, 08:56 AM   #5
SilverTurtle
while historically the case, I believe we will see role reversal in this model
got tequila?
Old 08-19-2008, 10:20 AM   #6
Dan
Dan's Avatar
Drives: 2004 GTO
On the GTOs the manual was a $695 option, auto was standard.
Dan is offline   Reply With Quote
Old 08-19-2008, 10:45 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It would seem to me the auto' would be more pricey too. I think the AFM in the L99 would have something to do with that since it sounds more complex than the LS3, valvetrain-wise. I'm sure it'll be underrated and under tuned. I'm sure getting rid of the TM would help a lot. I can tell you the difference in my car with the TM on and with it off were litterally night and day.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-19-2008, 05:15 PM   #8
fastball
White 'n Nerdy
Drives: 2017 Camaro 2SS 6MT
The GTO also did not have AFM and the more sophisticated transmission setup that will be in the automatic Camaro (good old 4 speed was in the GTO while the Camaro will have a 6 speed and paddle shifters or a manual operation of some kind).
Another factor to consider is that, since GM knew the automatic would get the gas guzzler tax, I think they used that as a reason to charge extra for the 6 speed and say to people "hey, you're still getting it cheaper than an automatic without the gas tax"
fastball is offline   Reply With Quote
Old 08-19-2008, 09:07 PM   #9
gunslinger
Drives: 1998 Z28 M6
The A6 will have a gas-guzzler tax while the M6 won't?
I figure the rated EPA MPG will be similar...
gunslinger is offline   Reply With Quote
Old 08-19-2008, 10:16 PM   #10
Jamestwilliams
junior member
Drives: Grand Am
Just to avoid confusion I put parenthesis around the term cheaper to show I didn't actually agree that the l99 would be cheaper. I was quoting the original poster.
Old 08-19-2008, 10:17 PM   #11
fastball
White 'n Nerdy
No, no, no...... I sorry, I think I might not have been very clear..... I was talking about the GTO and why I don't think you will have to pay for the manual on the Camaro:
What I meant, was, that since the 6 speed manual was a 695.00 option on the GTO, GM may have been using the fact that the standard 4 speed automatic was subject to a federal 1200.00 gas guzzler tax to garner some extra cash, while still be able to say the 6 speed manual was less than the automatic.
The AFM should help the Camaro avoid a gas guzzler tax. GM is aiming for 23 mpg highway with the automatic L99, which is about 3 mpg highway more than the 6.0 4 speed automatic got on the GTO. Not to mention, the ratings system has been revised since the GTO went out of production, so the L99 Camaro should be quite a bit more economical than the GTO automatic ever was.
Old 08-19-2008, 10:32 PM   #12
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
I think the 422hp manual might be more $$$ then the 400hp auto.
After reading the specs, it sounds like the manual will be standard and the auto will cost more. Thats usually the way it is.
JEFF2010SSMANUAL is offline   Reply With Quote
Old 08-19-2008, 10:42 PM   #13
SoFlaZ
SoFlaZ's Avatar
Drives: Nothing special :-(
I must be having a brain fart but what is a TM?
I hope not
SoFlaZ is offline   Reply With Quote
Old 08-19-2008, 11:38 PM   #14
shank0668
shank0668's Avatar
Drives: '00 WS6/'06 LJ/'76 Trans Am
Send a message via AIM to shank0668
ill be po'd if the auto is more and why cant they be the same price as the 69's
Camaro SS LS3 gear ratios. JEFF2010SSMANUAL V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 23 06-25-2015 10:45 AM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 10:20 AM
Edmunds: GM Foreign-Exchange Program: Holden Special Vehicles Getting LS3 Scotsman General Automotive + Other Cars Discussion 5 03-27-2008 01:51 AM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 06:11 AM
