Old 01-17-2010, 12:12 PM   #1
GeorgeM
Drives: 2016 2SS, Yellowjacket, A8
Painting the Engine Cover
To all the Camaro owners who painted their engine covers themselves ($285 option), let me ask:
1. Will the special order dealership 5 oz can of inferno orange spray be enough to paint the cover, or do I need to order another can?
2. After masking, did you spray a primer on the cover or just go directly to color?
GeorgeM
GeorgeM is offline   Reply With Quote
Old 01-17-2010, 12:28 PM   #2
Sevn86
Sevn86's Avatar
I want to know this also...and how much was the paint GeorgeM?
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 01-17-2010, 03:45 PM   #3
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
First let me say that I didn't order any GM special color match paint, but my car is RJT so it's a little more common as a base color.
I used dupli-color, which I could not find in RJT, so I took several, ok 7, cans from the shelf and asked the cashier if I could take them out and color compare it to my car...
I found a match, and bought 3 - 5 oz cans of the base color and one can of clear...
If you are painting the silver area of your cover, there is no need to prime it, but...... you do need to scuff sand it. I used 800 grit wet/dry sand paper and sand it until you knock the shine off of it. This ensures your new paint will have something to adhere to. Sand it, wet, dry it off, and if there are any shiny spots, resand that area a little....
As a reminder, sand large areas, don't spot sand, you'll end up with dimples in the finish...
Old 01-17-2010, 04:21 PM   #4
GeorgeM
The paint was $12.65 for a 5 oz. can and it had to be ordered. I have not received it yet.
Old 01-17-2010, 04:28 PM   #5
GeorgeM
Thanks for the help. Now I see I need more paint, clearcoat and 800 paper.
Old 01-17-2010, 05:00 PM   #6
Atcer
Atcer's Avatar
Drives: 2LT RS Silver Ice w/Cyber Grey strp
Here is your answer
GeorgeM
you can get duplicolor clear primer for automotive plasics at any autozone. I did 4 coats with 15 minutes inbetween. Then I used the can of SIM on mine and painted only the sides and I had enough leftto put 3 coats on my fuse box cover.
make light coats:
Atcer is offline   Reply With Quote
Old 01-17-2010, 05:11 PM   #7
DZbob
Drives: 2010 RJT Camaro M6
Send a message via ICQ to DZbob
A friend painted mine, but he wouldn't tell me how much it cost.
DZbob is offline   Reply With Quote
Old 01-17-2010, 06:10 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Here is the cover I customized based on views of a few other covers and some inspiration from Camaro5...
I used dupli-color regular paint. After prepping it (cutting out the top with a dremel, and filing it smooth, cleaning and taping and sanding) I painted base coats and then wet sanded it with 800 grit and then heavier color coats and then sanded it again. I then sanded it with 1500 grit wet-dry, and then sprayed it with clear coat. I sanded that with 1500 wet and then applied another coat of clear. I wet sanded that and then buffed the whole thing out with ultra fine buffing compound. It actually has a very deep color appearance...After all else was done, I got some # 8 stainless cap washers and screws and fitted them in the holes running down the center on each side...I used some screen material from Home Depot, gutter screen used to keep leaves out of the gutters, and cut it to fit and then used JB weld to install them...
Here are a few more items to consider... and this is part of a large thread on the DIY page for engine covers...Dremel, file, screen material,.......... JB weld... lol...
Old 01-17-2010, 06:30 PM   #9
Sevn86
Sevn86's Avatar
What if you have a V6 and want to paint your engine cover? How should I go about doing that since the whole thing is black? I have an ABM Camaro...
Old 01-17-2010, 06:31 PM   #10
kcamarom
SoCal C5 Family Member
Drives: 2010 CGM RS
Would like to know too.
kcamarom is offline   Reply With Quote
Old 01-17-2010, 07:08 PM   #11
DZbob
This is what the factory painted cover looks like
Old 01-17-2010, 07:23 PM   #12
Blueclyde
Blueclyde's Avatar
Drives: 2016 2SS
I had my dealer paint mine for $85. It came out perfect. Didn't have the patience to try painting myself and definitely was spending $285 to buy a new one.
Blueclyde is offline   Reply With Quote
Old 01-17-2010, 07:26 PM   #13
CatiaJockey
CatiaJockey's Avatar
Drives: 2010 2LT RS
Check out this thread:
http://www.camaro5.com/forums/showthread.php?t=32380
Old 01-17-2010, 07:34 PM   #14
teamlowes48
NFIRNO
teamlowes48's Avatar
Drives: 2010 Inferno Orange Camaro
I'm not george but I will tell you that the spray cans from Chevy do not go far. I ordered 2 for my engine cover and fuse box cover.
Prime first due to the texture of the plastic
Jason Barnes
Hazel Green Al.
teamlowes48 is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LLT engine specifications Tran Wiki 2 03-29-2010 11:06 AM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
Painting the Engine Cover Tecca Cosmetics and Lighting Modification Discussions 16 06-24-2009 08:06 PM
