Old 01-17-2010, 11:21 AM   #1
nhra stocker
nhra stocker's Avatar
Drives: 69,10 camaro 71 chevelle
Putting the stock tune back in my car???
I received my Vector Motorsports tuned file this week. I had the chance today to install it into my car. But im wanting to put it back stock for now due to my dyno appointment tomorrow. I want to be able to run it both ways on the dyno. But for some reason when i try to down load the stock file i saved , it says (Warning this is a new ECM file for us). Any suggestions???
2010 Camaro SS RS M6 Bone stock 12.58 at 110mph http://www.camaro5.com/forums/showpo...&postcount=263
1971 Chevelle SS 454 365hp NHRA C/SA 10.73 at 122
1969 Camaro (427 ZL-1 clone) M-22 being built
1982 Siverado 4x4 454 Mud truck stock class 3.66 sec in 150' of mud
nhra stocker is offline   Reply With Quote
Old 01-17-2010, 02:32 PM   #2
motor1
motor1's Avatar
Drives: 2010 Camaro 1SS/RS/M6.....no longer
Did you just download it anyway? I would imagine that if it is the stock tune that you saved then nothing can go wrong. There is a cell number in your instructions. If you are really worried I would just give them a call and if not available just call in the morning.
motor1 is offline   Reply With Quote
Old 01-17-2010, 02:35 PM   #3
nhra stocker
The stock file wont upload back to my cars ECM and The emergency phone number goes straight to a voicemail!
Old 01-17-2010, 06:01 PM   #4
motor1
motor1's Avatar
Did you get it worked out?
Old 01-17-2010, 08:21 PM   #5
nhra stocker
Nope the file is right above my tuned file saved in a folder. My wife and i tried many times to program the ECM to the stock file just like we did the tuned file but no luck. It wont even start it pops up a warning and wont let us.
Old 01-17-2010, 08:35 PM   #6
motor1
motor1's Avatar
Please post your solution when it gets taken care of. I am sure Vector will get it worked out tomorrow. They open at 9 CST but will probably answer their cell if you need them sooner.
Old 01-17-2010, 09:35 PM   #7
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Some emergency line....
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 01-17-2010, 09:37 PM   #8
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
that blows hmmm weird tho
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 01-17-2010, 10:26 PM   #9
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I would try disconnecting the battery. Remove both the positive and negative cables. Then touch the cables together a couple times to down power the ECM. Reconnect the battery.
After this, try reflashing the ECM.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 01-18-2010, 07:44 AM   #10
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
Had a similar problem with Vector on Saturday. Took my car to the drag strip and made 2 passes with the stock files to get a base line ET and then went to load the Vector files to the ECM & TCM. Loaded to 24% and quit. Tried everything that I could think of and nothing worked. Car was cpmpletely dead. Would not even load the stock files. Got ahold of Kirk at Vector and he said that they have never had that happen before. Ended up having the car put on a flat bed and towed home. Now I am looking at removing the ECM and overnighting it to Vector and renting a car for 3 or 4 days. On a whim yesterday morning I uninstalled Vector's software on the laptop and reinstalled it and tried loading the files again and it worked. Took both files. Disconnected the negative cable for 10 mnutes and the car started and runs just fine now. Hope this helps.
40years is offline   Reply With Quote
Old 01-18-2010, 08:07 AM   #11
nhra stocker
What procedure did you take to uninstall it ?
Old 01-18-2010, 08:20 AM   #12
40years
40years's Avatar
I went ahead and loaded the modified files. Have not tried to go back to stock yet. I'm a little gun shy at this point as this car is my daily driver.
Old 01-18-2010, 08:32 AM   #13
FLYNNZL1
Wicked ZL1
FLYNNZL1's Avatar
Drives: 2017 ZL1 A10 HBM
Send a message via ICQ to FLYNNZL1 Send a message via MSN to FLYNNZL1 Send a message via Yahoo to FLYNNZL1 Send a message via Skype™ to FLYNNZL1
If you mean uninstalling the software on you laptop, use Control Panal, then uninstall programs, look for the tune program.
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Tinted 3rd Brake Light
FLYNNZL1 is offline   Reply With Quote
Old 01-18-2010, 10:16 AM   #14
kelley@vectormotorsports
Drives: 2009 Pontiac G8 GT
We had no cell service at my house yesterday. I didn't realize this until my phone alerted me to his message from yesterday this morning.
Actually your issue was completely different. Somehow your laptop blocked part of the program from being installed. Sometimes an anti-virus program will do this. It is best for any type of programming to be verified at home before trying remotely. If you were home a simple log file emailed to us would have fixed the problem.
kelley@vectormotorsports is offline   Reply With Quote
Just for fun take a walk down memory lane Beandip2811 General Automotive + Other Cars Discussion 15 08-09-2009 09:26 AM
My car from stock 1Lt to my perfect car. Mohrg Beast Member Car Journals 0 07-24-2009 07:41 PM
2010 Chevy Camaro SS Indy 500 Pace Car Drive linkwpc Camaro Photos | Spyshots | Video | Media Gallery 0 05-23-2009 09:47 PM
Why you can't buy a new car directly from the manufacturer scotchsride09 Off-topic Discussions 13 02-14-2009 05:15 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
