Old 03-10-2010, 04:20 PM   #71
Agent Atomic Orange
Agent Atomic Orange's Avatar
Drives: 2010 Camaro LS IOM M6
What does the jury say about turning off all the nanny electronics for the 1/4? Could those things cause the car to "bog" down?
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp
Agent Atomic Orange is offline   Reply With Quote
Old 03-10-2010, 04:33 PM   #72
mrray13
mrray13's Avatar
Drives: 2010 1LT RS Rally Yellow
Leaving the controls on has seen to work the best. With the current setup on the car, even with controls on, it's very easy to get wheelspin. I can only imagine what would happen if I turned them off, lol.
PacMan
mrray13 is offline   Reply With Quote
Old 03-10-2010, 05:00 PM   #73
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Out of 5 passes I tried one with T/C off and it was wheel spin for the better part of 60'. No go for me, need more practice I guess.
T/C on worked well, at launch I just try not to let the wheel spin so the engine speed management doesn't kick in that results in a little hesitation.
I find it easier launching doing my 0-60 mph runs on dry, clean blacktop/asphalt but that may be from not being so pumped like at the track.
I launch from idle with my auto.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 03-10-2010, 05:08 PM   #74
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I launced from idle on all four of my runs and my times were iffy. TC was on and I was in D not S. When the light turns green do you guys floor it? Or do you ease onto it for a second or two and then mash it? Just trying to figure out how to get my 60' under 2.2x
BaylorCamaro is offline   Reply With Quote
Old 03-10-2010, 05:11 PM   #75
Agent Atomic Orange
Now are you guys driving autos or manuals?
Old 03-10-2010, 05:12 PM   #76
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Automatic, oh and I did go through the water box all four times and did a quick burn out. I've been hearing not to go through the water box if you have street tires? I didn't think I was sleeping or spinning when it turned green but maybe I did for just a second, can't remember.
Old 03-10-2010, 05:18 PM   #77
67 GTO
13.453 @ 101.90
67 GTO's Avatar
I always have it in S. I've found if you floor it with T/C on that's when wheel spin can be detected and the 'puter will compensate resulting in some hesitation till the tires grab. I try and ease into the pedal until I sense I've got good traction then I nail it. still working on it.
Old 03-10-2010, 05:27 PM   #78
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Ok, thanks GTO. I figured that by keeping TC ON and then flooring it, the car will want to spin and then the computer will cut the power for a second until there wont be any will spin. It makes sence that you need to feather it off the launch. Guess I'm going to have to test this out next time I'm at the track.
Old 03-10-2010, 05:33 PM   #79
67 GTO
13.453 @ 101.90
67 GTO's Avatar
A second in this game is a eternity. LOL..Best of luck your next time out.
Sure is fun!
Old 03-10-2010, 09:01 PM   #80
talltom
talltom's Avatar
Drives: Silver LS
Originally Posted by Agent Atomic Orange View Post
I have never taken a car to the strip before, but I was thinking about givin' it a try. I also have a manual. When you launch are you holding the clutch at the point of engagement, and then dropping it? What are your shift points (rpm)? It seems like the power peaks in this car around 5500.
It's a great experience. Most folks at the track are helpful and can give great advice (usually...grain of salt and common sense). Avoid the waterbox (the treads bring water to the staging area) and avoid the main groove when you stage (starter might line you up). I get a moderate rev and engage the clutch no faster than I can roll the throttle up. Too fast - I lurch or jump. Too slow - I'm slipping the clutch or spinning tires.
To me that first to second shift is the most important. Third just needs to be quick as hell and 5500 maybe a little higher seems about right.
Let me know how it goes. If you're at the Camaro5fest you'll have a great chance to try it out! Only 36 days.
Silver LS - manual, white stripes, black interior, and those swell 18" black steelies! (18" Bavarian aluminum in the garage).
talltom is offline   Reply With Quote
Old 03-16-2010, 10:42 AM   #81
02pewtersix
02pewtersix's Avatar
Drives: 2013 ZL1
here is my timeslip. this is my quickest time to date
02pewtersix is offline   Reply With Quote
Old 03-16-2010, 11:06 AM   #82
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Originally Posted by 02pewtersix View Post
here is my timeslip. the one on the right is my quickest time to date.
Updated.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 03-28-2010, 02:27 PM   #83
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Updated slip and another change. Replaced SLP intake with Injen CAI.
Tires used on the pass: Goodyear Eagle F1's
Performance Mods (if any):GMPP exhaust, JBA shorties, Injen CAI
Transmission:
Category submitted for: Bolt ons
R/T.......... 1.207
60'............. 2.142
330'........... 5.935
660'........... 9.033
660’ mph... 78.90
1000'.......... 11.710
1320'.......... 13.959
1320’ mph… 101.04
Name of the track: Atco raceway
Date of pass: 3/28/10
Weather conditions (include Density Altitude, if known): 43* DA -1378
Old 03-29-2010, 07:57 AM   #84
Xanthos
PWA Relapse
Xanthos's Avatar
Very nice!
- X
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 10:40 AM
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 10:50 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 04:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 12:31 PM
