Solo Performance
Old 09-13-2011, 02:54 PM   #911
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Originally Posted by KMPrenger View Post
Low 13s to high 12s on the corn syrup are coming. I can't wait to see peoples eyes pop out of their heads when they hear this and realize its just a V6 with bolt ons and tune, and no changed internals or boost.
Yep, I see moonshine & tune during the winter. I found a pump 15 miles from my house and one 15 min from Atco.
Thanks bmorecam for your work on this.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 09-13-2011, 06:00 PM   #912
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
Rod, have you tuned in that buck fifty shot yet? I seen some jetting in the othern forum, but don't know where those jets come from. I'm assuming you.
K&N Cai, BSR Ported intake, MBRP catback, BBK long tubes, VMax throttle body, 3.73 SS gears, Zex nitrous 125hp shot, window switch, purge,remote bottle opener, bottle heater, Trifecta tune, Hurst short throw, RX catch can, Intake isolator, Ported Intake manifold
jeff4946 is offline   Reply With Quote
Old 09-14-2011, 07:21 PM   #913
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
Geez... I must have koodies or something.
Old 09-15-2011, 12:13 AM   #914
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
That's who I got the numbers from, I do believe.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 09-15-2011, 01:46 PM   #915
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
You running that shot yet? I'm gonna play with it, and see if it will tune in with.this throttle body. It takes the computer a little bit to get used to it, when you change the jets.
Old 09-15-2011, 02:13 PM   #916
bmorecam
No problem!
I also want to remind you guys that there is still some room for improvement. If you ever had a chance to examine the factory ignition timing map you will notice that the timing will peak around 4k rpm then it will start to drop, and we will sometimes see a difference by almost 10* by redline. You can change the ignition timing to whatever but the timing will drive according to the set factory curve which I believe need to be controlled. The torque drops along with timing creating dips and some what of a gradual down slope.
The good thing is that I think we can gain extra ponies up top and/or stabilize the torque curve if we can stabilize the timing up top. The downside of this is that we don't have an option at this point to change things as we wish. I was actually going to try this next but it look like vince has his hands full and have other things to do
This is one of the logs on e85 that should give you guys some ideas of how the factory timing curve look like. This is 3rd WOT.
Hopefully soon I can get back to it
RPM SPARKADV°
3254 25.5
3322 25.5
3393 25.5
3393 22.5
3476 22.5
3540 23
3615 25.5
3615 25.5
3689 25.5
3762 25.5
3838 26
3838 27
3917 27
3992 27.5
4064 27.5
4064 27.5
4147 27.5
4222 27.5
4300 27
4300 27
4374 27
4452 27.5
4531 27
4531 27
4609 27
4680 27
4758 25.5
4758 25.5
4832 25.5
4907 25.5
4992 25.5
4992 24.5
5063 24.5
5139 24.5
5214 24
5214 23
5298 23
5370 23
5444 23
5444 23
5516 23
5592 23
5668 24
5668 24
5747 24
5812 24
5891 23
5891 23
5962 23
6030 23
6101 23
6101 23
6164 23
6232 23
6292 22.5
6292 23
Old 09-15-2011, 07:48 PM   #917
usa1camaro1969
I'm coming along. I've been dragging butt most of the summer in this heat, but it looks like I may have time to finally drill that hole in the Vararam or the intake manifold and install the nozzle. I'll also be playing with the jets due to the E85. Wish me luck.
-Ricky Bobby
Old 09-15-2011, 08:35 PM   #918
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
You got it buddy.
Old 09-17-2011, 08:17 AM   #919
usa1camaro1969
The moonshine up north is different during the winter. From what I'm reading they go down to 70% ethanol to help the hard-start in the cold weather states, and you, sir, are in a cold weather state. I don't know when they switch to the winter blend, but it'll be something to watch for.
-Ricky Bobby
Old 09-17-2011, 03:57 PM   #920
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
We are blending winter transition, in Utah. I work in a tankfield for Chevron, and we started these blends Sept. 1... Normally, we will go into winter blending around Oct. 15.
Old 09-20-2011, 04:37 PM   #921
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Yeah but I only ran it once and never did check the afr. I was having a major vibration problem that was consuming my attention.
ROD1 is offline   Reply With Quote
Old 09-20-2011, 11:09 PM   #922
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Hey usa1 shoot me a PM next time you go to the strip. I haven't been since I met you like a year ago, and I've modded a lot since then. Not to mention I'd like to see you run.
BaylorCamaro is offline   Reply With Quote
Old 09-21-2011, 06:24 AM   #923
jeff4946
jeff4946's Avatar
Drives: 2010 RS 2LT
Whoa.. that's not good. Wasn't the juice causing it, was it?
Old 09-21-2011, 09:13 AM   #924
ROD1
Retired
Naw Im pretty sure its the driveshaft at this point. Gonna send it out for balance b4 to long.
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 11:50 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 01:31 PM
