sjm autoprod
Old 11-07-2011, 10:07 AM   #1093
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
Tires used on the pass: 285/40/R20 - Nitto 420S - Treadwear - 420
Performance Mods (if any): Mrt V2 exhaust - Airaid V2 short ram intake
Transmission: M6
Category submitted for: N/A mods
R/T.......... .337
60'.............2.228
330'...........6.198
660'...........9.444
660’ mph...74.20
1000'...........000 (as shown on slip,error)
1320'..........14.569
1320’ mph…98.16
Name of the track: South GA Motorsports Park
Date of pass: 10/9/2011 - 10:04 AM
Weather conditions - 64.4*F, DA - 633 - 90% Humidity
Tire pressure was set to 37 lbs in the rear. Traction control was off, but not fully off. Shifted to 4th.
Please let me know anything I can do to improve this. Any suggestions, etc is appriciated.
I can post the slip if need be, but all the info you need should be here.
Thanks,
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 11-07-2011, 10:36 AM   #1094
bmorecam
So you are saying you can hit low 13's with just cutouts and vararam? And we are talking a v6 camaro right?
No disrespect but my money will not be on you. What makes you think the cutouts will give you so much power? It will help to scavenge but how far do you think that's going to take you?
Forget the time calculations, I am more curious to hear why you have so much hope that cutouts will all of a sudden make your car faster then everyone else's?
Old 11-07-2011, 10:46 AM   #1095
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Transmission: M6
R/T.......... .337
660’ mph...74.20
1320’ mph…98.16
Thanks,
With some practice you should be able to get that 60' down to a 2.0x. This will really help bring down your ET.
How are you launching?
scrming is offline   Reply With Quote
Old 11-07-2011, 10:59 AM   #1096
stand-al0ne
Rev Couture
Hey scrming,
Sorry I havent gotten back to your PM btw- congrats on all the success you're having with the twins
My launch was rev to 2500 or so, then drop clutch and floor it. The only successful time that worked was this time. Every other time I either spun or had severe wheelhop. I also made 6 passes that day. This was my first pass, and also my bet E/T. I believe the clutch was too hot by the end ( I only had to wait 15-20 min between passes). I did a very mild burnout before each pass, really just to clean the tires off and add a little heat.
Do getting closer to a 2.0 60' will help me the most? Should I not rev at all before launching next time?
Old 11-07-2011, 11:15 AM   #1097
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
You shouldn't be shifting into 4th yet 3rd finishes at like 104 or something. When I trapped 101 I was in 3rd. As for the cut outs they make more power than a cutback. Not a whole lot more maybe like 5-8 more wheel untuned. Its not just cut outs either its lighter rims and tires. My stock 14.35/14.18 was with the 20s. Going to 23lb 18s and lighter tires drops you almost. 5 tenths.
edit damn phone typos
Originally Posted by 67 GTO View Post
Perhaps we'll see on Black Friday. Almost sure we'll see negative DA at least early.
Its going to be really cold too! Im praying for no rain lol
cut outs, vararam and lighter rims/tires yes. 101.5 trap speed is indicative of about a 13.3 run with a proper 60' foot.
DarkneSS is offline   Reply With Quote
Old 11-07-2011, 12:58 PM   #1098
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
I don't believe this, I shaved 40lbs in wheel/tire weight and it helped my 1/4 mile only marginally.
BaylorCamaro is offline   Reply With Quote
Old 11-07-2011, 01:07 PM   #1099
DarkneSS
Every pound you add or subtract to your wheel/tire set up is the equivalent of roughly 7-8 pounds.
So talking about the rims alone and not even the tires, the stock 20s weigh about 30 lbs while the 1LT 18s weigh 23lbs.
That is a saving of 7 pounds per wheel. 7*8=28 pounds saved.
Once you apply some physics and rotational mass and energy equations you can multiply that number by about 8. 28*8=224.
So just the rims alone, not talking tires, is like removing 200lbs from your car. Every 100 pounds will net you approximately .1 in the 1/4.
If you get equally as weight reduced tires youre talking a 400lb decrease.
AND if you get slimmer profile tires you get a simulated better gear ratio as well which nets you maybe .05-.1 tenths. So theres your .5 reduction.
There are a number of reasons you may not have seen a sharp enough drop Id have to se everything youre running.
Anyone who knows the numbers behind drag racing will cosign what I'm saying its no secret. Its just basic physics as well.
Remember as well that when I say .5 tenths its if you reduce from the RS/SS rims. If you had say the 19s or something its not as dramatic of a decrease.
Old 11-07-2011, 01:35 PM   #1100
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Might want to check your math again. Got some errors.
I follow all the logic. I know because I have used it myself for understanding theory.
With that said, these are rough figures for THEORY only.
Now you need to go prove it to us.
GOOD LUCK.
Old 11-07-2011, 02:23 PM   #1101
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Typically when I multiply seven by eight I get 56. I've been known to be wrong in the past though..
Alright bud, can't wait to see your 13.0 time. Who knows you may even get sub 12's! What you're talking about it theory, I've learned A LOT of theory throughout my time in school. However I've come to realize theory and practice usually differ. Just say'n.
Old 11-07-2011, 02:32 PM   #1102
DarkneSS
Whoops I meant 7*4 per wheel 28 pounds saved.
Old 11-07-2011, 03:16 PM   #1103
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
Yep as they say "it all looks good on paper"
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 11-07-2011, 03:58 PM   #1104
DarkneSS
GOOD LUCK.
Thank you but I mean a 101.5 trap speed at Island, a slow track, is almost always representative of a mid to low 13 second car. you can trap that high unless thats what the car can run lol.
I kinda have proved my theory I just couldnt hook lol.
Old 11-07-2011, 05:33 PM   #1105
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
I guess everyone's just waiting to see the slip and until then we'll just keep doubting your ricer math. I'll be happy when you can get to sub-14's.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 11-07-2011, 05:40 PM   #1106
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
I have a 1.9 60' and a 102.2 trap what will my 1320 be?
Disappointing day for me and good at the same time. I ran 245/45/18 street tires and through 6 passes I just couldnt get them to hook. It was really cold out and not many cars came out today so street tires had no chance.
I'll post the slips if you guys want. The bad is I only ran 14.4, basically the same as stock.
The good/bad is that I trapped at 101.59 with a 2.5 60 foot!
Every .1 off your 60' is roughly .2 in the 1/4.
So essentially with proper tires I'll hit about a 13.45. Also at island dragway, the track I was at, cars typically run .2 tenths slower than tracks at sea level.
So although I didnt actually get a slip with the time, it seems that just with 1LT rims, lighter tires, vararam intake, and cut outs on stock exhaust My car can run about a 13.2-13.3.
Im going to go back with drag radials but unfortunately Im probably going to wait until early spring.
With radials Im sure I can cut a 1.8~ 60' which should land me right around a 13.0 MAYBE a 12.9.
This is all without headers, a tune, or the weight reduction from removing the stock exhaust.
Discuss....
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 11:50 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 01:31 PM
