Old 11-12-2011, 02:37 PM   #1163
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Originally Posted by 67 GTO View Post
This is all I can say.
scrming is offline   Reply With Quote
Old 11-12-2011, 03:50 PM   #1164
MrGazinya
MrGazinya's Avatar
Drives: Aggressive
Ha Ha, Pizza cutters on the front. Go gettem Rich
Safer than spares thats all I have to say
Black 2SS RS LS3 Inferno Int. Powdercoated 20's {MODS} KOOKS LT: Borla S-Type: Roto-Fab CAI: Hurst ST.: PFADT Stage 2, Trailing arms, Tie Rods: ECS BigBlower Cam: Fast 102mm intake: Brian Tooley racing dual spring kit: TFS pushrod set: Katech C5R timing chain: Mellings high volume oil pump: ATI Balancer: Tuned by Doug Ring at ECS. 472RWHP/445RWTQ.Dynapack Dyno.
MrGazinya is offline   Reply With Quote
Old 11-12-2011, 06:48 PM   #1165
bigted83
They call me captain slow
bigted83's Avatar
Drives: 2010 camaro lt
my time
whats wrong with my time
bigted83 is offline   Reply With Quote
Old 11-12-2011, 06:53 PM   #1166
scrming
scrming's Avatar
Main thing is your 60' time... need to work on getting that down. Is your car an auto or a manual? What kind of wheels and tires?
Old 11-12-2011, 06:57 PM   #1167
bigted83
bigted83's Avatar
auto and i had it in sport mode with the traction nanies on. and i running factory tires, and i think me being heavier doesnt help either
Old 11-12-2011, 07:00 PM   #1168
scrming
scrming's Avatar
Well... I am morbidly obese... so I know about being heavier... ugh...
Ok.. how are you launching? I found I got my best times by:
left foot on the brake
right foot on the gas
bring the RPMs up to just over idle
when you are ready to go, let off the brake and hit the gas, basically at the same time... one fluid motion, so to speak...
Old 11-12-2011, 07:05 PM   #1169
bigted83
bigted83's Avatar
im holding the brake and when the light turns i step on the gas and let go of the brake, not so fluid like, its at idle rpm when i take off
Old 11-12-2011, 07:24 PM   #1170
scrming
scrming's Avatar
Try bumping up your RPM a bit... And practice... Should be able to get the 60' down to the 2.1 range...
Old 11-12-2011, 08:05 PM   #1171
67 GTO
13.453 @ 101.90
67 GTO's Avatar
Drives: 2010 Camaro 2LT Rally Yellow
Everything scrming said. I take my rears down to 22 psi and the fronts up to 42 lbs.
At the track I run Goodyear summer tires but should work with the stock setup.
I launch from just over idle at about 11- 12k with the nannies on. I just slam the pedal.
I also do a good burnout to heat the rears up. (with T/C off for the burnout)
With T/C on, you may get a little hesitation if the wheels slip but the 'puter corrects pretty fast.
If lucky and with no wheel spin, you should get closer to a 2.00 60'
If the track is sticky, I'll launch with T/C off but that is rare in colder weather.
Just my experience.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned
67 GTO is offline   Reply With Quote
Old 11-12-2011, 08:23 PM   #1172
bigted83
bigted83's Avatar
I feel pathetic with a time like that
Old 11-12-2011, 08:37 PM   #1173
scrming
scrming's Avatar
Don't!!! With some practice you'll get those times down!
Old 11-12-2011, 08:44 PM   #1174
bigted83
bigted83's Avatar
I ran 5 times and the last run of mine was my favorite, I ran against a early stock 2000s bullet mustang and lost to it but it was close that was my reason for beings my favorite
Old 11-12-2011, 08:55 PM   #1175
HDRS
Fastest V6
HDRS's Avatar
Drives: 2010 CGM 2LT/RS 06 G6 GTP conv.
Originally Posted by ROD1 View Post
Nice Goat! Movin up the ranks! BTW What did Rich run? He get his new fronts? Im thinkin he did very well and ur holdin back!! lol
No big secret I ran a 13.7 and three 13.8 NA and only one run on a low bottle of the juice and ran a 12.05 the car was breaking up a little in each gear I think at the shift point but not sure. This may be from low bottle pressure I may try to reduce the size of the nitrous jet any feed back is welcome.
I think if I get this worked out I will be close to being told I need a roll bar. Can't wait till we line up on black Friday
1/4 Mile 11.841 at 113.98mph
SEPA5 /TEAM LLT
HDRS is offline   Reply With Quote
Old 11-12-2011, 08:59 PM   #1176
scrming
scrming's Avatar
Nice!
No rollbar until you hit 11.49...
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 11:50 AM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List GQ4Life Dragstrip and Launch Techniques Discussion 17 07-07-2010 01:31 PM
