Solo Performance
Old 01-18-2010, 11:05 PM   #15
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
You got that right!
Imagine what his car is gonna look like if it's a slow winter at the machine shop
It actually has been pretty slow this year. When oil dropped off so did we. I pray every night for gas to go back up to $5.00/gal.
Hopefully 2010 will be a MUCH better year.
g-townmach is offline   Reply With Quote
Old 01-18-2010, 11:49 PM   #16
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
Nice Work! I would buy that for sure. I have 3" pipes too and they do not have much clearance.
bpoirier is offline   Reply With Quote
Old 01-19-2010, 07:51 AM   #17
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
Originally Posted by g-townmach View Post
TUNNEL brace. Thats what its called. Not a "cross chassis brace." I'm dumb.
I was also thinking about making some links that would connect to this brace and go all the way over to the each subframe. Was looking under there and there are 2 unused threaded holes on each side and they look lonely.. wanting to be used. Seems like that would really help rigidity.
when you make it yourself, and it looks that good, you can call it any dam thing you want to. Great job.
Old 01-19-2010, 07:57 AM   #18
Mr Twisty
Mr Twisty's Avatar
I liked you for a few minutes.....
If you tie it to the subframe it'll be taking a lot more stress, the rear subframe bushings are pretty soft so it moves quite a bit.
-- Benjamin Franklin
Old 01-19-2010, 08:08 AM   #19
shevyman
Drives: 2010 Camaro SS IOM
yeah i would be down to buy one also. start building.
shevyman is offline   Reply With Quote
Old 01-19-2010, 08:47 AM   #20
Stewcam
Stewcam's Avatar
Drives: 2010 Camaro SS/RS
very nice work.
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's
Stewcam is offline   Reply With Quote
Old 01-19-2010, 09:31 AM   #21
MEDISIN
MEDISIN's Avatar
Drives: 2011 CTS-V Sedan
Beautiful craftsmanship - you have serious talent my friend!
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft.
"Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree
MEDISIN is offline   Reply With Quote
Old 01-19-2010, 09:39 AM   #22
Nice job
Old 01-19-2010, 09:59 AM   #23
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
that is beautiful
I piss excellence
and fart awesomeness
Old 01-19-2010, 10:03 AM   #24
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
I find myself wanting something like that and I am in Austin which I believe is Central Texas'ish no?
As others have said start building
Cheers
K
Moriartii is offline   Reply With Quote
Old 01-19-2010, 10:58 AM   #25
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Excelent work!
I looked in my garage and found nothing like that machine.
I will try it with my cordless drill in a vise tomorrow.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 01-19-2010, 11:02 AM   #26
ttexxan
That would be ausome if you could design this for my automatic...
http://www.edmunds.com/media/il/feat...hifter.500.jpg
ttexxan is offline   Reply With Quote
Old 01-19-2010, 12:33 PM   #27
Easy Go
Easy Go's Avatar
Drives: LLT MV5 B34 N65... period.
Honestly trying to help - not to be a wet blanket here...
1) The structural "contribution" of the shield is realized when bolted in place, so while it seems flimsy when removed from the vehicle, it does quite a bit when installed.
2) If greater durability/longevity is needed (because someone is driving their vehicle under aggressive circumstances) then maybe having a stiffer brace would be of benefit as part of an overall structural package. Signs of "more" being needed would be an observation of a buckled brace due to permanent deformation - or elongated attachment holes at the bolts. If anyone has observed this on an OEM brace, it would be good to know what the driving conditions have been and it would justify the need for "more beef".
3) The bolts are receiving higher than normal bending forces when installed using a spacer, as shown. Higher grade bolts may be needed.
4) Aluminum doesn't hold up to fatigue as well as steel does - so the design, as shown, may need some additional features to alleviate stress concentrations. Larger radii in the "cut outs", for one.
5) The design should directly strap the front bolts to the rear bolts on the opposing side as well as straight across to prevent "matchboxing". Think of a frame with an "X" pattern lined up with the bolts.
6) A gasket should be used to isolate the aluminum from the steel underbody (and fasteners) to prevent galvanic corrosion.
The spacers certainly do the trick and this definitely looks better than stock.
In the early morning... when there's only a mere suggestion that the sun is going to bother coming up at all that day - a CGM blur accompanied by the anthem of 312 horses awakens the morning commuters from their NPR-induced stupor. Charging past the front lines in an all-or-nothing battle cry that the King has returned...
Easy Go is offline   Reply With Quote
Old 01-19-2010, 01:20 PM   #28
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Thanks for all the positive feedback everyone. Maybe this weekend I'll look at tweeking my design a little bit with an X brace pocket. Considering doing a run of about 30-50 pieces and sell em.
Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H AJ@ECSMotorsports Suspension / Chassis / Brakes 80 11-17-2010 03:28 PM
Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! Circuit Motorsports Suspension / Chassis / Brakes 99 05-24-2010 05:21 PM
LMPerformance, Hotchkis 2010 Camaro Chassis Max Brace LMPerformance V8 Bolt-Ons & Tunes 0 01-05-2010 12:17 PM
BMR CHASSIS BRACE INSTALLED lawdogg149 Suspension / Brakes / Chassis 19 12-14-2009 09:39 AM
