Old 08-19-2008, 10:12 PM   #1
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Pedders partnering with GM Racing on Camaro suspension
Most of you already know that Riley Tech has been selected as the EXCLUSIVE builder of the Camaro for the Grand Am Challenge GS Camaro. What you don't know and I can now say that Pedders worked with GM on the development of this vehicle. The Grand Am Challenge Camaro will run the circuit using what Pedders considers to be daily driver bushes and bits. The OE Camaro will arrive with hydraulically damped radius rod bushes. The OE radius rod bush performs well on the street for most drivers. For the enthusiast driver a hydraulically damped radius rod bush is about as useful as the wrong size driving shoes. They are too compliant. GM asked Pedders to develop a radius rod bush that would withstand the demands of track use. You will be able to buy EP6560C Camaro Radius Rod Bushes, the same bushes we developed for the Grand Am Challenge. It is the same bush we will be using as a basic component of the Camaro suspension.
The Grand Am Challenge is a full on race car. It does not use street style dampers and there are other revisions to the suspension and drive-line. These cars will also be using Pedders eXtreme Castor Washers in addition to the full on hard mount strut bearing with Castor and Camber adjustment. In the rear suspension Pedders EP7267 Toe Link Bushes, 5422 Toe Link eXtreme Washers and EP7266 Rear Control Arm Bush. In testing at the Milford Proving Grounds GM determined that our Pedders Bits met or exceeded their engineering and driving expectations.
Pedders is a unique company. We do not make parts for race cars. We do make some street parts that just happen to perform incredibly well on the race track. Our warranty is also unique. Pedders does not have a racing exclusion. You can take your Pedderised street legal Camaro to the track, flog it. If a Pedders part fails within 24 months or 36,000 miles it is covered under warranty.
We were absolutely thrilled to be invited to work with GM on the development of the Grand Am Challenge GS Camaro. We consider it an honor to have been selected for such a special project. Working with http://www.rileytech.com/ is another honor. To be told that I own the "best handling G8 in the world" by some of the people who have worked on this project is yet another honor. Is there a better way to be introduced to the Camaro enthusiast community?
We invite all of you in the GTO, G8 and Camaro communities along with all the members of the PEDDERS NATION to take pride in the ZETA based Pedderised Chassis that will be racing in the Grand Am Challenge as a GS Camaro PEDDERISED!
For those who are interested, the Camaro platfrom will be almost identical to the G8 platform, with just a couple of exceptions and enhancements. But so far, the Camaro seems to be sitting up as high as a G8, and will have just a few pieces different. The non compliant "legacy" bushings are still there. The good thing is that Pedders is all ready for the Camaro.
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 08-19-2008, 10:22 PM   #2
The_Blur
Rock Chalk
The_Blur's Avatar
Drives: Demon Super Sport
This is great! I love finding out about more companies working to improve, publicize, and sell parts for the new Camaro.
Old 08-20-2008, 12:43 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Will you have more information after Indy'?
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-20-2008, 11:29 AM   #4
Info@PeddersUSA.com
Release of information has to come in stages. GM will control everything. Traditionally, our releases will come when GM announces stuff first.
There are still a few issues that we are working out, but should be resolved soon.
We currently have all the bushings for the Camaro. Besides the bushings and adjusters that GM uses of ours, the most critical bushings for performance driving are the 4 rear suspension cradle mount bushings. The OEM stuff is rather soft, and allows the rear end of the vehicle to move separately from the body. The great thing about these bushes is that the rubber in the bushing is not the issue; it is the huge amount of voids that allows the serious movement. So our fix is to install inserts top and bottom. Just doing this alone, will make a huge difference in handling. Also, it is a fairly easy job for the do it yourselfer!.
GM is expecting the Camaro to be extremely active in all kinds of racing. A lot of GM engineers have driven our G8 that has a full Pedders suspension system, including adjustable coil overs all around, all bushings replaced, front adjustability of caster, and multi adjustable sway bars front and rear. They are all blown away. Pedders is quite the buzz among this community. Lots of GM engineers roadtested the JusticePete G8 at the Woodward cruise weekend. and loved the experience. On the G8 forums, Pete has posted the engineers reactions.
Bushings are a big deal. All the domestic manufacturers have "legacy" ideas of bushings and what they should be. This basically means the dura (strength) of the bushes are quite weak. This is done out of concerns of reducing road noises, reduce sensitivity to vribrations, and noise. Now one of the reasons GM did not use all of our bushings, is that we make our bushings for severe racing, with built in controls for street driving also. So we are about 85% race,and 15% street. The Camaros mentioned above, will have delron bushings installed on all the links and control arms. But will have to be replaced after each race. Ours will last and last and last with no noise.
What other bushing for the rear? Especially for the drag racer, and also for the road racer and auto crossers, the 3 bushings that hold the differential to the rear cradle, is also very soft. It is alittle more of a challenge to remove and requires a special tool that we have made. GM also has a special tool for this. Our Pedders bushings are substantial and offer huge controls. There are some reports of wheel hop on some of the pumped up G8s. The rear cradle bushings and diff insert bushings should seriously help this. Then add a better controlling strut/spring combo, and now you have a big time killer ride.
For those who want to see what a ZETA platform upgrade looks like, check out this link. The system is called TRACKII by Pedders:
http://rides.webshots.com/album/565293362RwypFx
If you want more info on ZETA, and the development of ZETA and G8, check out this link
http://rides.webshots.com/album/561316983BMtYeV
thanks
mike
dms
Old 09-30-2008, 11:25 AM   #5
Info@PeddersUSA.com
Our Pedders Camaro development is coming right along. We are a the stage of almost doing a test fit. GM Racing has done it, but we have not done i with springs/struts and such. We have all the data on the coils and struts. We are hoping at delivery to be able to also have our 32 way adjustable coil overs ready at the Camaro launch.
We are also working on 2 unbelievable brake packages. Cannot discuss i yet. But if it works out, all of you will say wow to the first one, and quadruple wow to the second.
Last week, I had the opportunity to drive our Pedders G8 that has our Extreme Package on it, which is every bushing, multi adjustable sway bars, and adjustable coil overs, and also a Procharger. We are having custom wheels made and they are not in yet, along with a special brake package. Pete's G8, which is a ZETA platform just like the Camaro, handles unbelievably, plus with serious sporty comfort. Lets not forget the massive power increase with his Procharger, and custom tune.
So we are ready for Camaro and all who have interest in it. If you have any questions, just ask
thanks
mike
dms
Old 09-30-2008, 11:46 AM   #6
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
to do a full bushing install on a g8 how long does it take and what tools do you need? is it somethign i could do at home? if i had the tools?
headpunter is offline   Reply With Quote
Old 09-30-2008, 12:14 PM   #7
Info@PeddersUSA.com
Requires a 15-20 ton hydraulic press, a universal balljoint press, something to lower the rear cradle, hand tools to 24mm. For the differential bushings, we supply a custom tool for this.
If you want to see the process on a trackII install on a Zeta plaform, spend some time at my webshots site at:
mike
dms
A Message to all Fbody Enthusiasts TAG UR IT 5th Gen Camaro SS LS LT General Discussions 12 02-02-2013 07:41 PM
Why the Camaro is Doomed!! TFord 5th Gen Camaro SS LS LT General Discussions 140 01-16-2010 08:07 PM
Why do you think the Z28 is the higher tier? The_Blur Camaro ZL1 Forum - ZL1 Specific Topics 181 10-14-2009 08:08 PM
Pedders is Ready for Camaro!!! Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 10 04-15-2009 11:26 PM
Detroit News panel wants GM to build Camaro concept Tran 5th Gen Camaro SS LS LT General Discussions 12 03-15-2009 04:38 PM
