Old 01-19-2010, 03:26 PM   #1
Black LS3
Black LS3's Avatar
Drives: 2010 Black 2SS LS3
Thumbs up Is This A Good Price For Borla S-Type Axle Back & Magnaflow Tru-X 2.50" X-Pipe?
Hi everyone,...
I've been getting offers in my email a lot lately and I came upon this setup and was wondering if this was a good price for these two items.
1 x Magnaflow Tru-X X-Pipe 2.50 Inch.
1 x Borla S-Type Axle Back With Round Tips.
Total Price is $662.16 with Free Shipping.
I'd like to get a CAI while I'm shopping to get the discount on it as well but i'm still undecided as to which one to get still.
The Coupon code for AutoAnything for 10% Off Your Order Under $150 is PBEA3 or you have this Code for Orders over $150 EJA1018FAA
Let me know what you think about this price because the sale i think has been going on for a day already so i only have another day to think about it.
If I happen to not get the Axle Back and just go Straight Pipe, Borla sells a set of these Tips in a 4"x4" Outlet Size, 2.50" Inlet Size, 6" Length. Will these Fit out of the Exhaust Ports on the 2SS with out any problems?
Thanks guys.
Black LS3
A.K.A. Jim
OnlineAutorama.US - A Camaro Parts/Accessories Site for Dealers & Vendors.
Muffler Delete. ( See Videos - Vid 1. - Vid 2. )
Stock Resonators & H-Pipe Removed.
Magnaflow 2.50" Tru-X X-Pipe.
AirAid Cold Air Intake System.
11.21.09 1100 Order Accepted At Dealer - 11.24.09 2000 Accepted At GM - 11.25.09 2500 Preferenced - 12.03.09 3000 Production Control Notes: 01/11/2010 - 12.17.09 3400 Order Broadcast - 01.13.10 3800 Order Produced VIN # 2G1FT1E - 01.25.10 4000 Available to Ship from Rail Yard by Truck - 01.27.10 5000 Delivered to the Dealership - 01-27-10 6000 Delivered to Customer.
Black LS3 is offline   Reply With Quote
Old 01-19-2010, 03:33 PM   #2
Indpowr
Drives: Corvette C6
Call Titan, Ask for Bottle, I am sure they could do a better job on it. Tell him Jon Pine sent you
407-277-8423
Old 01-19-2010, 04:16 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
If you decide not to go with the Borla axle-back I would tell you to look into making a Magnaflow Comp series cat-back type system. Basically you'll use a Magnaflow #11386 X-pipe (it's a resonated x-pipe) and then do a muffler delete. You should be able to use a local muffler shop, supply the x-pipe, and get it all done in the $250 - $300 range. If for some reason it's still a little loud for your tastes you can always add some Magnaflow mufflers for about $140 + labor.
Take a look around post #89 on this thread:
http://www.camaro5.com/forums/showth...t=28047&page=4
Give Jordan a call to get your pricing.
This is basically what you'll be making. You can hear the sound clips on this page. http://www.magnaflow.com/02product/s...one=all&id=126
BTW: The price listed above is assuming you'll be using your factory exhaust tips.
Build Journal
Old 01-19-2010, 04:35 PM   #4
Black LS3
Black LS3's Avatar
407-277-8423
Okay Thanks Jon I will.
Thank You
If i cut the stock exhaust off and will I be able to use the Stock Tip again or No? Wont i have to buy new tips anyway or what?
That what i was thinking i had to do was buy new tips,.. I didnt think the stock tips off of the stock mufflers would be useable.
Jim
Old 01-19-2010, 05:12 PM   #5
caverman
caverman's Avatar
You can reuse the stock tips. I think there is about an inch or so of space between the back of the tip and the front of the actual muffler. Many have reused the tips already. So unless you specifically want after market tips then have the muffler shop cut off and reuse the factory tips. Locally I've found a shop to do the muffler for $80 and another for $96. Shop around and you'll find it in that range. The x-pipe will cost you about $95 and to install should be around $60-$80 for that.
Do a search on this forum for muffler delete. There are plenty of threads and almost everyone reuses their factory tips.
Build Journal
Old 01-19-2010, 08:12 PM   #6
Black LS3
Black LS3's Avatar
Man,.. Thats Great News about the Factory Tips. I wasnt sure how much room there was between the muffler and the tips for cutting.
Do you happen to have a close up picture of your Factory Tips Handy by chance that you could post up here so i can check them out pls?
Hmm,.. Now i dont know if i want to go with the Borla S-Type Axle Back & Magnaflow X-Pipe with Resonators Removed or save myself a Bunch of Money and just go with the Straight Pipes and Magnaflow X-Pipe with Resonators Removed.
Old 01-19-2010, 11:10 PM   #7
caverman
caverman's Avatar
Sorry....can't help you out with the picture of the factory tips since my car won't be her for another month or so but look around on the forum for muffler delete.
The aftermarket tips form the SLP LMI or Magnaflow Comp axle-back definately look better than factory but it's just a matter of how much money you want to spend. Right now I plan to go as cheap as I can for a little while because my long term plan is to install Long Tube headers and full 3" exhaust.
Here is the original muffler delet thread. This doesn't have the #11386 though but you can get an idea.
http://www.camaro5.com/forums/showthread.php?t=24815
Build Journal
Old 01-19-2010, 11:46 PM   #8
Hyp
I've been lost...
Hyp's Avatar
Drives: 2010 SW 2SS/RS W/IOM LSA Swap
check this site out i just found on another forum, they have some awesome prices!
http://performance-curve.com/exhaust.aspx
Hyp is offline   Reply With Quote
Old 01-20-2010, 02:48 AM   #9
Black LS3
Black LS3's Avatar
Thats okay about the Picture,.. Maybe someone else that'll pop in will have one for me.
As far as that thread goes,... Yeah i've got that in my Favorites already, Thats the Grandfather of them all, I've watched those videos several times, I tried to send him a tell to see what he did about his tips but his inbox is either full or he isnt accepting any P.M.'s .
Hey ya Hyp,...
Howsx it going?
I checked out that store and it seems like they dont carry exhaust for the 2010 Camaro's and I couldnt find any Intakes for it either, The Magnaflow X-Pipe they sell is the same price as it is at AutoAnything.
Do you know the guys who work there or something?
