Old 01-21-2010, 11:17 PM   #29
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Originally Posted by Qwkss View Post
I checked your site, where is the tool? How much?
the tools are custom made. We only sell them to our dealers. We tried "lending" some of our tools, but an extremely high % of them came back damaged or destroyed. So we do not do it any more
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 01-21-2010, 11:23 PM   #30
Info@PeddersUSA.com
Originally Posted by mtcwby View Post
I don't see the tool you used working on the Camaro. The diff bushings are in a steel cup, with a flange that interferes with your tool.
If you are so convinced that your tool works so well on the Camaro, send me one of the tools to test. If it works I'll definitely give you a super write up.
Even with the tool, no way it's only one hour. Takes half that long just to get the car up on stands and properly supported.
First of all, I do not have to prove it to any of you. We have done it many times. I only mentioned it because of the 8 hours The tool is used for the Camaro and G8. The Camaro might take about 5 minutes longer because of the flange has to be moved. But that is it. These tools are not mass produced and are custom made. We make no money on them so we do not want to sell them to everyone.
I am in travel mode the next 2 weeks. I have a Justice Package and a Track system to do on 2 Camaros locally. I will be taking a million pictures and documenting the builds. And from these pictures, will make or update a ton of install manual. I will be glad to post and do first the rear diff mount bushings, first so all of you that said it cannot work can be done or impossible can see how Pedders gets things done in an efficient manner.
mike
dms
mike
dms
Old 01-21-2010, 11:34 PM   #31
Mr Twisty
Mr Twisty's Avatar
-- Benjamin Franklin
Old 01-22-2010, 12:07 AM   #32
Qwkss
Qwkss's Avatar
Drives: Hoopty Winter Beater
mike
dms
Ok. Who is a Dealer in the Cincinnati area where I can buy one from??
mike
dms
mike
dms
I thought the guy was being sarcastic. Sounds like you are working too much overtime and need a break.
Qwkss is offline   Reply With Quote
Old 01-22-2010, 12:32 AM   #33
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
mike
dms
mike
dms
Yes, I can see the tool working IF you cut the flange off the oem bushing with a sawzall first, but your instructions (that you posted) did not say anything about cutting off the flange.
As far as 1 hour, never, unless you have 4 guys on it, that have done it before. It will take that long to get it up on stands and to remove the exhaust system. You are probably exaggerating the time to say it is easy. But guys on this forum that DIY don't want exaggerations. They want realistic times that can be achieved by the average guy in his garage, that has never done it before. Sure once you do a couple of them you can usually cut the time in half. But how many of us will ever do it more than once? So give us REAL times. Bring in someone that is mechanically inclined, give him some good directions(for the Camaro, not a G8), jack stands, floor jack, and normal hand tools and see how long it takes to do ONE kit. Not 2 kits or 3 kits. That will be a realistic install time.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 01-23-2010, 08:43 AM   #34
Mr Twisty
Mr Twisty's Avatar
Your posts do sound like you're trying to pick a fight. I believe he was talking to Aaron when he said it can be done in an hour, not you.
This is the type of job that really isn't a DIY, should be left to professionals unless you have the skills and tools to R&R bushings. If you do have the skill, then, yeah, the first one will probably take considerably longer than an hour.
Old 01-23-2010, 08:58 AM   #35
Info@PeddersUSA.com
I am the guy that writes the manuals and install sheets for Pedders. On most of the component install sheets that I have done, I have done them in my driveway, on jack stands, using my compressors, air guns and quality tools. I have done the subframe and diff mount bushings in my driveway 3-4 times and it is very easy. Have not done it in my driveway on a Camaro, but have done it in the shop. You do have to modify the steel jacket. With a air chisel, maybe 30 seconds to a minute per bushing of work is required.
I am also the one that has established the recommended labor times for our PEDDERS dealers. I program 1 hour of time into our systems for the diff mount bushings.
As a final note, I did not make these posts in any way to promote Pedders or to say Pedders is better parts than others. The point of my posts is to assist everyone, from Pfadt to the DIY guys in taking a job the the author of this forum spent 8 hours on, and Pfadt thinks it is a 5 hour job. I am not an engineer like Aaron. But I have very serious practical experiences, am a semi expert in finding procedures for auto repair to be more efficient. I also have a PHD in the "College of Hard Knocks" It absolutely blows me away that so many seem to be angry that I can get this done in a hour, maybe 1.5 for a first timer. If you do not want to believe me, that is OK. If you have specific questions on the install process, I would be glad to assist this community as I always have.
mike
dms
Old 01-23-2010, 09:24 AM   #36
IROCanSS
Drives: 89 IROC 350
I am glad someone else is taking care of this for me! Looks like a HUGE PITA!
Old 01-24-2010, 07:17 PM   #37
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
Actually enjoy doing most of the mods myself.... just not tackling the engine this time around. This work is more like playtime when working on your own car. Plus I get the satisfaction of saying "I did it". Besides, what's the fun of having a muscle car if your not going to "tinker" with it.
Can hardly wait for Pfadt coilover install & test drives!
LPE Brotherhood
Old 01-25-2010, 12:53 PM   #38
RichJ.
Shop Owner
Drives: 1 ton silverado
It generally takes us about an hour here in the shop.
RichJ. is offline   Reply With Quote
Old 01-25-2010, 01:00 PM   #39
RichJ.
Shop Owner
Thanks Blue70SS for the write up and pictures
Old 01-26-2010, 10:02 AM   #40
Blue70SS
Blue70SS's Avatar
All in fun ..... crazy how addictive these cars are!
LPE Brotherhood
Old 01-26-2010, 04:11 PM   #41
Qwkss
Qwkss's Avatar
mike
dms
First off, THANK YOU for the motivation. We looked around and could not find this tool you speak of. So we made our own. Worked great.
But you do have to cut one small piece of the old.
Then "fold" up the edge or knock it off.
Install tool.
Impact it.
VIOLA!! All three are gone.
Old 01-26-2010, 07:48 PM   #42
Cruz-lo
Drives: 2010 2ss RS
Well MY .02 as a DIY it took me 4 hours to get the factory bushings out after I removed the diff! I made a tool and then had to cut the flange of the steel jacket off too!
For me it was better to take everyting out of the car!! I think it is faster in the end.
Cruz-lo is offline   Reply With Quote
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 06-07-2011 12:09 PM
Pfadt Race Engineering releases new Camaro V8 Engine Mounts PfadtRacing Suspension / Brakes / Chassis 6 01-15-2010 12:58 PM
Pfadt Engine Mounts PfadtRacing Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 08-19-2009 02:54 PM
Pfadt Engine Mounts PfadtRacing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-19-2009 02:51 PM
Pfadt Engine Mounts PfadtRacing Forced Induction - V8 0 08-19-2009 01:39 PM
