| Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications. |
Thread Tools |
ZL1 lover-4-life
How does the rear bowtie emblem come off?
I bought some SS emblems so I can remove the bowtie emblem from the rear part of my car. I'm just wondering if it's held on with double sided tape or is it actually bolted on?
![]() Drives: 2010 Black SS Join Date: Sep 2009
Crowbar... >_>
Hair dryer for a minute and fishing line. |
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
#4 | |
![]() Drives: 2010 camaro Join Date: Jan 2010
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: RSSS Join Date: Dec 2009
#6 |
And for my next trick.......
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 T/A, 2010 2SS/RS, 2006 Z06 Join Date: Apr 2009
Another trick is to take the trunk liner out, and push on the posts from the backside with a long screwdriver. Works like a charm
#8 |
![]() Drives: All Blacked Out 2010 2LT Camaro Join Date: Dec 2009
You don't even need a tough wire either, I did it to mine with a just a single string of dental floss.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS - Black - GFX Join Date: Nov 2008
much easier with a putty knife
I managed to do it without scratching the paint.... the floss/wire thing just made me frustrated.
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @115°), LTs, VR CAI, Cutouts |
#10 |
It's a sickness!
Drives: 442 Join Date: Dec 2009
Use a sawing motion or a straight pull?
How hot does it need to be? |
#11 |
It's kind of a slight pressured sawing motion, angled from top to bottom and switched back a bit. The heat needs to be pretty hot, almost to where you can't touch it, I wear gloves to make sure that the wire dosen't cut my hands.....The wire I use is MIG wire right out of the welder because it is plentiful at the shop.
#12 |
Virologist in the making
Drives: 2010 VR SS/RS LS3 Join Date: Aug 2009
Has anyone tried applying goo-gone or some other paint safe adhesive remover behind the bowtie before removing it? Like apply some goo-gone where the bowtie meets the trunk and let it sit for a bit before applying heat. Maybe this can loosen up the tape more and make removing it a little easier?
6000, Delivered to the customer - 12/21/09 ![]() |
#13 |
![]() Drives: '88 Monte Carlo SS, '10 Camaro SS Join Date: Jan 2010
Anybody know if there is a post/hole underneath the factory SS badge in the corner of the trunklid? I wanted to remove it since installing the SLP "SS" in place of the factory bowtie; but didn't want to pull it until I was sure there are no holes underneath.
-Chris
'10 Camaro SS '88 Monte Carlo SS |
#14 |
![]() Drives: 2010 Camaro SS, 57 Nomad, 71 Camino Join Date: Jan 2010
Also ... if the original emblem has 2 posts (I assume to locate it, since they don't "hold it on"), do the aftermarket "SS" emblems also have posts to put it in the exact same location?
"DragonZ28" suggest pushing on the posts from inside the trunk, so I assume then they go straight thru the rear body panel ... So if the aftermarket "SS" emblem does not have posts, does it at least cover up the factory holes in the rear body panel? Sorry ... I haven't gotten my car yet, but I wanna make sure I'm ready when it does arrive ... |
| Thread Tools | |
| Setting up an IRS/Drivetrain for Drag Racing | Kyle2k | Suspension / Brakes / Chassis | 44 | 06-05-2010 09:17 PM |
| Prototype SLP Wheels, Hoods, RS Emblem, and Rear Spoiler. | KILLER74Z28 | Camaro Photos | Spyshots | Video | Media Gallery | 161 | 11-08-2009 11:24 AM |
| LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends. | LMPerformance | V8 Bolt-Ons & Tunes | 0 | 10-19-2009 01:44 PM |
| The Tom Henry Full Length Stripes, Rear Panel, Emblem Thread (new SS emblems) | TAG UR IT | Camaro Photos | Spyshots | Video | Media Gallery | 211 | 06-02-2009 07:05 PM |
| Zeta (Camaro/Commodore/G8) suspension details | Gatecrasher | Wheels and Tires Talk Sponsored by The Tire Rack | 66 | 04-16-2009 01:11 PM |
