sjm autoprod
Old 01-21-2010, 11:12 AM   #1
55Designs
Drives: 2010
Rattles from heat shields under the car. ANyone have this or has removed these?
My car is very tight and of course roads suck.
I recently got a rattle and buzz sounds like under the middle where the drive shaft is.
Its quite annoying. I cant get over how cheap the shields are. I think I may have ran over a larger twig that may have knocked it out of place.
Has anyone been annoyed with these and decided to just remove them?
This is the cause of the cold start buzzing most guys with exhaust systems hear as well.
55Designs is offline   Reply With Quote
Old 01-21-2010, 11:25 AM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I had issues when they installed the JBA Shorty headers. But they adjusted the exhaust and the issues stopped. In the meantime, I went under the car and "adjusted" the shields as best I could. You can either complain to the dealer and let them fix it, or just get under the car and do it yourself.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 01-21-2010, 02:37 PM   #3
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
I also fixed mine myself. Had to tighten a few of the nuts that hold them in place and also bend them up to keep the air from getting between them and the car.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 01-21-2010, 10:35 PM   #4
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Check and see if your exhaust pipes are rattling on the tunnel brace like mine were when I put on my 3 inch catback. May be that or like you said, the thin heat shield up in the tunnel.
http://www.camaro5.com/forums/showthread.php?t=61445
g-townmach is offline   Reply With Quote
Old 01-21-2010, 11:34 PM   #5
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Another thing you can try if nothing else works is to remove the shield and put some Dynamat on the side towards the car.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 01-21-2010, 11:45 PM   #6
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
You sir are correct. I'm a big believer in dynamat.
Old 01-22-2010, 02:31 PM   #7
55Designs
Drives: 2010
We tried adjusting them 5 times today, on and off the lift wasted so time and no luck. its the shield dead center above the center resonator.
I decided to just remove it and forget about it because its so flimsy and my car is so stiff it would eventually come back.
Old 01-22-2010, 04:40 PM   #8
ffrcobra_65
so removed the shield and the rattle is gone? thanks for the update.
Old 01-22-2010, 05:39 PM   #9
55Designs
Drives: 2010
Yep fixed
Old 05-13-2010, 02:02 PM   #10
rcracer78
rcracer78's Avatar
Drives: 2010 Camaro 2SS
I'm having the same problem and am considering removing the heat shield myself. Will this damage anything or raise the cab temprature? Dynomat would be nice.
rcracer78 is offline   Reply With Quote
Old 05-14-2010, 02:43 PM   #11
rcracer78
rcracer78's Avatar
ANYBODY?
Old 05-14-2010, 10:31 PM   #12
jrpxxii
jrpxxii's Avatar
Remove heat shield and there are several different types of heat tapes you install so you wont notice any change in cabin and get rid of shield.
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 01:04 AM
1st Car Show and meeting Al Oppenheiser! scrming 5th Gen Camaro SS LS LT General Discussions 44 08-17-2009 05:46 PM
09 Mustang GT and 09 Challenger R/T test drives CamaroSpike23 General Automotive + Other Cars Discussion 19 04-10-2009 05:27 PM
