BORLA
Old 01-21-2010, 12:21 PM   #1
DFS88
DFS88's Avatar
Drives: 2010 camaro ss2
Anybody heard of a fix for non RS HID headlights "not aftermarket" yet??
Just thought i would ask its been a couple of months im getting sick of looking at these $1300 GM replacements for my non RS 2SS. Before somebody says if you wanted RS lights you should have ordered it with the RS package, I bought mine off the lot as is i couldn't wait, saw it had to have it "Love at first sight" Thanks.
DFS88 is offline   Reply With Quote
Old 01-21-2010, 03:46 PM   #2
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
there was a post a month ago someone from the assembly came on and said no due to the relay switch on the ecm i do beleive.
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 01-21-2010, 07:35 PM   #3
DFS88
DFS88's Avatar
Thanks for your input. Anybody else hear anything?
Old 01-21-2010, 09:37 PM   #4
FutureCamaroOwner
FutureCamaroOwner's Avatar
Drives: White 1SS/Black Stripes
Sameone has done it but it was wired completly different. Dont remember the members name tho
FutureCamaroOwner is offline   Reply With Quote
Old 01-25-2010, 01:27 PM   #5
jrpxxii
jrpxxii's Avatar
Yes it has been accomplished. There a couple of options. The easiest way is to find the power wire of headlight and wire into the sidemarker light and then find the ground wire of headlight and ground it. Only problem is you can't just turn on the halos. The other solution is more technical and requires some wiring mods and relays. But it can be done.
Old 01-25-2010, 04:44 PM   #6
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
I put RS lights in our non-RS with the intention of troubleshooting the canbus issue, correcting it, and posting a DIY.
The good/bad news is we installed the headlights, plugged everything in and they worked normal with no flickering....
AACstyle is offline   Reply With Quote
Old 01-25-2010, 05:53 PM   #7
FutureCamaroOwner
Justin, you got it to work with no issues? Was it the same factory part?
Old 01-26-2010, 10:27 AM   #8
AACstyle
AACstyle's Avatar
We had a set of factory RS headlight housings that we installed into a non-RS Camaro here at AAC. The only problem that we ran into is with the Bi-Xenon high beam. The non-RS cuts power to the low beam when the high beam is activated, the Bi-Xenon RS high beam works by a magnet collapsing the cut-off shield in the projector when the high beam is engaged. Since the low beam power is cut when the high beam is now engaged you can clearly hear the shield retract but the light promptly cuts out.
There are several possible ways to correct this, we have just been busy as of late and since the high beam has yet to be needed it has not been much of a priority.
Old 01-26-2010, 11:56 AM   #9
ottobody
Drives: 2010 trans am/camaro
otto body customs does sell these RS OEM headlights for $1000 this includes ballasts bulbs and connectors PM if interested
ottobody is offline   Reply With Quote
Old 01-26-2010, 12:20 PM   #10
FutureCamaroOwner
Do you have pics?
Old 01-26-2010, 02:00 PM   #11
ottobody
i will post pictures in a little bit i gotta pull them off of my phone
Old 01-26-2010, 03:30 PM   #12
FutureCamaroOwner
Cool, looking forward to seeing those pics
Old 01-26-2010, 05:15 PM   #13
jrpxxii
jrpxxii's Avatar
I think Justins case is very rare as I replaced my original headlamps with RS and they didnt work, then I bought the entire RS wiring harness and light switch and only the Halos worked, no actual headlights. Took it to dealer and was told your BCM must have a specific code for HID lights to work. GM will not give out this code, which is insane. Anyway as I said above, there are other options to make them work, but I wouldn't count on being as lucky as Justin as others who have tried this had the same experience as me with them.
Old 01-26-2010, 08:39 PM   #14
FutureCamaroOwner
So you basically just need to find an additional power source for the headlights right. Can't be that hard?
RS package front headlights.. Stylish Cosmetics and Lighting Modification Discussions 12 12-22-2009 07:24 PM
Swap RS headlights with non RS headlights rallyyellow Cosmetics and Lighting Modification Discussions 14 10-09-2009 05:49 PM
RS headlights quality. i007spectre 5th Gen Camaro SS LS LT General Discussions 73 08-24-2009 02:49 PM
HID Bulbs for 2010 Camaro NON-PROJECTOR Headlights? meissen Cosmetics and Lighting Modification Discussions 32 07-30-2009 01:59 PM
HID Headlights, Rear Taillamps. jacob678 Cosmetics and Lighting Modification Discussions 14 06-07-2009 11:35 PM
