Old 08-21-2008, 08:16 PM   #1
SSNIGHTMARE
SSNIGHTMARE's Avatar
Drives: 2002 SS Camaro
engine listings
http://www.gmperformanceparts.com/_r...ineQRC2008.pdf
SSNIGHTMARE is offline   Reply With Quote
Old 08-21-2008, 08:33 PM   #2
camaro&T/A
Drives: '82 Z28 400SB
the Z28 should come with a carbed LS3!!! 515 HP sweet!!!
camaro&T/A is offline   Reply With Quote
Old 08-21-2008, 11:54 PM   #3
MajorTom
MajorTom's Avatar
Drives: 2005 Pontiac GTO
I like that it tells the weight of each engine. It's nice to know that LS motors are lighter than most other engines. Lighter than smaller displacement DOHC V8s so when people say "It doesn't put out a lot of power for being such a big engine." I always said displacement doesn't equal physical size. This'll be a good reference.
And the Carbed LS3 would be a step backwards in technology. Not to mention throttle response and lowend torque.
MajorTom is offline   Reply With Quote
Old 08-22-2008, 02:39 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
not necessarily.
you can get more power from a carbed motor and better mileage 9 times out of 10. however, it takes a crap ton of tuning and fine tuning and finer tuning and even finer tuning to get there. and all that tuning and whatnot costs money and isnt very efficient.
I piss excellence
and fart awesomeness
Old 08-22-2008, 04:34 PM   #5
Grape Ape
Drives: 96 Bronco w/ a 5 speed
not necessarily.
You can get more power and better mileage from non-emisions controled motor, but all else being equal injection beats carbs hands down.
Grape Ape is offline   Reply With Quote
Old 08-22-2008, 04:42 PM   #6
CamaroSpike23
Truth Enforcer
what about a throttle plate? best of both worlds...lol
I piss excellence
Old 08-22-2008, 09:36 PM   #7
gunslinger
Drives: 1998 Z28 M6
EFI has been proven through the years to produce a more constant (from VERY low temps and altitude to VERY high temps and altitude) and wide power band than an equivalent STREET carb setup.
The fact that the EFI injectors are now placed close to the valve also helps with fuel economy. Computers have also allowed EFI to instantly change tune for max power or max economy.
Carbs, however have shown that for max effort application, they are still effective. They make the same if not slightly more peak HP while allowing the air-fuel mixture more time to mix as it makes its way to the cylinder. Not to mention changing carbs is about ten times cheaper than changing EFI systems.
For racing, I don't think the carb will ever die, but on the street, I will take my EFI any day of the week!
gunslinger is offline   Reply With Quote
Old 08-23-2008, 10:20 AM   #8
CamaroSpike23
Truth Enforcer
i like both...
94Z-LT1=EFI
86RS-LS1=Carbd
I piss excellence
Old 08-23-2008, 12:43 PM   #9
MajorTom
MajorTom's Avatar
In my experience two engines with the same displacement, one carbed and one fuel-injected, the carbed one gets worse economy simply because it's a less precise method of injection. Fuel is wasted on the way to the combustion chamber.
And throttle response on the street is important and it's 9 times out of 10 going to be better with a fuel injected engine. And with electronic throttle, it's going to be better anyway because throttle tip-in is more progressive and measured and controlled. Just my experience owning a GTO and driving a few muscle cars.
I wouldn't want a carbed car. If I built a muscle car, I'd put an LS motor in it.
Old 08-23-2008, 04:41 PM   #10
Captainbob
Drives: 69 Z28, 71 vette,01 ZO6,GT500
mono blade throttle bodies
+1 I'm running about 800 hp/676 rwhp wiht a S/C of course but all due to A/F calibrations and a nice monoblade throttle body I'm able to get 20mpg+ on the hiway, and run 10 sec 1/4 miles.. Thats technology
Previous cars: 65 GTO, 69 Z28, 73 vette,
84 vette, 01 SS Camaro, 01 ZO6, 07 Shelby GT500.. 10.97 @ 128mph
1st in line for a new SS Camaro..
Hoping GM will do the right thing. Super charge the new SS.. So it will compete with the big dogs!
http://www.youtube.com/watch?v=rnevMoEut_E vs. ZO6
http://www.youtube.com/watch?v=V2l25Q5AHc4 10.97 run
http://www.youtube.com/watch?v=vML-dKHCcLg dyno vid
http://www.youtube.com/watch?v=yLtQEdfN-CA hole shot
Captainbob is offline   Reply With Quote
Old 08-23-2008, 05:12 PM   #11
BowtieGuy
Enlightened
BowtieGuy's Avatar
Drives: Nothing Currently
You're telling me that throttle response is better on an injected engine? I've never seen that. I don't understand how a physical throttle linkage (pedal down, throttle open) could be slower than computer controlled (pedal down, computer signal travel, throttle open). Sure, we're talking milliseconds here, but even then I don't see EFI being faster.
If you believe it is your right to speak freely no matter the content, relevance, or intelligence of statement, then it is my duty to the powers that be to set you straight.
People have to talk about something just to keep their voice boxes in working order. So they'll have good voice boxes in case there's ever anything really meaningful to say.
Kurt Vonnegut
BowtieGuy is offline   Reply With Quote
Old 08-23-2008, 05:18 PM   #12
CamaroSpike23
Truth Enforcer
i think he's meaning more towards the actual injection portion of fuel with carb'd vs efi
I piss excellence
Old 08-24-2008, 04:04 PM   #13
Jamestwilliams
junior member
Drives: Grand Am
fuel injection is simpler, no floats, no chambers, no swearing as all the little pieces fall on the floor.
Jamestwilliams is offline   Reply With Quote
Old 08-25-2008, 02:57 PM   #14
Grape Ape
The fuel injected motor’s advantage is that it can more closely track the amount (mass) of air entering the cylinders and increase the amount of fuel right away. Carbs suck at dealing with changes in load, the accelerator pump helps get it through tip in, but it is still kind of crude.
A drive by wire system might open the throttle a couple milliseconds late, but the more precise mixture control will more than compensate. Assuming of course that the ECM has a reasonably aggressive throttle map.
Turbocharge your way to efficiency.....and power! Mr. Wyndham Forced Induction - V8 20 07-06-2008 12:46 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
