Rick@Livernois
Old 02-15-2010, 09:00 AM   #57
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Awsome!
nak3dsnake is offline   Reply With Quote
Old 03-21-2011, 07:46 AM   #58
MyWorld
MyWorld's Avatar
Drives: RJT 2LT RS
I am bringing this post back from the Dead, but I wanted to confirm part numbers for the Rear Calipers and this seems like the best place to do it. This is what I am planning to do:
For the fronts Calipers I am going to buy a OEM Take-Off Front Brake Kit (Calipers, Rotors, Pads, Hoses, Shields) for $350 through SLP. I am buying it just for the Calipers though, maybe someone will be interested in front Rotors, Pads, Hoses, and Shields after I get the kit ???
Then I want to get a Front/Rear set of R1 Concepts Rotors (Dimple and Slotted), Hawk Ceramic Pads, and Stoptech Stainless Steel Brake Lines through r1concepts, who is a forum sponsor.
That leaves me with just the rear Calipers. I have seen people say that all you need is as follows:
92233177 Driver side rear disc brake caliper. Without pads.
92233176 Passenger side rear disc brake pad. Without pads
89047728 Rear Pin Kit (2 sets required)
But I am concerned other items may be required such as:
89047739 Rear Boot Kit (2 sets may be needed ???)
89047731 Rear Piston Kit (2 sets may be needed ???)
Does anyone know if those last two parts are needed?
MyWorld is offline   Reply With Quote
Old 03-21-2011, 08:20 AM   #59
nak3dsnake
nak3dsnake's Avatar
No, the last two parts are only needed if your rebuilding a rear caliper. Caliper should come ready to bolt on from the factory aside from pins and pads.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
Old 03-21-2011, 08:25 AM   #60
MyWorld
MyWorld's Avatar
Drives: RJT 2LT RS
Cool, Thanks!
Old 03-21-2011, 01:08 PM   #61
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Cool, Thanks!
You can get those pin kits a whole lot cheaper from OReilly auto parts website too. That's what I did. They come as a set for both rear calipers for the same price any GM parts house wanted for just one side.
[B]
Old 08-27-2012, 06:22 PM   #62
jonathanmoguel
MM.CC
jonathanmoguel's Avatar
Drives: 2010 Camaro 2SS LS3
how did u get the rotor off. i cant pull mine out . i took out that torx bolt.. it seems like its stuck or something..
jonathanmoguel is offline   Reply With Quote
Old 08-27-2012, 10:28 PM   #63
01pewterz28
Camaro Junkie
01pewterz28's Avatar
Drives: 2010 2LT/RS AKA ZLRS
You will need to work it back and forth you might need to use a pry bar to break them lose
Old 08-28-2012, 05:16 PM   #64
Chang
Chang's Avatar
Drives: 2010 Camaro V6 LLT Rally Yellow
Very nice to see a thread like this, since I will upgrade the breaks soon.
The Brembo GT costs $3500 for the front only, so i guess SS Brembo will be my choise.
Current mods: Flowmaster AMT Axle-back | RX Catch Can | RX Breather | Vararam DZ-6 Intake | Vmax CNC Ported Throttle Body | RX Ported Intake Manifold | Mace Plenum Spacer | Mace 25mm Insulator | BMR Level 3 Handling Kit | BBK Stainless LT header w/ HFC | Magnaflow Res. X-Pipe |
On the way: Trifecta Tune
Future mods: DONE!
Chang is offline   Reply With Quote
Old 08-30-2012, 08:34 AM   #65
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
good post, thanks
jeremywes is offline   Reply With Quote
Old 08-31-2012, 09:08 AM   #66
01pewterz28
Camaro Junkie
Glad it was helpful
Originally Posted by jeremywes View Post
good post, thanks
thanks
I can say everything has been going strong 55k miles later no issues
Old 05-11-2013, 02:17 PM   #67
AUS10BMX
AUS10BMX's Avatar
Drives: 2010 2LT RY, 2014 Silverado
Bringing this back to life, but a questions as I'm upgrading mine to a set of the 1LE Brembos.
Im gonna get a set of the Goodridge lines. V6 vs V8 lines with the connection points does everything line up and connect to the car fine when putting on the V8 lines?
Hypertech | Airaid | JBA Exhaust | RX Catch Can/CNC TB/Black Ice-Olator | Ported Intake/Heads | 1LE Brembos | F14's | RS Headlights | ZL1 Grille
AUS10BMX is offline   Reply With Quote
Old 05-11-2013, 04:01 PM   #68
CamaroDreams07
Drives: Slow V6
Yep
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 05-13-2013, 08:52 PM   #69
AUS10BMX
AUS10BMX's Avatar
Well, went ahead and got one step closer this afternoon since I had time. Trimmed the rear rotor shield, cleaned it up and knocked it down with some paint so it wouldn't have a bare edge.
Name:  Screen Shot 2013-05-13 at 8.43.53 PM.jpg
Now just waiting on the brakes.
Old 08-18-2013, 03:24 PM   #70
CamaroLS
CamaroLS's Avatar
Drives: 2014 Blue Ray Met. Camaro 1SS Vert
Thanks for the write up because I am getting ready to do the upgrade!!
CamaroLS is offline   Reply With Quote
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
Brembo Brakes ChevyBoiSS Wheels and Tires Talk Sponsored by The Tire Rack 15 02-03-2009 08:23 PM
What's written on the brembo brakes FUTURE TOP DOG OWNER 5th Gen Camaro SS LS LT General Discussions 19 09-19-2008 09:11 PM
Brembo brakes question topgun1 Wheels and Tires Talk Sponsored by The Tire Rack 20 09-04-2008 11:34 AM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
