Old 01-25-2010, 04:27 PM   #1
ROBBDOGG1986
Tampa Gulf Coast Family
ROBBDOGG1986's Avatar
Drives: 2010 CAMARO SS
I need some tips for getting a good run down the track!
NEVERMIND
BALLSS2 the Wall! :5thgenvert:
ROBBDOGG1986 is offline   Reply With Quote
Old 01-25-2010, 05:09 PM   #2
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
Here's the timeslips from my stock baseline runs. I hadn't been down the track in about 5 years.
The first run was with stabilization off / traction control on. (8.91 /13.524) The last run was in competition mode.(8.832 /13.501) The second race, I red lighted and missed second gear.
Here's a video of my screw up.
Your tip...... don't do this.
Last edited by Toyaholic; 01-25-2010 at 05:16 PM. Reason: OK....Having a problem with the YouTube link
Toyaholic is offline   Reply With Quote
Old 01-25-2010, 05:22 PM   #3
Toyaholic
It's a sickness!
Toyaholic's Avatar
I've heard, If you're running street tires....you want to spin the tires just enough to clean them.
Were your runs in Lakeland?
Old 01-25-2010, 06:36 PM   #4
ROBBDOGG1986
Ya I've been to Lakeland
Old 01-25-2010, 08:29 PM   #5
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
Drive it like u wanna break it. But with control.
THUMPER20X is offline   Reply With Quote
Old 01-25-2010, 08:33 PM   #6
hb35man
hb35man's Avatar
Drives: 2010 Camaro 1LT Aqua Blue Metallic
Practice,practice,practice..............practice being smooth and consistent.Never change more than one thing at a time.Sorry I'm not much help
hb35man is offline   Reply With Quote
Old 01-25-2010, 09:00 PM   #7
Toyaholic
It's a sickness!
Toyaholic's Avatar
I found this article on the basics of racing a stock vehicle.
http://www.albeedigital.com/supercou...racing102.html
Old 01-29-2010, 10:18 AM   #8
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
Always turn TC off and try 7 sec hold down to turn every thing off.
Hold gas pedal between 2500 and 3000, with street tires, and 3,000 and 3,500, with drag radials. Drive it out of hole, don't pop clutch and don't slip it. Same motion as driving off from a red light on street. If you smell it you slipped it too much. If it doesn't smell it is fine.
DO INSTALLl BMR Fabrication ($139.95) or Spohn trailing arms, worth .2 reduction in 60 foot stops most wheel hop (protects drive train) Best mod you can make and easy to do.
Light burn out with street tires. Drive around the water and back up almost to water box. Spin tires on wet pavement not in water. Water in treads of street tires will drip off on the starting line (bad). For M6 burn out hold gas pedal steady at 5,000 rpm entire time. Dump the clutch in second and lightly get on the brake. Allow vehicle to move forward slowly entire time and get off brake and drive out of tire spin. If rear end moves right steer right. move left steer left, while moving forward. The faster you move forward the straighter it will go. Get off gas if rear moves to far to the side.
Launch between 2,500 and 3,000, with street tires, and 3,000 and 4,000, with drag radials, depending on conditions. The goal is minimal wheel spin with no bog coming out of wheel spin. Roll into throttle as wheels stop spinning. If it bogs coming out of wheel spin, raise launch rpm 200 at a time and/or roll into throttle sooner or faster. With to much wheel spin roll in later or slower. Too much wheel spin and/or wheel hop, pedal throttle, let off half way to 2/3 and roll back in
Track surface must reach 50 to 55 degrees to hook very well.
Easiest to hold throttle steady and wait till wheel spin stops to roll into throttle but slower. You can raise or lower launch rpm holding pedal steady to prevent bog or too much spin, then roll into throttle after wheel spin stops. I need at least 3000 rpm after spin stops to roll in for best results. Push rev limiter for shifts but don't hit it. Stock limiter will cause throttle blade to close for a second or two just like letting off on the gas. This can be tuned out and still leave spark reduction on for rev limiter.
nuptualnemesis is offline   Reply With Quote
Old 01-29-2010, 12:35 PM   #9
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Hold gas pedal between 3,000 and 3,500 rpm. Drive it out of hole, don't pop clutch and don't slip it. Same motion as driving off from a red light on street.
Light burn out with street tires. Launch between 3,000 and 3,500 with minimal wheel spin and try to roll into throttle as wheels stop spinning. If it bogs coming out of wheel spin, roll into throttle sooner or faster. With to much wheel spin roll in later or slower.
Easiest to hold throttle steady and wait till wheel spins stops to roll into throttle but slower. You can raise or lower launch rpm holding pedal steady to prevent bog or too much spin, then roll into throttle after wheel spin stops. Need at least 3000 rpm to roll in after spin stops for best results. Push rev limiter for shifts but don't hit it.
Which one do you have and where can I get it?
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 01-29-2010, 01:04 PM   #10
CFPC_2010
VIN #3026 IOM/IO
CFPC_2010's Avatar
Drives: 2010 IOM Camaro
I have the BMR parts (go to http://www.bmrfabrication.com/F5.htm ) and it has made a huge difference in how the car launches. It was done as part of a tech article in the current GM High Tech magazine where you can see a side-by-side comparison with the stock part. The car's launch changed drastically, I never had issues with wheel hop but when it spun the car would head towards the wall. Now the car goes straight and launches much harder. Stock tires I run low 1.80 short times and on drag radials I hit low 1.70s. The car only has a converter and headers and runs 12.40s at 111 mph.
CFPC_2010 is offline   Reply With Quote
Old 01-29-2010, 05:47 PM   #11
nuptualnemesis
NuptualNemesis
I have BMR TA's. My mods are listed in my garage and dyno graphs in my photo album (click Nuptualnemesis on left and ind drop down menu click on View public profile then look on left for Photos Album) Thunderracing.com in BR can get you anything.
TIP: You can remove front sway bar end links to get better lift and weight transfer. I drive on street with out them but don’t corner quiet as hard.
Second Mod I recommend is a Spohn rear sway bar, it has 80%,120% and 170% stiffer than stock settings. ($149.00) Makes IRS act more like a solid rear end. The middle setting helped completely eliminate wheel hop with drag radials. Ran a best 1.675 sixty foot. Will try stiffest setting next time. Spohn says not to use stiffest setting on street, only for race. The sway bar also reduces under steer (put front end links back on to try it). Under steer better for inexperienced drivers. You have to power through or out of cornering skid without it. Can’t let off like with stock suspension because rear end will spin around instead of straightening out. I am not sure how much the rear sway helped because I had also switched from 20” Nitto’s to 295/45/17 MT ET Streets at same time but it feels a lot more solid and improved handling. You may not need a new front sway bar but I think the Spohn front end links ($95) may help. Bwoody sells just the front end links for I think $295.
TIP: Lighter rims and tires make dramatic improvement in performance. Less inertia to accelerate or stop. 1 lb reduction in reciprocating weight is like 4 lbs less sprung weight. Stock rims are boat anchors. I took off 40 lbs with 24 & 25 lb 20" racing rims and took .2 off my ET plus 2 mph.
Tip: Tirerack,com has cheap light weight 18” rims. Search under 2010 camaro LT. Must designate LT. They have 144 rims listed with 42 on special. When they get to three or less they go for $99 to get rid of them. I got 2-17x9 & 2-18x9 SSR 16lb rims for $396 ,regular $2400. Practically all 18" rims listed for Camaro LT will fit SS but one piece works better than 2 piece especially on 17's. Caliper clearance issue is back side of front of rim on 18's and top of caliper on 17's. Off set is 32-35 front and 40 rear. You can call and ask. They may even test fit them. I had to run a 3/8 spacer on the rear. Billet aluminum spacer from speedway.com $11.99 @. Longer wheel studs recommended. I also saved 10lb per front tire with smaller 27" diameter street not a racing skinny but streetable front tire. Match front and rear tire diameter for ABS. Pics in my photo album.
Old 01-30-2010, 08:57 PM   #12
SRT10KLLR
Need to get these ASAP. My best so far was 12.59 with headers, CAI and tune.
I have BMR TA's. My mods are listed in my garage and dyno graphs in my photo album (click on name over avatar and home page for photos) Thunderracing.com in BR can get you anything.
TIP: Track surface temperature needs to be 50 to 55 degrees to get good hook.
Second Mod I recommend is a Spohn rear sway bar, it has 80%,120% and 170% stiffer than stock settings. ($149.00) Makes IRS act more like a solid rear end. The middle setting helped completely eliminate wheel hop with drag radials. Ran a best 1.675 sixty foot. Will try stiffest setting next time. Spohn says not to use stiffest setting on street, only for race. The sway bar also reduces under steer (put front end links back on to try it). Under steer better for inexperienced drivers. You have to power through or out of cornering skid without it. Can’t let off like with stock suspension because rear end will spin around instead of straightening out. I am not sure how much the rear sway helped because I had also switched from 20” Nitto’s to 295/45/17 MT ET Streets at same time but it feels a lot more solid and improved handling. You may not need a new front sway bar but I think the Spohn front end links ($95) will help. Bwoody sells just the fron end links for I think $295.
I did not see trailing arms in your mod list in your "garage". I saw them listed in your mods in the 1/4 mile times though but I did not know what t-arm was at the time. Always wanted to ask just never did till now. I was trying to beat your time last time I went to the track but did not get enough runs because of a bracket racing competition going on.
I was thinking of going to the SMJ/Bogart 17" wheels then thought about the 18" Corvette Z06 wheels to save some money. You say that 17's will fit the 2SS?
Thanks, guys for the advice I will definitely be ordering the t-arm on Monday morning.
Old 01-31-2010, 07:42 AM   #13
BabyHauler
Drives: CGM 2SS/RS 6M
Anyone have any pics of the trailing arms installed?
Z06+Baby= 2010 2SS/RS 6M
BabyHauler is offline   Reply With Quote
Old 02-01-2010, 11:24 AM   #14
nuptualnemesis
NuptualNemesis
BMR TA's installed
Look on last page of this thread. http://www.camaro5.com/forums/showth...ght=BMR&page=4
It show comparison to stock and installed. The lower one in the photo is TA and upper is toe rod.
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
How well does the L99 SS Run? Scott@Bjorn3D 5th Gen Camaro SS LS LT General Discussions 57 07-08-2010 10:10 AM
Photos From the Recent Hotchkis Track Test Hotchkis Camaro Photos | Spyshots | Video | Media Gallery 12 01-20-2010 01:28 AM
Edmunds.com review of Holden Commodore... good info. LSxcellent General Automotive + Other Cars Discussion 6 07-23-2007 07:49 PM
