BeckyD@RodgersChevrolet
Old 08-24-2008, 05:50 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
new engine for the new camaro
ordered a new LS3 block and a 418ci stroker rotation assy and a set of cnc ported L92/LS3 heads to build a new engine and have it ready to drop in when my L99 auto camaro comes in.
ill post up some pics when they show up
Old 08-24-2008, 05:52 PM   #2
The_Blur
Rock Chalk
The_Blur's Avatar
Drives: Demon Super Sport
We already have our first 2010 Camaro project. What are you going to do with the L99?
Old 08-24-2008, 05:56 PM   #3
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
sweet
TFord is offline   Reply With Quote
Old 08-24-2008, 06:36 PM   #4
JEFF2010SSMANUAL
JEFF2010SSMANUAL
JEFF2010SSMANUAL's Avatar
Drives: IOM 2SS/RS LS3
COOL $$$$$$$
JEFF2010SSMANUAL is offline   Reply With Quote
Old 08-24-2008, 06:48 PM   #5
camaro1
camaro1's Avatar
ill keep it wrapped up in storage for a while,,
Old 08-24-2008, 08:01 PM   #6
smike07
smike07's Avatar
Drives: 1998 convertible Camaro RS
I'm officially jealous!
smike07 is offline   Reply With Quote
Old 08-24-2008, 08:09 PM   #7
Cessna510
Gm loyalist
Cessna510's Avatar
Drives: 04 z71 tahoe\99 SS m6
how much did that run you, if you don't mind me asking. I'd like to put an LS7 in a 5th gen with some LT's and an X-pipe....i'd get happy pants every time i drove it.
Cessna510 is offline   Reply With Quote
Old 08-24-2008, 08:11 PM   #8
o2camaross
o2camaross's Avatar
Drives: 2010 2SS/RS & 04 silvy
sweet, whos building it? Are you sticking with N/A?
o2camaross is offline   Reply With Quote
Old 08-24-2008, 08:55 PM   #9
camaro1
camaro1's Avatar
im building it, well besides from the machine work/balancing
new gm LS3 block $1300
stroker kit, crank, rods, pistons, bearings (4.080 bore, 4" stroke) $1700
cnc ported LS3/L92 heads with valves and .660" springs $1600
machine work, balancing, boring/honing, setup $500
then the small stuff, camshaft, lifters, timing chain, oil pump, bolts, gaskets-$1000
Old 08-24-2008, 09:23 PM   #10
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Little over 6 grand huh. Bench dyno, what do you think the numbers will be?
Old 08-24-2008, 10:09 PM   #11
camaro1
camaro1's Avatar
550+ hp easy
Old 08-24-2008, 10:16 PM   #12
GTAHVIT
Blessed
GTAHVIT's Avatar
550 at the Crank?
Do you know what the Compression Ratio will end up at?
Sounds sweet.
Old 08-25-2008, 02:07 AM   #13
HOT LS3
HOT LS3's Avatar
Drives: Chevrolet
Very nice! Everyday I am researching performance mods for my future Camaro. Just stumbled upon the MP2300 Supercharger which is the same one being used in the ZR1's LS9 engine. Also been tossing around the idea of an LS7 for the '427' effect. Lots of options and plenty of time to contemplate them.
HOT LS3 is offline   Reply With Quote
Old 08-25-2008, 05:17 AM   #14
Cessna510
Gm loyalist
Cessna510's Avatar
Hmmmm sounds like a great deal since your doing the assembly! Getting ready to build a house, but man i'd like to be able to buy an SS and make it sick right off the bat.
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 12:14 PM
AW: New Camaro a one trick pony? Scotsman 5th Gen Camaro SS LS LT General Discussions 16 09-04-2008 09:07 PM
The Camaro team at GM seeks answers ChrisL 5th Gen Camaro SS LS LT General Discussions 148 08-28-2008 08:47 PM
Camaro Chat 9:30-10:00 jdpickering 5th Gen Camaro SS LS LT General Discussions 25 07-22-2008 02:11 PM
