Old 09-21-2011, 01:51 PM   #141
William.23
William.23's Avatar
Drives: 2011 Summit White.
Originally Posted by Txbatman View Post
245/45 fronts, 275/40 rears are stock. You're going to have more trouble finding tires than anything else. I'm going to save the stock rims for snow tires, and order a set of Forgestar F14's in gunmetal for my summer tires. I plan on going with 275/40 on 9" rims for the front and 305/30 on 11" in the rear.
So what your saying for the Front 20x8 and Rear 20x9 would be this?
http://www.tirerack.com/tires/tires....omCompare1=yes
But then that wouldn't match be two different sets of tires making it look weird O_o
William.23 is offline   Reply With Quote
Old 10-25-2011, 03:11 PM   #142
heavytdt
Drives: 2011 2SS/RS
Originally Posted by Speed74SS View Post
It is ok to run 10" tires front and back. It is not recommended as far as the rim size and tires, as they are just outside the range for 10" rims for both 275's and 315's. However, this is the exact set up I am running with the Nitto NT05's and it works for me. My car is lowered about 1.5" also. I did buy these rims to run 285's all around but couldn't find any tires in that size that I wanted to run. I think you may run into rubbing issues running a 305 up front.
I am getting 20x10s for all four with an offset of +35 and will be mounting 275/40z. should work? ill get different tires later but for now this is what i got to work with. is there any problem i am not seeing? i did try to create a new thread for the question but i dont have privalidges for that yet i guess haha
heavytdt is offline   Reply With Quote
Old 11-30-2011, 07:48 PM   #143
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
I have this wheel the Bravado Americana 20x9.5 on all corners I would like to go a little wider than 245/45/20 and still remain within the 3% tolerance that is recommended on 1010 tires website.Can anyone that has knowledge of this little problem and could possibly recommend a tire size that will keep me within that 3% range.
I am not interested in what you are running and this or that will work but a definite answer from a tire guru.Sorry guys I am not being rude but I am having surgery next week and would love to get this sorted out because I will not be able to drive my car for about 4 weeks.
Ohten is offline   Reply With Quote
Old 12-07-2011, 10:26 PM   #144
kavya23
Drives: 2010 Camaro 2SS
Hey i have a 2010 2SS and i just put my first set of winter wheels and tires on it...i went down from the stock 245/45 20s and 275/40 20s to 295/45/19 on all fours is that ok? because the list on the first page has 295/40/19 recommended..will it have any problems?
kavya23 is offline   Reply With Quote
Old 12-09-2011, 09:31 AM   #145
T_MECO
T_MECO's Avatar
Drives: 2013 SS/RS 1LE
What the cheapest set of tires you can get for 21" OEM wheels
T_MECO is offline   Reply With Quote
Old 01-02-2012, 04:35 PM   #146
hawaiianboy
Drives: 2010 Camaro 2SS/RS SIM
Hello everyone, Did anyone change their stock tires on their 2SS and replaced them with wider tires on stock wheels? If so what size tires did you go with?
hawaiianboy is offline   Reply With Quote
Old 01-03-2012, 07:05 PM   #147
PC HOTROD
PC HOTROD's Avatar
Drives: 2010 Camaro SS IOM 6M
Just order the Continental ExtremeContact DW's from www.TireRack.com. Rev'd the rears today and waiting on the fronts. $1050 for the set.
Front Pirelli ($454) - 245 / 40 / 21 (28.6" tall by 9.5" Section width)
Rear Pirelli ($521)- 275 / 35 / 21 (28.6" tall x 10.8" Section width)
Continental Front ($197) 245 / 35 / 21 (27.8" tall x 9.8" Section width)
Continental Rear ($223) - 295 / 30 / 21 (28.0" tall x 11.9" Section width)
www.MotoDivaz.com
2010 Camaro SS IOM
PC HOTROD is offline   Reply With Quote
Old 01-03-2012, 07:23 PM   #148
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
Check these out... I love mine in 20". These tires ROCK!
http://www.tirerack.com/tires/tires....10XL&tab=Sizes
Beauwulf is offline   Reply With Quote
Old 01-03-2012, 07:38 PM   #149
Beauwulf
Beauwulf's Avatar
Originally Posted by PC HOTROD View Post
The fronts only come in 21's, not the rears.
285/30 works on the rear too... it's a healthy size tire that still fits the OEM 21 width... what's not to like?
Old 01-03-2012, 07:43 PM   #150
Beauwulf
Beauwulf's Avatar
Are you speaking of 20" or 21" Wheels/Tires?
I have the Hankooks on mine in 20" but I was referring to the link which is for 21s.
Old 01-12-2012, 06:53 PM   #151
echavez555
Drives: 2012 white camaro LS
HELP!!!
I have a 2012 camaro LS. Im debating on getting 20's or 22's. 22's look better in my opinion. I live in San Diego CA so the weather here is perfect, never have to worry about snow or anything like that. I would like to get them staggered but im wondering if tires are going to be super expensive. Im only 20 years old so I am on a budget.
pros and cons on 22's?
should I go with staggered or go same size all around to stay within my budget?
any other thoughts? THANKS!
echavez555 is offline   Reply With Quote
Old 01-12-2012, 08:54 PM   #152
kobSS
kobSS's Avatar
Drives: 2010 2SS/RS
Originally Posted by echavez555 View Post
HELP!!!
tires for 22's are more expensive. There are a lot of factors that affect the exact price like wheel size, and how much tire wall you want. I just picked up a set of 22's and the tires are 1400.
20" rims are cheaper, and for the most part, so are the tires. It all comes down to the look you want within your budget. I've seen some pretty good aggressive looks on some cars sitting on 20's. If your going for Auto-X or drag/DD, then your best performance option would be 20's. If your looking for showing the car, then 22's, IMO would be best. I dont plan on doing drag or auto-x till i can put more money into performance, so i went with 22's
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers
"Information is the oxygen of the modern age"
Build Thread
kobSS is offline   Reply With Quote
Old 01-12-2012, 10:10 PM   #153
echavez555
Cool thanks man!!! Any suggestions on what kind of tires I need? I think I'm going with 22's. Don't need all weather. Just rain and sunny days.
Old 01-13-2012, 09:12 PM   #154
Toyaholic
It's a sickness!
Toyaholic's Avatar
Drives: '69 442 Vert
Went to the pirelli site today and they are not listing the 315's any more!
Toyaholic is offline   Reply With Quote
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
