| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
#51 |
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
What about the offset? I thought I read 32 F and 46R... does that sound right?
#52 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
#53 |
Thanks... Ya know, I scrolled through that a coupla times and missed that twice! Good thing it wasn't a snake! LOL!
#54 |
![]() Drives: 2010 Black Camaro 2SS/RS Join Date: Nov 2009
guys I want to put 315/35/20 on rear and 27/l40/20 on front and with factory wheels so would be any problems or just fine and no need to do any thing? the tires are nitto nt05
or 305/35/20 on rear and 275/40/20 on front with factory wheels and the tires are nitto nt555r please tell me which one is better nt05 or nt555r |
#55 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2011 Camaro SS Join Date: Oct 2008
Somebody didn't read the original post.
![]() Recommended tire sizes based on wheel widths are what this post is about. Short answer, NO I wouldn't recommend those widths for factory wheels.
#56 |
![]() Drives: 2010 Camaro 2SS/RS LS3 Join Date: Apr 2010
may i bug you . . i want to get new wheels. How wide can i go front and rear and big tires. how big can i go stock without rubbing?
#57 |
2$$
Drives: 94 ss, 2008 gxp, soon to be2011 2ss Join Date: Apr 2010
GREAT INFO...THANKS
burn rubber & write your name in the street
#58 |
![]() Drives: 2010 Black Camaro SS/RS MTX Join Date: Jun 2010
Will a 22x10 rim fit on a 315/25-22 tire?
#59 | |
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
What would happen....Safety wise....to big...won't fit...handling will be worst.....Rub against fender...Offset.....??? Thanks
Member of 'Club Elite' #70
2LT/RS Auto /Solo HFC/Solo Mach X-LLT J-Pipe/JBA Headers Shorty/CAI - Cold Air Inductions /PowerAid TB Spacer / VMAX TB / Trifecta Tune /Hotchkis Max Strut Brace/ Blade Dovetail Spoiler / ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / T1 Led Light Kit |
#60 |
![]() Drives: 2010 Camaro RS/SS Inferno Orange Join Date: Dec 2009
Wheel & tires
I have A 2010 RS/SS I have lowered the car 1" front & rear.
Will the lowering affect the size of tire a want to use 165/40/20 on 8.5 front rims and 305/35/20 on 10.5 rear rims. Thanks Bernie |
#61 |
![]() Drives: 1SS Summit White Join Date: Jun 2010
I have to admit that I need some of this rocket science training also.
Is there a formula to choosing the right combination of wheel and tire? |
#62 |
![]() ![]() Drives: 10 LT2/RS-08 SILVERADO-05 COBALT Join Date: Jun 2009
When replacing rear tires. It is good to remember that the new tire diameter when change your final gear ratio.Here is the math. New tire dia divided by the old tire dia times the current gear ratio equals the new gera ratio. 30.7 divided by 28.7 equals 1.07 Times 3.42 equals 3.66 new gear ratio.
Retired |
#63 |
![]() Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
Would there be a problem putting 10" wide wheels on all 4 corners, but having 275 tires on the front and 305 or 315 on the rear? Would the different tire sizes contribute to understeer alleged to occur with staggered wheel/tire sizes? In the alternative, with the 20" X 10" wheels on all four would running 305's all around cause problems up front? Secondly, would a car lowered with coilovers be affected any differently than a stock suspension?
Mods: Pedders Xa's, bushings, braided brake lines, Solution B sway bars, Hawk ceramic pads, Spohn trailing arms, Kooks 1 7/8 LT's, HF cats, Magnaflow 3" cat-back, MBRP rec tips, Cold Air Inductions black CAI, MGW short-throw shifter w/retro shift ball, Showstopper Engine Bling, Forgeline MD3P's 9.5 & 11", Conti DWS 275's & 315's. AAC plasma DRL's.
Proud previous owner of: 1968 327 Camaro, 1972 Camaro SS 350, 1978 Z28, 1979 Z28. 2010 SS is My 5th Camaro |
#64 | |
![]() ![]() ![]() ![]() ![]() Drives: 2010 LPE 650+ CTS-V Join Date: Oct 2008
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI |
#65 |
Darrell W
spare
Just bought a 2010 1ss; Can I get a rim and tire that will fit the trunk space and the car itself/ I was told to get a 20.7 rim and 245/20 tire can't find such a rim
dwmanuel@yahoo.com |
#66 |
![]() Drives: 5th Gen Rental Join Date: Aug 2007
the Pedders Camaro is running a Tire 305/30/19. the diameter is 26.20 inches. This changes the rear gear ratio from a 2.42 to a overall of 3.73
This works seriously well mike
Rob Anderson - Business Development
rob@peddersusa.com |
#67 | |
![]() Drives: 1SS/RS/M6-White/Beige Join Date: Jul 2009
The stock SS has 3.27 gears for the auto and 3.45 for the manual - right? The tire size changes should produce an 26.2/28.66 or .914 factor. So I am not following or getting the point you are making. Would you clarify? Thanks. Edit --> Mike I think I figured this out, believe you have a typo. Your tire changes should be like changing gears in auto to a 3.57 and the manual to a 3.77; correct me if I am in error.
#68 |
305/30R19
The Pedders Camaro has proven to be off the charts fast on the track with RE11 Bridgestones. But we elected to go smaller on the tires.
The Pedders Camaro is running 305/30R19s, which are a 26.2in diameter tire front and rear. This has proven to be seriously successful! for multiple reason. Just wanted to throw this numnber out into the discussion mike
#69 |
![]() Drives: Navigator/Corvette/2010 Camaro Join Date: Aug 2008
When departing from 20 inch rims, a popular combination and being on the wide side seems to be:
Pirelli Tire 315/25-22 back and 265/30-22 front These calculate to a 3.15 sidewall front and rear What are people thoughts to this combination? Pirelli Tire 315/25-22 back and 285/30-21 front With these fronts, the sidewall increases to 3.4 (about ¼ inch more) It may not be much, but I’m wanting a bit more in the front for our winter pothole season, plus it provides at least .6 inch more tread in the front for extra grip. The fronts will be .4 shorter than the rears, which I belive is withing the margin. Anyone run such a combo? Any thoughts? I’d consider 20’s in front and 21s rear is someone made those sizes within thin the same tire model. (Looks like any decent wheel is a custom size anyway, so might as well match to the tire size I want.)
***56K miles and still going strong*** 2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM Gary Custom Z vented fenders. Vararam ver 2 |
#70 |
Bump
#71 |
![]() Drives: 2010 2ss black with silver stripes Join Date: Jul 2010
Can anyone tell me what the bolt pattern is on the ss 20' wheels? 5-lugs ???mm ??inches?
K/N cai, borla "s" type catback, XSPOWER 1 7/8" LT headers, Jannetty tuned, blacked out bowties, aac abl dome/trunk led's, matching footwells. custom dash plaque, Hurst Harddrive shifter plate, and e-brake boot, custom SS kickplates ![]() ![]() |
#72 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS V6 Join Date: Jul 2010
will rim fit
i was told these will fit the camaro ls. i dont know if there trying to sell me and just say it fits but i have asked numerous rims vendors and they state it will.
the rims bolt pattern is 22x9.5 5x120.65 offset of 35. from what i was told this .65 will not matter in fitting it on my car and that the 5 lug drill hole is slightly bigger than a normal 5x120! my thing is will this actually fit and what size tire would i get? i was looking at 265/30/r22 OR the 285/30/r22. help me peoples. plus i would get all the mirrored/gray part painted white to match my white ls Last edited by zkdreads; 01-12-2012 at 09:20 PM. |
#73 |
Guys, you are better off creating new posts in the normal forum about particular wheels and tires. This thread is meant to be more of an informative resource, on proper (recommended) tire sizes. Some of your tire size questions would be answered if you just read the original post. It gives recommended tire widths for all wheel width ranges.
#74 |
376 cubic inches of fun
I notice that the stock tires on the SS are exactly the same diameter front and rear.
Does the traction and stability control system get confused if the front and rear tires are different diameters? Thanks. |
#75 |
@jbadd
Drives: Black 2011 ls camaro Join Date: Nov 2010
So I ordered a set of the 20' midnight silver wheels and they just came in today...3 of them all say P275/40R20 and one of them says P245/40R20 .will this cause any damage when I put them on ??? What should I do ??? Help
| Thread Tools | |
| CAMARO WIKI | Tran | Wiki | 42 | 05-18-2013 09:32 AM |
| Drag Racing Suspension Kits | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 25 | 02-21-2010 08:48 PM |
| The Camaro, what it has come to mean for me | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 23 | 04-13-2009 09:31 PM |
| Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
