Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 02-01-2011, 02:22 PM   #76
justonemic
@jbadd
justonemic's Avatar
Drives: Black 2011 ls camaro
So I ordered a set of the 20' midnight silver wheels and they just came in today...3 of them all say P275/40R20 ! And one of them say P245/40R20 .will this cause any damage when I put them on ??? What should I do ?? Help
justonemic is offline   Reply With Quote
Old 02-01-2011, 06:09 PM   #77
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
i wouldn't put it on cause then you won't be able to return it. I would return the different sizes so the tire sizes will be equal on each side.
chopss is offline   Reply With Quote
Old 02-01-2011, 06:49 PM   #78
LoneStarCamaro
LoneStarCamaro's Avatar
Drives: 2011 IOM Camaro
I would check the sizes of the wheels! You might have three 20x9's and one 20x8.
LoneStarCamaro is offline   Reply With Quote
Old 02-02-2011, 08:41 AM   #79
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2011 Camaro SS
Originally Posted by Rock-It Man View Post
I notice that the stock tires on the SS are exactly the same diameter front and rear.
Does the traction and stability control system get confused if the front and rear tires are different diameters?
Thanks.
Yes, different height front and rear tires could mess up these systems:
Anti-Lock braking system
Traction & stability control system
But, only if the tires are much different in height. We try to maintain at least 0.5" between the heights, just to be safe.
www.DV8Motoring.com - Forged Wheels & Customs
Email: Tony@DV8Motoring.com
Old 02-07-2011, 05:56 PM   #80
justonemic
@jbadd
justonemic's Avatar
finally got the correct tire. thanx guys
Old 02-09-2011, 11:48 PM   #81
bigwayne3000
Drives: 2011 Camaro LS
Will running 10.5" in the rear significantly lower my MPG?
bigwayne3000 is offline   Reply With Quote
Old 02-10-2011, 12:56 AM   #82
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I still get 28 mpg on the freeway with my 22x11 rears.
"J, you're my favorite Pokemod" ~Revo1
Old 02-16-2011, 02:49 PM   #83
metalemt
Urban Ninja
metalemt's Avatar
Drives: 2SS/RS CGM A6
Alright I need help from the masters, using the stock 20x8 and 20x9.
Looking at Nitto NT05 or Invo's will these work.
NT05
F- 255/45/20
R- 315/35/20 (prefer)
R- 275/40/20
Invo
F- 255/45/20
R- 305/25/20 (prefer but noticed height is way lower)
R- 295/35/20
any thoughts.
metalemt is offline   Reply With Quote
Old 02-16-2011, 03:00 PM   #84
Nine Ball
Nine Ball's Avatar
metalemt, 255 works on the 8" fronts, but I'd not go any wider than 275 on the rear 9" wheels. Even the factory 275 tires are on the wider side for a 9" wheel. 295 will fit, but it will bulge some.
Old 02-16-2011, 03:43 PM   #85
metalemt
Urban Ninja
metalemt's Avatar
Awesome thanks
Old 02-16-2011, 06:05 PM   #86
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
I personally think the 20 profile would be a mistake. I used 30 on the rear with a 35 front. It works very well! Plus, you have to keep the tire diameters within 5% front to rear to keep the stabilitrack computer happy! That means using at least a 25 on the front (with a 20 rear) or you'll get a light.
I gotta put in a plug for the tires I'm using. The Hankook Ventus V12s are excellent tires and they cost about 1/2 of the Nitto Invos and were rated higher by Car and Driver and a couple of Euro mags as well! The NT05s are probably a bit better but you'll burn them up twice as fast so the cost of the Hankooks is even better! Check them out on Tire Rack. Oh.... 20 profile and these big wheel wells looks bad IMHO too!
This is a 285/30/20 0n a 10" wheel. They do have a 275/35/20 in the Ventus
Front is a 255/35/20 which should fit the stock wheel. Mines on a 9" wheel.
Beauwulf is offline   Reply With Quote
Old 02-16-2011, 08:37 PM   #87
Nine Ball
Nine Ball's Avatar
Beauwulf, the Hankooks are a good tire. I'd say your tire height is too short for my taste though, it leaves a huge wheel gap when you run a shorter than OEM tire. If anything, I prefer to push towards 29" tall to fill up the gaps and get a better ride quality. The shorter tire also puts phantom mileage on your odometer and makes the speedo read higher than it should. For low-mileage weekend cars or track cars, no biggie though.
Old 02-16-2011, 08:49 PM   #88
Beauwulf
Beauwulf's Avatar
I chose these for TD tires mostly. I wanted the gearing advantage (3.27 up to about 3.42) and the stiffer sidewall these afford. The speedo error is 3 MPH at 70... added to the oem error of 2 MPH so, indicated 80=75.
Now, this is a "huge" wheel gap! LOL!
Old 02-17-2011, 04:26 AM   #89
Fat_Tire_Custom
Drives: 1972 Rally Sport, 2010 RS/SS
Location: the Pacific Northwest 3300 07/20/2009 3800 7/27/09
I would measure the wheel widths. You may have gotten three 9" rear wheels and one 8" front wheel.
Fat_Tire_Custom is offline   Reply With Quote
Old 02-17-2011, 04:57 AM   #90
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
Hey NINE BALL are you going to stock the new Weld wheels 17 in. wheels that just came out. I would like a set for the rear in 11 in. dia.
thanks
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline   Reply With Quote
Old 02-17-2011, 05:14 AM   #91
bob vogel
Drives: 2010 rs ss
looks great. make sure you keep a eye on the sidewalls on these hankooks.
bob vogel is offline   Reply With Quote
Old 02-17-2011, 03:46 PM   #92
Fat_Tire_Custom
Has anyone found replacement tires from anyone other than Pirelli PZeros to fit stock 20 x8 fronts and 20 x 9 Rears? I don't mind going a little wider on rear or all tires, and I don't mind going a little lower profile than stock, but I am having no luck finding any combinations that meet my personal requirements which are:
1) American tire manufacturer;
2) Sidewall height in back should be same or a little taller than front sidewall heights for aesthetic reasons;
3) Rears should be an inch or so wider than fronts for aesthetic reasons;
4) ABS and Traction Control may get confused if the front and rear diameters are too much different;
5) Tires should be same brand and preferably same model front and rear.
Very few of the 20" tire manufacturers offer enough assortment to end up with that "just right" look for width and height and front and rear. I'm just curious what non-OEM tire brands and sizes members have installed successfully with no ABS / traction control warnings.
Old 02-19-2011, 12:06 PM   #93
Fat_Tire_Custom
What's the widest tire that anyone is successfully running on their stock 20" wheels? I'm looking at Vredestein's 275/40/20's on front (I've seen several members running 275/40's on front successfully) and 315/35/20 on back. This setup retains stock sidewall height and stock tire oustside diameter to keep ABS, traction control and speedo calibration happy, and the price is pretty good. Width is 1.5" wider in back and 1.2" wider in front. It looks like there is adequate clearance inboarda nd outboard of front and back tires to run this combo. Has anyone tried this setup yet?
Old 02-20-2011, 11:07 AM   #94
Nine Ball
Nine Ball's Avatar
Just because you can force a tire to fit a wheel, that doesn't make it a proper (or safe) fit. The factory wheels are already pretty narrow, and those 9.0" wide rears are already on the narrow side for 275 OEM tires already. I'd personally not go wider than a 295 tire on the rear, 265 on the front. The guys running 275 tires up front are also using another pair of rear 20x9 wheels up front. They are a direct fit, front and rear.
Old 02-20-2011, 07:50 PM   #95
Habib
Habib's Avatar
Drives: 2011 Camaro 2SS
Thanks man!!!!!!!
Habib is offline   Reply With Quote
Old 03-05-2011, 11:46 PM   #96
Hollywood2
Drives: 2010 Black Camaro LS
What bolt size it used on the ls and ss? I keep seeing different options and I need to know which one to pick!
Hollywood2 is offline   Reply With Quote
Old 03-06-2011, 01:07 AM   #97
Hollywood2
Trying to find this answer so I hope someone here can answer. Will a stock ls tire fit on an 18x8 wheel? I know the stock pos is 18x7.5 so would it really be that noticable as far as looks and what affects would it have?
Old 03-07-2011, 01:24 AM   #98
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
does anyone have a pic of a 275/40/20 tire on a 10in wide rim
camaro4mybday is offline   Reply With Quote
Old 03-10-2011, 07:27 PM   #99
bumbletee
Drives: 2010 camaro 2ss
i have changed my rims to foose legends 20 by 10's rear and 20 by 8.5's fronts what are your recommened sizes (biggest)
bumbletee is offline   Reply With Quote
Old 03-11-2011, 12:02 PM   #100
melody301
NY Football Giants YAY!!!
melody301's Avatar
Drives: 2011 LS
I'm a little slow when it comes to all this so I just need quick clarification. I see that the recommended rim size on a 275/40R20 tire is 20x9-9.5 but does this mean I can't put that same tire on a 20x10" rim? What problems if any might I run into?
melody301 is offline   Reply With Quote
CAMARO WIKI Tran Wiki 43 06-05-2013 04:54 PM
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 09:31 PM
