Old 05-27-2010, 12:02 AM   #57
SSinatra Andretti
2$$
SSinatra Andretti's Avatar
Drives: 94 ss, 2008 gxp, soon to be2011 2ss
GREAT INFO...THANKS
burn rubber & write your name in the street
SSinatra Andretti is offline   Reply With Quote
Old 07-03-2010, 12:10 AM   #58
GuidosCamaroSS
Drives: 2010 Black Camaro SS/RS MTX
Will a 22x10 rim fit on a 315/25-22 tire?
GuidosCamaroSS is offline   Reply With Quote
Old 07-03-2010, 09:06 AM   #59
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Originally Posted by Nine Ball View Post
Somebody didn't read the original post.
Recommended tire sizes based on wheel widths are what this post is about. Short answer, NO I wouldn't recommend those widths for factory wheels.
305/35/20 on rear and 275/40/20 on front with factory wheels
What would happen....Safety wise....to big...won't fit...handling will be worst.....Rub against fender...Offset.....???
Thanks
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 07-05-2010, 02:19 PM   #60
Bernie Hover
Drives: 2010 Camaro RS/SS Inferno Orange
Wheel & tires
I have A 2010 RS/SS I have lowered the car 1" front & rear.
Will the lowering affect the size of tire a want to use 165/40/20 on 8.5 front rims and 305/35/20 on 10.5 rear rims.
Thanks
Bernie
Bernie Hover is offline   Reply With Quote
Old 07-10-2010, 07:14 PM   #61
Transfusion
Transfusion's Avatar
Drives: 1SS Summit White
I have to admit that I need some of this rocket science training also.
Is there a formula to choosing the right combination of wheel and tire?
Transfusion is offline   Reply With Quote
Old 07-12-2010, 06:35 PM   #62
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Cool
When replacing rear tires. It is good to remember that the new tire diameter when change your final gear ratio.
Here is the math. New tire dia divided by the old tire dia times the current gear ratio equals the new gera ratio.
30.7 divided by 28.7 equals 1.07 Times 3.42 equals 3.66 new gear ratio.
Retired
cowboy1948 is offline   Reply With Quote
Old 07-13-2010, 05:44 PM   #63
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Would there be a problem putting 10" wide wheels on all 4 corners, but having 275 tires on the front and 305 or 315 on the rear? Would the different tire sizes contribute to understeer alleged to occur with staggered wheel/tire sizes? In the alternative, with the 20" X 10" wheels on all four would running 305's all around cause problems up front? Secondly, would a car lowered with coilovers be affected any differently than a stock suspension?
Meh
My 5th is offline   Reply With Quote
Old 07-13-2010, 09:42 PM   #64
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
It is ok to run 10" tires front and back. It is not recommended as far as the rim size and tires, as they are just outside the range for 10" rims for both 275's and 315's. However, this is the exact set up I am running with the Nitto NT05's and it works for me. My car is lowered about 1.5" also. I did buy these rims to run 285's all around but couldn't find any tires in that size that I wanted to run. I think you may run into rubbing issues running a 305 up front.
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline   Reply With Quote
Old 07-15-2010, 06:00 PM   #65
dwmanuel
Darrell W
Drives: 1 SS Cyber gray
Send a message via Yahoo to dwmanuel
spare
Just bought a 2010 1ss; Can I get a rim and tire that will fit the trunk space and the car itself/ I was told to get a 20.7 rim and 245/20 tire can't find such a rim
dwmanuel@yahoo.com
dwmanuel is offline   Reply With Quote
Old 07-15-2010, 11:15 PM   #66
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
the Pedders Camaro is running a Tire 305/30/19. the diameter is 26.20 inches. This changes the rear gear ratio from a 2.42 to a overall of 3.73
This works seriously well
mike
Info@PeddersUSA.com is offline   Reply With Quote
Old 07-16-2010, 10:13 AM   #67
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
mike
Wow Mike, your post is confusing me.
The stock SS has 3.27 gears for the auto and 3.45 for the manual - right?
The tire size changes should produce an 26.2/28.66 or .914 factor.
So I am not following or getting the point you are making.
Would you clarify?
Thanks.
Edit --> Mike I think I figured this out, believe you have a typo.
Your tire changes should be like changing gears in auto to a 3.57 and the manual to a 3.77; correct me if I am in error.
edneyens is offline   Reply With Quote
Old 07-30-2010, 12:24 AM   #68
Info@PeddersUSA.com
305/30R19
The Pedders Camaro has proven to be off the charts fast on the track with RE11 Bridgestones. But we elected to go smaller on the tires.
The Pedders Camaro is running 305/30R19s, which are a 26.2in diameter tire front and rear. This has proven to be seriously successful! for multiple reason.
Just wanted to throw this numnber out into the discussion
mike
Old 08-29-2010, 09:45 AM   #69
PatrickfromMD
PatrickfromMD's Avatar
Drives: Navigator/Corvette/2010 Camaro
When departing from 20 inch rims, a popular combination and being on the wide side seems to be:
Pirelli Tire 315/25-22 back and 265/30-22 front
These calculate to a 3.15 sidewall front and rear
What are people thoughts to this combination?
Pirelli Tire 315/25-22 back and 285/30-21 front
With these fronts, the sidewall increases to 3.4 (about inch more)
It may not be much, but Im wanting a bit more in the front for our winter pothole season, plus it provides at least .6 inch more tread in the front for extra grip.
The fronts will be .4 shorter than the rears, which I belive is withing the margin.
Anyone run such a combo?
Any thoughts?
Id consider 20s in front and 21s rear is someone made those sizes within thin the same tire model.
(Looks like any decent wheel is a custom size anyway, so might as well match to the tire size I want.)
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
Old 08-30-2010, 05:07 PM   #70
PatrickfromMD
Bump
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
