Old 09-03-2010, 09:54 AM   #71
gatorlover
gatorlover's Avatar
Drives: 2013 AGM 1SS/RS 1LE
Can anyone tell me what the bolt pattern is on the ss 20' wheels? 5-lugs ???mm ??inches?
2013 Ashen Grey Metallic 1SS/1LE, NPP, Camera
(1 of 43 produced)
gatorlover is offline   Reply With Quote
Old 09-08-2010, 07:00 PM   #72
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
will rim fit
i was told these will fit the camaro ls. i dont know if there trying to sell me and just say it fits but i have asked numerous rims vendors and they state it will.
the rims bolt pattern is 22x9.5 5x120.65 offset of 35. from what i was told this .65 will not matter in fitting it on my car and that the 5 lug drill hole is slightly bigger than a normal 5x120!
my thing is will this actually fit and what size tire would i get?
i was looking at 265/30/r22 OR the 285/30/r22. help me peoples. plus i would get all the mirrored/gray part painted white to match my white ls
zkdreads is offline   Reply With Quote
Old 09-09-2010, 09:57 AM   #73
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Guys, you are better off creating new posts in the normal forum about particular wheels and tires. This thread is meant to be more of an informative resource, on proper (recommended) tire sizes. Some of your tire size questions would be answered if you just read the original post. It gives recommended tire widths for all wheel width ranges.
Fquick.com/NineBall
Old 12-07-2010, 03:46 PM   #74
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2010 Camaro 2SS A6
I notice that the stock tires on the SS are exactly the same diameter front and rear.
Does the traction and stability control system get confused if the front and rear tires are different diameters?
Thanks.
Rock-It Man is offline   Reply With Quote
Old 02-01-2011, 03:20 PM   #75
justonemic
@jbadd
justonemic's Avatar
Drives: Red 2016 Corvette Stingray 2LZ
So I ordered a set of the 20' midnight silver wheels and they just came in today...3 of them all say P275/40R20 and one of them says P245/40R20 .will this cause any damage when I put them on ??? What should I do ??? Help
justonemic is offline   Reply With Quote
Old 02-01-2011, 03:22 PM   #76
justonemic
@jbadd
justonemic's Avatar
So I ordered a set of the 20' midnight silver wheels and they just came in today...3 of them all say P275/40R20 ! And one of them say P245/40R20 .will this cause any damage when I put them on ??? What should I do ?? Help
Old 02-01-2011, 07:09 PM   #77
chopss
chopss's Avatar
Drives: 04 sentra, 2ss
i wouldn't put it on cause then you won't be able to return it. I would return the different sizes so the tire sizes will be equal on each side.
chopss is offline   Reply With Quote
Old 02-01-2011, 07:49 PM   #78
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
I would check the sizes of the wheels! You might have three 20x9's and one 20x8.
LoneStar is offline   Reply With Quote
Old 02-02-2011, 09:41 AM   #79
Nine Ball
Nine Ball's Avatar
Thanks.
Yes, different height front and rear tires could mess up these systems:
Anti-Lock braking system
Traction & stability control system
But, only if the tires are much different in height. We try to maintain at least 0.5" between the heights, just to be safe.
Fquick.com/NineBall
Old 02-07-2011, 06:56 PM   #80
justonemic
@jbadd
justonemic's Avatar
finally got the correct tire. thanx guys
Old 02-10-2011, 12:48 AM   #81
bigwayne3000
Drives: 2011 Camaro LS
Will running 10.5" in the rear significantly lower my MPG?
bigwayne3000 is offline   Reply With Quote
Old 02-10-2011, 01:56 AM   #82
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
I still get 28 mpg on the freeway with my 22x11 rears.
Old 02-16-2011, 03:49 PM   #83
metalemt
Urban Ninja
metalemt's Avatar
Drives: 2SS/RS CGM A6
Alright I need help from the masters, using the stock 20x8 and 20x9.
Looking at Nitto NT05 or Invo's will these work.
NT05
F- 255/45/20
R- 315/35/20 (prefer)
R- 275/40/20
Invo
F- 255/45/20
R- 305/25/20 (prefer but noticed height is way lower)
R- 295/35/20
any thoughts.
metalemt is offline   Reply With Quote
Old 02-16-2011, 04:00 PM   #84
Nine Ball
Nine Ball's Avatar
metalemt, 255 works on the 8" fronts, but I'd not go any wider than 275 on the rear 9" wheels. Even the factory 275 tires are on the wider side for a 9" wheel. 295 will fit, but it will bulge some.
Fquick.com/NineBall
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
The Camaro, what it has come to mean for me Number 3 5th Gen Camaro SS LS LT General Discussions 23 04-13-2009 10:31 PM
