Old 01-28-2010, 01:48 PM   #1
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Pfadt new Strut Tower Brace release information
Hey everyone, GREAT NEWS!
These are NOW AVAILABLE! and ready to ship!
As always, we pride ourselves on providing you with the best performing products that have extensive engineering analysis behind them. Building on our great Camaro product line up, we have yet another offering that exemplifies this, and is now available. The new Pfadt Strut Tower Brace. This strut brace is a "no compromises design" that straddles both front strut towers entirely and leaves absolutely no room for flex in any direction! We took this approach to give as many people as possible what we know is the best solution. The Pfadt Strut Tower Brace also allows future upgrades to the front suspension, like Adjustable Camber Plates and Coilovers and has been fully designed and engineered in CAD to provide a strong, efficient, easy to install, lightweight solution. It comes with the correct installation tool necessary for a tight install to the chassis. Please take a look below! PM for price, while we work on adding it to our website!
A couple of notes about this brace:
-4 point chassis brace to reduce strut tower deflection under hard cornering/braking
-Weighs 8 pounds
-Very easy install, no need to remove strut
-Two versions, one for stock NA engines (available NOW), and one for Magna Charger (production batch to come later)
-Designed and made in the USA!
-Available bare or powdercoated Satin Flecked Charcoal (+$25)
Old 01-28-2010, 01:53 PM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
On the phone now!! Man I hate hold....
EDIT: Just found out that this is gonna require drilling two holes in the car! Don't think I wanna do that....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-28-2010, 02:29 PM   #3
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
I see 2 problems,
It won't work with a Vortech supercharger and you will
have to remove the brace to be able to check the power steering fluid.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 01-28-2010, 02:50 PM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
umm im not drilling holes in my car!
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 01-28-2010, 03:31 PM   #5
PfadtRacing
Hey everyone, just a little more info on this. This piece was designed to install with rivnuts. Rivnuts are a very common fastener used throughout the OEM GM chassis. This is just another point where they can be used to benefit the chassis strength. We did this for a number of reasons. One is because straddling the strut tower on either side creates a very strong relationship between both the left and right strut towers. The second is that there is really no existing holes to bolt to. The third is because we didn't want to potentially interfere with aftermarket coilovers etc, and bolt through the top near the OEM strut top.
We understand the hesitation to drill holes in your chassis. Not everyone will be comfortable with using a drill to properly install this Strut Tower Brace. But please take into consideration that there are no structural risks you are taking. You are doing quite the opposite. This is a common practice used in OEM manufacturing and motorsport chassis engineering.
Originally Posted by mtcwby View Post
I see 2 problems,
EDIT: To check the power steering fluid level you will need to remove the 4 bolts (not the chassis fasteners) from the brace. This process should take less than a minute. I can see how this may be unclear in the pictures.
We have been in talks with supercharger manufactures to get preliminary CAD packaging for us to use to determine if this brace will clear. This is never an easy process. Unfortunately, we can not predict what supercharger systems will be designed/used with the new Camaro and if they will reroute the intake system or not. We can only hope that they accommodate strut tower braces. Until we receive CAD data, or have a car in our shop that has a specific supercharger already installed, we will just have to wait to confirm fitment. Thank you for your patience.
We appreciate all of the feedback! Please keep it coming
Old 01-28-2010, 04:14 PM   #6
hypurone
hypurone's Avatar
Not questioning your design method.
And it's not that I'm not comfortable using a drill (I have 30+ years wrenching on cars, 20 of those paid!). I am just not gonna drill holes in the body of my car!
Not to mention a starting point for corrosion....
Old 01-28-2010, 05:13 PM   #7
mtcwby
mtcwby's Avatar
Originally Posted by PfadtRacing View Post
You can check the power steering fluid level just fine with this brace installed. I can see how this may be unclear in the pictures. Rest assured, we did not overlook this.
So, there's enough clearance to remove the engine cover under the brace.
It sure doesn't look like it.
If you need some detailed pics of the Vortech installed, PM me and I'll email them to you. Thanks.
Old 01-28-2010, 10:55 PM   #8
55Designs
Drives: 2010
Post some close ups on the mounting points. Is there a special tool included for the install?
55Designs is offline   Reply With Quote
Old 01-29-2010, 11:20 AM   #9
PfadtRacing
Ill see if we can get more pics up soon. And yes, there is a tool required, and supplied by us for the installation. Very easy to work with.
We pride ourselves on producing properly engineered, completely functional products that arn't gimmicks. This strut brace for the Camaro is no exception. As a result of this, if you want to install this brace, you will need to be comfortable and familiar with some basic fabrication techniques. There is no other way around it if you want a functional strut tower brace. Since GM did not provide needless rivnuts in these areas, we install them for our product to be truly functional. The rivnuts will cover any exposed sheet metal, just like the OEM ones on your Camaro. If you are still worried about corrosion, I think you can brush on some touch up paint before installing the rivnuts, and that should take care of any added concern. This will be a quality OEM fastening, for a serious chassis stiffening component. Four bolts, and its back off again. Rivnut fasteners remain in place.
Ill keep adding info as necessary. We are excited to get this product out there to you guys who are interested in performance handling!
Old 01-29-2010, 11:41 AM   #10
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
Looking forward to installing one of these on our Project Cammedmaro! It will look amazing in our engine bay, and really help stiffen up the car at the track.
/Erik
Erik@Torq is offline   Reply With Quote
Old 01-29-2010, 05:51 PM   #11
nl12
Drives: Unicycle
Do want!
nl12 is offline   Reply With Quote
Old 02-03-2010, 05:06 PM   #12
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
three questions;
- will this fit on the v6 model as well?
- when will this be available?
- pricing guideline?
Thanks
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 02-03-2010, 06:56 PM   #13
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
Aaron where is mine? I have been waiting on this along with many others for my race car. Seems the boys over here in the NASA southeast circuit are getting worried of the camaro. Here is a photo from Sebring last month. Check out the Pfadt decals on the car. Love the sways and waiting patiently on the tower brace.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 02-04-2010, 01:56 PM   #14
PfadtRacing
/Erik
Originally Posted by nl12 View Post
Do want!
Thanks for the kind comments guys!
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
PFADT - Drop springs & Balance bars (Pics inside) CRUSHER2SS Suspension / Brakes / Chassis 12 01-05-2010 10:12 AM
Strut Tower Brace stovt001 5th Gen Camaro SS LS LT General Discussions 10 12-27-2008 11:27 PM
important information (from the GM release) littlecammi Camaro Price | Ordering | Tracking | Dealers Discussions 5 10-12-2008 11:13 AM
Release Date Information ProCamaross Camaro Price | Ordering | Tracking | Dealers Discussions 6 04-25-2008 04:09 AM
