Ron@Vengeance
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 01-29-2010, 12:15 PM   #1
kellyjrt
kellyjrt's Avatar
Drives: 2010 CAMARO"s ABM & Synergy Green
Removal of rear diffuser on v6
Does anyone know if you can remove the rear diffuser on a v6 without taking off the entire rear fascia? We won't to take it off to get it painted or replaced.
kellyjrt is offline   Reply With Quote
Old 01-29-2010, 02:39 PM   #2
CleanCutCreations
CleanCutCreations's Avatar
Drives: 2010 camaro
I have always done it with the bumper off. The rear bumper comes off in about 10 minutes. After you remove the covers over the taillights in the trunk jamb and unplug the wiring, there are only about 6 screws holding it on in the wheelwells, the rest just push clips tight on the 1/4s and the rear body, no big deal. I guess you could get the diffuser off with the bumper still on. You can see most of the clips around the diffuser if you just poke your head underneath. The clips that hold it on are very weak and prone to breaking. Be careful. The ones along the top edge will be the hardest to get out without damage.
CleanCutCreations is offline   Reply With Quote
Old 02-01-2010, 07:19 AM   #3
kellyjrt
kellyjrt's Avatar
Yea, your right. I'd rather not risk the damage. I will just remove the whole bumper. After what you explained it seems pretty easy for the most part..your car looks great, thanks for the information.
Old 02-03-2010, 12:10 PM   #4
kellyjrt
kellyjrt's Avatar
could it be done if the muffler and pipes were removed first?
Drag Racing Suspension Kits Info@PeddersUSA.com Suspension / Chassis / Brakes 25 02-21-2010 08:48 PM
RAZZI REAR GROUND EFFECTS FOR V6 !!!!! orange10s.c. Exterior Parts & Accessories 15 12-27-2009 01:09 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 01:49 PM
Help!!! Hearing a Strange Noises from rear end of V6 6 speed Bigred1981 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 10-17-2009 11:18 AM
Rear Diffuser TJ91 5th Gen Camaro SS LS LT General Discussions 3 08-04-2009 12:56 PM
