Gen5DIY
Old 02-01-2010, 12:42 PM   #43
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by BMR guy View Post
It doesn't seem right but the gap is normal. You should have about 1/4" on both sides. If the other side is flush it's just because the strut mount hasn't seated in the strut tower yet. Putting the weight back on the suspension and turning the wheels or bouncing the car will seat it. The gap is designed into it for turning. To see what I mean try this. Once you put the car back on the ground, start it and turn the wheels lock-to-lock. You will notice that the upper strut washers "rock" side-to-side and the gap closes on one side. When the wheels are straight the gap goes back to normal. The washers are designed for strut retention but require this gap due to the suspension design.
Thee was no gap when I took them off.
Old 02-01-2010, 01:09 PM   #44
PQ
Booooosted.
PQ's Avatar
Ok. Just called Pfadt and was told that this gap is mormal. I've been freaking out. I guess I just don't understand why the gap changed from none, to what I have now.
Old 02-01-2010, 01:15 PM   #45
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
so why has it changed to what u have now?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 02-01-2010, 01:21 PM   #46
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
You may have remembered it when the suspension was hanging. With the suspension unloaded, there is no gap. Loaded, the strut is fully seated and the washers will have the gap.
BMR guy is offline   Reply With Quote
Old 02-01-2010, 02:00 PM   #47
PQ
Booooosted.
PQ's Avatar
I had allready lifted it.
The guys at Pfadt said that the retainer washer is only there to keep the strut from falling out when the car is lifted and the suspension drop.
I do feel kinda like an idiot.
Exactly correct.
I talked to Scott and he went out to his to look and there was the same gap.
Old 02-01-2010, 03:54 PM   #48
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
No biggie, the first time I saw it I thought something was screwed up too!
Old 02-01-2010, 04:16 PM   #49
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Take it for a spin yet???
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 02-01-2010, 05:13 PM   #50
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Post some pics when you get done too!
g-townmach is offline   Reply With Quote
Old 02-01-2010, 05:41 PM   #51
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 02-01-2010, 06:30 PM   #52
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
This has been quite an experience. My hats off to you. I'm not sure how many would have the balls to do this with no experience. Very nice!!!
Old 02-01-2010, 07:41 PM   #53
Alain
Alain's Avatar
Drives: 2010 SS, RS, Manual. 2012 F150, FX4
where are the pics dude
Alain is offline   Reply With Quote
Old 02-01-2010, 08:08 PM   #54
FFPM73
Firefighter/Paramedic
FFPM73's Avatar
Drives: RJT 2SS/RS M6 LS-3
I just put on the Eibach Pro Kit. I had the car jacked up on 4 stands just until the front tire left the ground. The rear springs and sway bar is a breeze. Keep in mind YOU DO NOT HAVE TO REMOVE EXHAUST. I'm sure it will make it easier but I had my new springs and sway bar installed in less than 2 hours including removing the old stuff and clean up.
Now, the front. YOU DO NOT NEED TO JACK THE ENGINE UP!!! Again, it may make it a little easier, however, I had the new springs and sway bar in in less than 2 hours including removal of the old stuff and clean up. TRICK: the front sway bar, remove totally the front end links which will make snaking the old/new bar easier. The way I did it was I snaked the bar out the passenger side and and the new one in the same way. Be sure to tork all strut bolts front and rear as well as front/rear end links with vehicle on the ground. The back are easy to get to but the front you have to turn the wheel to reach strut bolts and end links. It's not rocket science, you'll figure it out.
FFPM73
FFPM73 is offline   Reply With Quote
Old 02-01-2010, 08:26 PM   #55
PQ
Booooosted.
PQ's Avatar
Not a good one. Just around the block. Gotta get it aligned.
Originally Posted by Ject View Post
Tomorrow. My camera cord is at the office.
.umm told ya so..lol..ok no more emergency texts about your suspension okay...lol
Ok, so a freaked out a little.
I torqued them whit it up. Should I break them loose and re-torque?
Old 02-01-2010, 10:32 PM   #56
caverman
caverman's Avatar
Drives: '69 SS Convertible
I wouldn't think you would need to break them loose. I would just re-torque them.
Build Journal
Eibach Sways and Springs! In Stock! JSC Speed Suspension / Chassis / Brakes 53 11-22-2010 03:48 PM
Pfadt springs and sways installed rhunley14 Suspension / Brakes / Chassis 18 01-27-2010 09:44 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 10:09 PM
Pfadt GROUP BUY! Springs / Sways / Mounts IPS Brandon Suspension / Chassis / Brakes 18 11-23-2009 03:46 PM
Seeking Ohio Camaro owners for near Free Pfadt Springs/ Sways Install!ASAP IPS Brandon USA - Great Lakes 0 11-05-2009 11:50 AM
