Solo Performance
Old 02-01-2010, 11:00 PM   #57
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Originally Posted by caverman View Post
I wouldn't think you would need to break them loose. I would just re-torque them.
Surely they wouldn't have loosened up?
If so, I'll just do it, but they seem ok. Rear link thread shafts are a little angled but should be fine.
Old 02-01-2010, 11:45 PM   #58
Steve1968LS2
Drives: 1968 LS2 powered - Bad Penny
Originally Posted by comm54 View Post
CAUTION.....
The front sway bar may require lifting the engine to get it into place. You should be able to remove and install the rear bar pretty easily, Good Luck
No way..
If the stock front bar gives you too much trouble coming out just cut it in half..
The rest is so easy it's scary... heck, we didn't even need a spring compressor..
Tech Editor for Camaro Performers Magazine
1968 Camaro - 461 RHS LS 700hp, various stuff, called Bad Penny
1968 Camaro - In progress, called Track Rat
2010 Camaro - DSE Suspension, Baer 6S Brakes, Boze Wheels, Nitto NT05 Tires, JBA Exhaust and long tubes, Magnacharger TVS, 660rwhp Forged Eagle 416 LS3 short block, ADM fuel system, Lingenfelter GT-9 cam, G-Force axles, Anvil and Seibon CF parts, Centerforce Dual-Disc Clutch
www.fquick.com/steve1968ls2
Steve1968LS2 is offline   Reply With Quote
Old 02-01-2010, 11:56 PM   #59
PQ
Booooosted.
PQ's Avatar
Originally Posted by Steve1968LS2 View Post
No way..
I thought about cutting it after I took the bushings off to get it out. I was afraid I woudn't be able to get the other one in.
Old 02-01-2010, 11:59 PM   #60
Steve1968LS2
The new one is easier since the pads are seperate from the bar unlike the stocker..
It was a bitch, but we did it. This was on a two post lift. I was told that unhooking a steering arm helps.
It does go in, but you have to manuver it just right.. and cuss a lot, it seemed to help. lol
Old 02-02-2010, 12:06 AM   #61
PQ
Booooosted.
PQ's Avatar
Ya, cussing was helpful. Of course promted the common 'Shouldn't you just pay someone to do it' comment from Bonnie. (And the kids )
But I pryed the pads from the bar under the car. I was laying on the ground using jackstands.
Old 02-02-2010, 09:29 PM   #62
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Torque specs right here.
http://www.pfadtracing.com/blog/wp-c...structions.pdf
I'm gonna do it in the cold.
These are for the sway bars, I just have the springs to change..thanks anyway..
Old 02-02-2010, 09:42 PM   #63
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
The way that I do the front bars is this:
1. Disconnect the front radius rod bolts and have the radius rod hang down
2. Disconnect the tie rod ends from the knuckle
3. Disconnect the D mounts and bushings and end links
4. Pull out from the right side and rotate the sway bar as you pull it out.
took me about 30 seconds to remove, and about 1 minute to put back in.
thanks
mike
dms
Info@PeddersUSA.com is offline   Reply With Quote
Old 02-02-2010, 10:08 PM   #64
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 02-02-2010, 10:19 PM   #65
Jay_LHD3
Jay_LHD3's Avatar
Drives: 2017 Fiesta ST
Originally Posted by Ject View Post
+1
Jay_LHD3 is offline   Reply With Quote
Old 02-03-2010, 02:28 AM   #66
PQ
Booooosted.
PQ's Avatar
Oh, crap sorry. Here.
http://www.pfadtracing.com/blog/wp-c...stallation.pdf
thanks
mike
dms
Makes perfect sense.
I got stuborn. I did 3 and 4.
Originally Posted by jfaber99 View Post
+1
It's in the paint shop. I'll get some good ones shortly. Also it's getting aligned.
Got a 14 minute video too.
Old 02-03-2010, 06:42 AM   #67
Ject
aka Patrick
Ject's Avatar
Huh, Paint Shop? Do I dare ask what is getting painted? Exhaust bearings ?
Old 02-03-2010, 12:52 PM   #68
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
Cool.
The sway bars arent' covered though. I wonder if this is why D1BADZ didn't do his front yet?
All the shops I talked to that said they'd look into it and call me back (which is only 3) never called back.
Kinda yes, LOL, Ill be ordering the front soon though.
O....M....G....!!!!!!!!!
Front sway bar was a PITA!!!!!!!!
Got it out but had to take a few hoses loose. Luckily not a brake line.
IT'S TIGHT!!!!!!!!!!!!!
haha thats what everyones been saying, started to rain on me once i finshed up the rear so wouldnt have had time when i installed mine anyways.
Sure am glad u got it though.
Ok. Just called Pfadt and was told that this gap is mormal. I've been freaking out. I guess I just don't understand why the gap changed from none, to what I have now.
I shit a brick too after i noticed that, i was likee hmm everything looks fine, test drove it and figured it to be normal.
No way..
May do this lol, and +1 on not needing a spring compressor, ( although i had one) these are not as bad as 4th gens.
thanks
mike
dms
Gonna have to try this method lol.
thats a quick removal!
post up PQ!
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 02-03-2010, 01:20 PM   #69
PQ
Booooosted.
PQ's Avatar
I ordered the Pfadt exhaust bearings seperate.
The paint getting done is warranty stuff from under the rear spoiler.
Do yourself a favor. Follow dms advice and disconect the items he stated.
Ya, I freaked out big time. I noticed it on the second side before I reassembled the rest of the wheel. I called Junkie and he said it would be fine. I called Pfadt and they said it was normal. STILL was freaked. Called Scott to go out to his car and look at his. He's never touched it so I knew it would be a good example. He had the same gap.
Heck, I'm STILL kinda uneasy.
post up PQ!
I got a video of the install I'm trying to get up. Should post it later today. May be kinda lame but I'll post it anyway.
Old 02-03-2010, 03:49 PM   #70
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
I swear PQ is the biggest frikkin tease on the board.........LOL.
He will keep saying he's got pictures and even a video and take 3 days to post em! And then he says the video might be lame.
Its like The Champagne Room. Stripper says, "Lets have some fun in the Champagne room" you ask"what kind of fun?" she says "Whatever you like, honey" Then you get there and are out 100 bucks for a $25 lap dance. LOLOLOLOLOLOL.
Blade is offline   Reply With Quote
Eibach Sways and Springs! In Stock! JSC Speed Suspension / Chassis / Brakes 53 11-22-2010 03:48 PM
Pfadt springs and sways installed rhunley14 Suspension / Brakes / Chassis 18 01-27-2010 09:44 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 10:09 PM
Pfadt GROUP BUY! Springs / Sways / Mounts IPS Brandon Suspension / Chassis / Brakes 18 11-23-2009 03:46 PM
Seeking Ohio Camaro owners for near Free Pfadt Springs/ Sways Install!ASAP IPS Brandon USA - Great Lakes 0 11-05-2009 11:50 AM
