BeckyD @ James Martin Chevy
Old 01-30-2010, 04:15 PM   #1
robsmack920
Drives: 2010 2SS #3894
How Do i Take the plastic Door Inserts out?
Ok, i want to take the door's plastic insert out without breaking the plastic rivets, How can I do that? And if I have to break them, what do I need to do to have them sit back in place "properly?"
robsmack920 is offline   Reply With Quote
Old 01-30-2010, 04:49 PM   #2
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
grind the heads off them.
SSTony is offline   Reply With Quote
Old 01-30-2010, 05:36 PM   #3
robsmack920
but then they can't be used again... right?
Old 01-30-2010, 06:30 PM   #4
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
Streetjudge79 posted pics. of instructions on a post . ithink its called My new door panels and dash trim arrived today ( post # 32 ,33 ) .. you will need some short ,stubby screws to reattach . thats what comes with my new trim kits . hope it halps you out .... i used a razor blade and pliers , it was alot cleaner
1 BAD RS 2 SS is offline   Reply With Quote
Old 01-31-2010, 09:33 AM   #5
robsmack920
thanks for the help, ill check it
Old 01-31-2010, 09:34 AM   #6
Bosco
Bosco's Avatar
Drives: 2010 Camaro 1SS RS SIM
Save here my kit came with short replacement screws. Took a razor and sliced the tops off carefully. Replaced panel and used the new screws and worked perfect
Bosco is offline   Reply With Quote
Old 01-31-2010, 12:40 PM   #7
SSTony
SSTony's Avatar
Drives: SS Camaro
what are the sizes of the screws? I need to go pick up some and i need to kn ow what size to get. length i guess is important
Old 01-31-2010, 12:56 PM   #8
1 BAD RS 2 SS
in the instructions it calles for 26 8 mm screws ( 13 per door ) nothing on how long , but im thinking mine were like 3/8 but just guessing . may be your dealer can get some through GMPP . im calling my dealer tomarrow and see if thay can order them . it will help out everybody if we could get some that way
plastic screws and nuts holding small black spoiler under front bumber cm5217 Exterior Parts & Accessories 15 11-09-2016 12:44 PM
Water spots on plastic SirZoltan Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 11-20-2009 09:23 PM
Plastic fading and how to restore?? Susantroy1 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 11 09-20-2009 09:47 PM
Laser-cut Plastic Gill Primus Cosmetics and Lighting Modification Discussions 23 08-15-2009 10:49 PM
PLEASE DONT USE THAT HEAVY PEBBLED PLASTIC ON THE NEW CAMARO Weedwaka 5th Gen Camaro SS LS LT General Discussions 15 01-09-2009 12:01 AM
