Old 01-31-2010, 03:32 AM   #1
SJ LYNN
Drives: 2010 Camaro 2SS/RS
Ring & Pinion Swap Out
Is there is anyone out there that has already done a Ring & Pinion change on their 2010 Camaro and what ratio did you go with? Do you think it was worth the investment?
My concern is that these Camaros with the stock ratio gear in them are quick already. For someone like myself I would like to know up front, is it so drastic a change that the rear tires "breaks loose" as you come through the gears?
By the way, I have the L99/Automatic. I know its all in how you adjust your driving habits/style, but before I go and change my R&G to a 3.73 or 4.10, I kinda want an idea of just how dramatic a change it made.
Look forward to everyone's reply.
Thanks,
Shan
SJ LYNN is offline   Reply With Quote
Old 01-31-2010, 07:42 PM   #2
jordan 572
jordan 572's Avatar
Drives: none
Lol doesnt look like anyone replied. I am curious to. bump
jordan 572 is offline   Reply With Quote
Old 01-31-2010, 07:49 PM   #3
1 BAD RS 2 SS
1 BAD RS 2 SS's Avatar
Drives: 2010 RS 2 SS
ive been looking everyhere and no luck , i was woundering the some . L99 owner too . i was looking into m6 gear set or whole center section . dont know how it would help 1/4 mile times so maybe 3.73
1 BAD RS 2 SS is offline   Reply With Quote
Old 01-31-2010, 08:33 PM   #4
IROCanSS
Drives: 89 IROC 350
Search is your friend... plenty of people have gears already...
Right now the install kit is hard to come by. You wont have an issue with 4.10s and a six speed (auto or manual). And yes, it will be a DRASTIC difference. These cars should have had 4.10s to begin with. You will rip through first and second pretty quick but like you said, just adjust your driving habits and get used to it. I am next in line for the 4.10s here at a local shop, I will give my review once I get them and the weather breaks.
Fleming Co., my father in law has a farm right outside of Flemingsburgh. I live in Georgetown Oh, you ever get to Maysville?
Old 01-31-2010, 08:51 PM   #5
1 BAD RS 2 SS
about once a mounth , maybe see you there sometime
Old 01-31-2010, 09:09 PM   #6
IROCanSS
Drives: 89 IROC 350
maybe...
Old 01-31-2010, 09:30 PM   #7
SJ LYNN
Glad to see I am not the only one curious about this. If it requires a set of "sticky tires" so be it. But as we all know the tire manufacturers don't give those away neither. $$$$ for R&G and more $$$$ for some serious traction rubber (if needed - we'll have to see/hear some feedback from our fellow Camaro5 members)
Perhaps jrhaus76 will get his installed very soon and give us the play-by-play of just how loose the rearend does get with a better/different gearset. Hopefully as we said already; with a simple adjustment in driving style we can save us the $$$$ for tires.
Thanks,
Shan
Old 01-31-2010, 09:39 PM   #8
IROCanSS
Drives: 89 IROC 350
Thanks,
Shan
I hope soon too! But even if I do, the weather here in Ohio has been crap. I am betting new rubber will not be required. Sure I will have to adjust foot pressure when driving normal but when i want to, I am sure it will really smoke the rears. This will be very sparce. I am not looking to buy tires once year!
I for sure will be giving a full write up on the 4.10s but like I said, there are members who already have them installed.
Old 02-10-2010, 06:36 AM   #9
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I was convinced that I wanted 4.10 gears until I did the tune. Now I can't use any more power on the street with stock tires.
A tune is a lot cheaper than the gears!
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 02-18-2010, 06:39 PM   #10
Qwkss
Qwkss's Avatar
Drives: Hoopty Winter Beater
Thanks,
Shan
We just started our 4th 4:10 gear swap and its an Automatic. Once we get all the parts installed and he gets some miles on it, Ill have the owner do a write up.
Qwkss is offline   Reply With Quote
Old 02-18-2010, 06:44 PM   #11
Roger Ramjet
Motor Head
Drives: CTS-V
For street driving with an A6 a gear change is not necessary. Get a tune (both ECM and TCM) and you will have all your stock tires can handle.
Old 02-18-2010, 06:53 PM   #12
Mr Twisty
Mr Twisty's Avatar
Gear change to 4:10 will really shine after you get out of 1st gear (maybe ease into 2nd as well ) and beyond, should pull like a freight train!... Just don't get too rough with the throttle in 1st.
4:10's... they're not just for 1st gear. They'll help your 0-60 a little, help your 0-100 alot!
-- Benjamin Franklin
Old 02-18-2010, 07:01 PM   #13
Qwkss
Qwkss's Avatar
So I guess with the Cam swap and Nitrous Outlet Nitrous kit his tires are really gonna be screwed.
Old 02-18-2010, 07:09 PM   #14
SJ LYNN
Qwkss ,
Whats your take on this now?
If I am going through the traps, I am going to be faster stock factory ratio gear with a "TUNE" only or perhaps the same if not FASTER with leaving the "TUNE" alone (for discussion purposes only here now) but just add a 4.10 gear.
What do ya think?
Thanks....SJ Lynn
5th Gen camaro engine swap American Muscle 5th Gen Camaro SS LS LT General Discussions 13 10-25-2009 04:32 PM
Piston to Valve Clearance? My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-18-2009 08:26 PM
LS-Series Swap Discussion The_Blur Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 06-24-2009 01:25 PM
Is a ring and pinion whine normal for 2002 V6? TopFuelTim 4th Generation Camaros 7 04-09-2009 08:51 PM
lq9 swap ChevyLee General Automotive + Other Cars Discussion 3 03-28-2008 11:23 AM
