BeckyD @ James Martin Chevy
Old 01-31-2010, 01:28 PM   #1
tony1
tony1's Avatar
Drives: 2SS/RS Vortech/L99
L99 TCM-Tuning
Does anyone know if a tune can turn off DOD in the "sport mode" only and when in Drive still work??
tony1 is offline   Reply With Quote
Old 01-31-2010, 03:06 PM   #2
JR-Vette
JR-Vette's Avatar
Drives: 1999 500 HP Corvette
I tune DOD differently as to each owner's drive style
Via tuning can contol when DOD is functional or not by RPM, each trannie gear, the amount of engine MAP/Vac and if high octane timing is being used or not.
Of course if owner has a tuning tool I do multi tunes that they can then flash in when needed with different tune configurations such as one tune that has DOD always off, or another tune with set parameters when DOD is commanded on or off.
JR-Vette is offline   Reply With Quote
Old 02-01-2010, 12:00 PM   #3
kelley@vectormotorsports
Drives: 2009 Pontiac G8 GT
We have been working on this for quite some time. It appears that it is possible.
Hopefully we can still figure it out. You guys will be the first to know.
kelley@vectormotorsports is offline   Reply With Quote
Old 02-01-2010, 01:55 PM   #4
Calibr8or
EFI Guru
Drives: 2010 RJ Camaro SS M6
Must be working really hard there, its only been in hp tuners since the first AFM/DOD release and it works on the camaro too.
Calibr8or is offline   Reply With Quote
Old 02-01-2010, 02:04 PM   #5
mlee
www.CamaroFest.org
mlee's Avatar
Drives: 2017 A10 ZL1
Jury is still out?..
Currently DOD can be tuned to different speed thresholds but will be that way in both D and M modes.
What can be done is tune TM down in M and leave it stock in D. As I understand there is some bleedover affect, but it's still as close to stock as you can get in D and more aggressive in M.
Old 02-01-2010, 02:13 PM   #6
Calibr8or
EFI Guru
really? better tell the hpt guys because they screwed up and put this working table inalso the tm thing doesnt sound right at all the values are either on or off or adjustable for upshift
Old 02-01-2010, 02:17 PM   #7
mlee
www.CamaroFest.org
mlee's Avatar
I do hope you are right... I don't see M on the list . What does T1 - T13 stand for?
Old 02-01-2010, 02:19 PM   #8
Calibr8or
EFI Guru
ive done it on a few cars and it works fine. t is the transmission mode including sport and manual they arent called that for some reason.
Old 02-01-2010, 02:22 PM   #9
mlee
www.CamaroFest.org
mlee's Avatar
That's great news... I counted up the T's and there were more than 6, but then off is off... That would be perfect...
I currently have mine turned completely off and lost around 3mpg
Old 02-01-2010, 02:29 PM   #10
Calibr8or
EFI Guru
its off per mode as in one of those t is the sport and one is manual.
Old 02-01-2010, 02:35 PM   #11
mlee
www.CamaroFest.org
mlee's Avatar
Sport and Manual are one in the same. Pull shifter back to M and you are in Sport mode.
Possibly T is for Tap Shift mode...
Old 02-01-2010, 02:37 PM   #12
Calibr8or
EFI Guru
they are different modes in the tcm
Old 02-01-2010, 02:49 PM   #13
mlee
www.CamaroFest.org
mlee's Avatar
Well Thanks... I for one want mine tuned that way...
and Welcome to the C5 forums...
Old 02-01-2010, 02:51 PM   #14
Calibr8or
EFI Guru
thanks its pretty cool here!
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Tuning LS3 vs L99 Evilangel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 10-30-2008 11:22 AM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
