JUICEDMOTORSPORTS
Old 02-01-2010, 12:46 PM   #1
Mike TexaSS
Drives: 454 LS7 Camaro SS
Exclamation G-Force Rear Suspension and Halfshaft Upgrade! Pics
Had a customer with a LS3 2010 Camaro SS break a rear CV joint. We went ahead and gave it the works!
2010 Camaro SS LS3
  • Driveshaft Shop Stage 5 Axels
  • BMR Rear Trailing Arms
  • BMR Rear Toe Arms
  • Eibach Pro Kit
The car rides great!
BMR vs Stock
Halfshafts and rear suspension Installed!
Mike TexaSS is offline
Old 02-01-2010, 01:18 PM   #2
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Those are some good looking parts!!
BMR guy is offline
Old 02-01-2010, 01:36 PM   #3
Mike TexaSS
The car rides awesome!
Old 02-01-2010, 10:20 PM   #4
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
Can the toe arms be put on w/o removing the wheels... kinda like the trailing arms?
g-townmach is offline
Old 02-01-2010, 11:52 PM   #5
Steve1968LS2
Drives: 1968 LS2 powered - Bad Penny
Yea, but it's a bit tougher. We installed our on a drive on type lift.
The toughest part is the inner bolt on the driver side since the gas tank liner is in the way. We used a prybar to GENTLY dimple in the liner to get the bolt out (then the plastic popped back into shape). At the end we put the bolt back in the oppsite way (nut towards tank)
Tech Editor for Camaro Performers Magazine
1968 Camaro - 461 RHS LS 700hp, various stuff, called Bad Penny
1968 Camaro - In progress, called Track Rat
2010 Camaro - DSE Suspension, Baer 6S Brakes, Boze Wheels, Nitto NT05 Tires, JBA Exhaust and long tubes, Magnacharger TVS, 660rwhp Forged Eagle 416 LS3 short block, ADM fuel system, Lingenfelter GT-9 cam, G-Force axles, Anvil and Seibon CF parts, Centerforce Dual-Disc Clutch
www.fquick.com/steve1968ls2
Steve1968LS2 is offline
Old 02-02-2010, 09:41 PM   #6
Mike TexaSS
Old 02-02-2010, 09:58 PM   #7
CynAgain
CynAgain's Avatar
Drives: Chevy
Looks good
CynAgain is offline
Old 02-03-2010, 10:52 AM   #8
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
No clue why that bolt isn't in in the opposite direction in the first place, would make life much simpler! Even if you think that you will never be taking this apart again I would still put it back together with the bolt in the opposite direction (nut towards tank).
BMR guy is offline
Old 02-03-2010, 09:19 PM   #9
Steve1968LS2
GM does crazy stuff like this all the time...
Old 02-06-2010, 02:33 PM   #10
tples69
Blaq Out
tples69's Avatar
Drives: Hummer H2, 2010 Camaro RS/2SS
What do those axels go for? Might be needing some soon due to a driving mishap!
tples69 is offline
Old 02-07-2010, 12:36 PM   #11
CynAgain
CynAgain's Avatar
Drives: Chevy
ouch! what happened?
CynAgain is offline
Old 02-07-2010, 07:46 PM   #12
jrpxxii
jrpxxii's Avatar
$1799
jrpxxii is offline
