Old 02-01-2010, 10:12 PM   #1
zsuns
zsuns's Avatar
Drives: All Blacked Out 2010 2LT Camaro
Blacking out my tail lights bezels.
After blacking everything else out, I decided to finally get around to blacking out my tail light bezels. From what I heard the task of taking them out was very hard and tedious, but this wasn't quite the case; it was easy and took about 10 minutes to take them out.
To take out the bezels, all I had to do was first take off the panel located in the trunk over the top of the bezels. To do this, I just took a screw driver and popped off the circular tabs. Once the panels were off, I took a flat head screw driver, covered it with a thin dish towel, and lightly pried out the bezels. To do this carefully enough to not break the tabs, I first pried on the upper side corner, then the opposite side, then the top and bottom sides. Easy enough.
Once the bezels were out, it was time to get supplies. I headed over to home depot. I picked up:
One can of premium enamel gray valspar spray primer.
One can of premium enamel valspar flat black spray paint.
A few pieces of 3M wet/dry 400 grit sandpaper.
Once I gathered the supplies, I then used the 400 grit sandpaper to sand all four bezels down until all the chrome(excluding the tabs) had a scratched and sanded look and the shininess of the chrome was brought much down. The bezels looked dirty for a comparison of the shiny chrome. I then cleaned the bezels with a wet dish towel.
After sanded, I masked(taped up with masking tap) all of the tabs on the bezels. If the bezels became painted, they would have a chance of not fitting correctly back in place, giving the need to mask them off.
Once masked off, I needed a surface large enough to hold all four bezels. I found one of my old boxes that my rims came in; perfect size and good height. The box had some dirt on it so I used the dish towel and once I dampened it, I wiped of the surface of the box, then dried it.
I placed the four bezels on top of the box, shook up the gray primer for a good 45 seconds, and applied my first light coat of primer. I used a stroking pattern, as with a paint brush, from a close enough distance to cover all of the area I needed to. The strokes were fast and overlapped eachother(from left to right to left). I didnt use one long stroke around the whole frame; I sprayed one of the four sides at once.
I waited 15 minutes, and applied a second, slightly heavier coat of primer. I used the same technique as the first.
After waiting one hour, I applied my first light coat of the flat black spray paint. Same technique as the primer, and for this first coat, I applied lightly. I wasn't too worried about unevenness yet because there are more coats to come.
After a half hour, I applied my second coat of flat black. I made sure to go over any unevenness and and go over the previous coat, lightly of course.
Finally, 45 minutes later, I applied a third and final light coat. They looked very good already so I didn't want to blotch more paint on than needed. Again, same technique, covering all of the previous coat. This is what they looked like after the third coat an hour later.
So I let them sit out and dry over night, which was about 12 hours in time. Once morning came, I made sure they were fully dry, and put them back in their slots, put the panels back on and enjoyed the final product! I like the look a lot and was very satisfied.
Here is the final product:
Feel free to post some pictures of your bezels too!
zsuns is offline   Reply With Quote
Old 02-01-2010, 10:15 PM   #2
sitruknosnhoj
Drives: none yet
very cool. looks nice
sitruknosnhoj is offline   Reply With Quote
Old 02-01-2010, 10:24 PM   #3
zsuns
zsuns's Avatar
Thanks!!
Old 02-01-2010, 10:39 PM   #4
SamIyam
SamIyam's Avatar
Drives: 2010 1SS
Depending on your automotive paint store... you might even be able to find SEM Trim Paint... in flat/semi gloss black.
It's really good stuff... and is made specifically to paint automotive trim parts.
Sam
SamIyam is offline   Reply With Quote
Old 02-01-2010, 10:47 PM   #5
zsuns
zsuns's Avatar
Yeah i've seen it around but i've never used it, plus I've had experience with this spray paint before and liked the look of it so decided to use it again.
Old 02-01-2010, 10:50 PM   #6
scythezo6
Virologist in the making
scythezo6's Avatar
Drives: 2010 VR SS/RS LS3
Looks good, I'm glad I did mine. Looks much better imo.
Old 02-01-2010, 10:57 PM   #7
zsuns
zsuns's Avatar
Thank you very much. It was easier than I thought from what I heard it was hard to take out the bezels but for me atleast it was easy.
Old 02-02-2010, 12:24 PM   #8
Bone
2SS RJT OWNER/OPERATOR
Bone's Avatar
Drives: 2010 2SS LS3 RJT
The Black on Black looks reall cool. Nice job!
Fly low and Avoid the radar!
Bone is offline   Reply With Quote
Old 02-02-2010, 12:28 PM   #9
baranowski
baranowski's Avatar
Drives: 1968 Bronco,2001 Fatboy,2010 SS
Killer! Black on Black with everything Black. I LOVE this look.
baranowski is offline   Reply With Quote
Old 02-02-2010, 02:00 PM   #10
purplhaizcraz3
Drives: 2010 2LT CHEVY CAMARO BABY!!!!
Great write up and fantastic pics! I've been wanting to paint my bezels for the longest time but I could never find any definitive instructions to do it. As a half- ass kinda way, I just wrapped them up in flat black vinyl, but thanks to your write up, I feel confident to finally do this the right way! Thanks!
purplhaizcraz3 is offline   Reply With Quote
Old 02-02-2010, 07:19 PM   #11
Alain
Alain's Avatar
Drives: 2010 SS, RS, Manual. 2012 F150, FX4
excellent write up man. thanks for this. as soon as i get my car i will be doing this.
looks killer.
Alain is offline   Reply With Quote
Old 02-02-2010, 07:40 PM   #12
zsuns
zsuns's Avatar
Yeah it all comes together nicely. Thanks!!
Me too haha! Thank you!
Thank you very much. Yeah I realized everyone else kinda just told people what they did without explaining it that's why I decided to do a whole tutorial type thing.
looks killer.
Thanks man, feel free to pm any questions or just post on here when the time comes!
Old 02-02-2010, 09:39 PM   #13
Superfly1
Superfly1's Avatar
Drives: 2010 Camaro 2LT #2197
Looks good!... this is the one thing that I think made a big difference with the look of mine. The black on black of yours just enhances it more.
The only thing I would have suggested doing different is using a good plastic adhesion promoter instead of the primer.
As SamIyam stated, the SEM is an excellent product for these kinds of projects.
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft
Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie
Eibach Springs & SS Sway Bars
| BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph
Superfly1 is offline   Reply With Quote
Old 02-02-2010, 09:56 PM   #14
zsuns
zsuns's Avatar
Yeah when I went in the store I actually did ask for an adhesion promoter but the worker said all they had was primer.
Clear Lens Tail Lights - smoked kdoske Cosmetics and Lighting Modification Discussions 13 04-24-2011 02:55 AM
Removal of tail lights Germann Camaro DIY & HOW-TO instructions & discussions 8 12-14-2010 10:43 PM
Blacked out my tail light bezels... scythezo6 Cosmetics and Lighting Modification Discussions 9 05-10-2010 10:47 PM
New tail lights? 2000v6 4th Generation Camaros 40 03-17-2010 04:07 AM
black out tail lights, vinyl or stickers? Darth_Emma Cosmetics and Lighting Modification Discussions 3 12-14-2009 01:03 AM
