SDPC
Old 02-02-2010, 07:49 PM   #1
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
Has anyone tried these rotors yet?
Has anyone tried these rotors made by Brake Performance and distributed by SupremacyCustoms here at Camaro5. They are dimple drilled and slotted and have a lifetime warranty against warping, that's pretty good! I just have never heard of them and SupremacyCustoms swears by them! The price is better than other close competitors too!
Not a Camaro but it works for now!
Old 02-02-2010, 08:04 PM   #2
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Old 02-02-2010, 08:12 PM   #3
ssmike
Missing Big Red
ssmike's Avatar
Get a PM from SupremacyCustoms for a price but I would guess around $600 for a set. I was looking at getting a set of Stillens until I saw these. Just wondering if anyone has tried them! I trust Stillen, they've been around for a long time but I never heard of these.
Old 02-03-2010, 09:47 AM   #4
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I was also wondering about them!!!!
Gotthat02fire is offline   Reply With Quote
Old 02-03-2010, 11:42 AM   #5
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
I've had a set of their drilled slotted rotors on my Dodge dually for a couple years now and they've been fine. When the dimples disappear, then they are at the minimum thickness, great wear indicator.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 02-04-2010, 04:08 PM   #6
BigGriff
Drives: 2000 Ford Ranger, 2007 Silverado
any pics of them on a car?
BigGriff is offline   Reply With Quote
Old 02-04-2010, 05:47 PM   #7
Granatelli
Drives: 2SS Victory Red
Sorry Not yet
Granatelli is offline   Reply With Quote
Old 02-04-2010, 06:41 PM   #8
ssmike
Missing Big Red
ssmike's Avatar
Thanks for the heads up on the noise from the dimpled! Are the crossed drilled holes chamfered? What is the warranty? Are they made by Granatelli and where are they manufactured? Thanks!
Old 02-05-2010, 11:59 AM   #9
Granatelli
Yes the crossed drilled holes are chamfered
The warranty is lifetime against warpage
Granatelli does not make the rotors per-say. We purchase new cores and have the machining done to the customers request - i.e slotted, dippled or drilled or a combo.
Old 02-05-2010, 01:19 PM   #10
PQ
Booooosted.
PQ's Avatar
Witch are these? And how much for fronts and backs?
Old 02-05-2010, 01:28 PM   #11
Tecca
Tecca's Avatar
Drives: ...
Cheapest I have seen is $425, I just do not know about the stuff I have read about the dimpled making a clicking/scratching noise.
http://rpmspeed.com/index.php?cPath=...f0858d37b42465
Tecca is offline   Reply With Quote
Old 02-05-2010, 02:42 PM   #12
Granatelli
Just so there is no confussion We are happy to ship dimpled or drilled - WE DO OFFER THEM both ways
Here is a pic of dimpled
The first time you hit the brakes they get shiny like the others
Old 02-05-2010, 02:59 PM   #13
Granatelli
Just a few more specs
· Fits 2010-2011 Camaro
· Lifetime warranty
· Installs easily with simple hand tools
· Cooler looking then stock and offers a better cosmetic appearance
· Less brake pedal fade after repeated hard stops
· 15% decrease in repeatable stopping distance
· Increased heat absorption with faster thermal recovery
· Maintains OE civility and fully compatible with factory OE ABS
· Black Zink Coating – wipes away after 10 miles leaving a beautiful looking rotor with the dimples or crossed drilled holes and slots highlighted in black and a shinny face surface
· Drilled rotors have all holes chamfered to ensure long lasting quality
· GMS Rotors Feature Scraper Slots – These fully dissipate heat, increase bite and reduce stopping distance. Our slots also help to de-glaze and even out brake pads while throwing dust and debris away from the wheels. It also sheds water under-wet driving conditions.
· GMS Rotors Feature either Drilled (Dimpled) Holes or Chamferred Cross Drilled Holes – In both cases this prevents warping and cracking. A major feature of our blind degassing dimpled holes is that it extends the life of the rotors and pads and they dissipate heat with maximum braking performance under all necessary driving conditions. This allows us to offer a LIFETIME WARRANTY against warping and cracking.
· Balanced & Vented – GMS Rotors are machine balanced, vented for cooling, X-Ray Inspected and manufactured to meet QS and ISO quality system standards.
· Manufactured from premium quality solid casting, TUV approved steel.
· Ultra smooth rotor surface reduces brake noise and extends pad life and are vented for cooling.
· Meets and exceeds federal safety standards required for new vehicles
· Guaranteed vibration-free performance
Fronts
Outer Dia......................................355.4mm
Height........................................... 49.7mm
Nom Thick................................... 31.9mm
Min Thick..................................... 30.0mm
Hub Reg...................................... 67.4mm
Bolt Size..................................... 16.2mm
Bolt Circle.................................. 5-Lug x 120mm
Weight........................................ 25.5 LBS
Rears
Outer Dia......................................365.0mm
Height........................................... 47.6mm
Nom Thick................................... 28.0mm
Min Thick..................................... 26.0mm
Bolt Size..................................... 16.5mm
Weight....................................... 24 LBS
Thank You
Old 02-05-2010, 03:20 PM   #14
ssmike
Missing Big Red
ssmike's Avatar
Thanks Granatelli for all the excellent info! Greatly appreciated!
Brembo 2SS Brake rotors Front and Rear Complete with Pads 55Designs Suspension / Chassis / Brakes 4 06-07-2011 02:58 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 03:57 PM
2-piece rotors for all 4 corners group buy Doc Suspension / Chassis / Brakes 96 12-31-2009 03:18 PM
Warping brake rotors Angrybird 12 Suspension / Brakes / Chassis 13 12-18-2009 02:45 PM
2010 Camaro SS Brembo Heavy Duty Cross Drilled Brake Rotors In Stock Ready To Ship Tim@Lingenfelter Suspension / Chassis / Brakes 4 12-07-2009 08:26 PM
