HeadlightArmor
Old 02-05-2010, 03:21 PM   #15
ssmike
Missing Big Red
ssmike's Avatar
Drives: 2006 Corvette DSOM, '13 Equinox CRT
Originally Posted by Teccboxx View Post
Cheapest I have seen is $425, I just do not know about the stuff I have read about the dimpled making a clicking/scratching noise.
http://rpmspeed.com/index.php?cPath=...f0858d37b42465
Wow great price!
Not a Camaro but it works for now!
ssmike is online now   Reply With Quote
Old 01-28-2011, 02:36 PM   #16
Diejediknight
Diejediknight's Avatar
Drives: 2010 Camaro 2SS RS
I have a set i just installed,i warped 3 factory sets in 12,000 miles before the dealer decided i was over driving the car.I am impressed so far with the Granatelli's,will update in a month.
Diejediknight is offline   Reply With Quote
Old 01-29-2011, 10:00 PM   #17
Go big or Go home
Go big or Go home's Avatar
Drives: 2010 Camaro 2LT RS
I have the cross-drilled and slotted rotors from Brakeperformance.com, only had them on for about two weeks but haven't had any problems. They look great, much better than the stock... can't say I notice any performance difference though.
Not a great picture, but it gives you an idea...
Go big or Go home is offline   Reply With Quote
Old 01-30-2011, 06:21 PM   #18
Granatelli
Drives: 2SS Victory Red
They look like they are already turning blue - You go speed racer
Granatelli is offline   Reply With Quote
Old 01-30-2011, 06:27 PM   #19
martin_2010
martin_2010's Avatar
Drives: 2010 Camaro 1ss/Rs package
Is that a bad thinh that they are turninh blue?
martin_2010 is offline   Reply With Quote
Old 01-30-2011, 07:22 PM   #20
Granatelli
Blue means he was riding the brake peddle. Like driving 2 footed. Or perhaps he was hauling-ars and had to stop very short. Once you turn the rotors blue like that, they usually stay blue - If they are not warping or warped then he is fine - if they are - i guess they have a lifetime warranty so ..... no big deal
Old 01-30-2011, 09:53 PM   #21
Dimitry@FairwayChevrolet
Drives: 2010 camaro
Go Big or Go Home
Can you post more pics of your car if its possible?
Dimitry@FairwayChevrolet is offline   Reply With Quote
Old 01-30-2011, 09:58 PM   #22
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I run Granatelli rotors ...no issues and they look great!
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 01-31-2011, 01:45 PM   #23
orange-prince
QATAR 2022
orange-prince's Avatar
Drives: black cts-V coupe a6
pic's for the black rotors installed please
orange-prince is offline   Reply With Quote
Old 01-31-2011, 02:18 PM   #24
Granatelli
I will work on that but it looks just like the white car - These are basically a high end factory rotor replacement with the slot and dimples or hles cross drilled
Old 01-31-2011, 08:42 PM   #25
Go big or Go home
Originally Posted by 2010MARO View Post
Go Big or Go Home
I don't have too many of just the brakes but I have some of the whole car...
Old 01-31-2011, 08:53 PM   #26
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
i have those rotors from supremacy....they are great ....no noise at all
bmbbl be is offline   Reply With Quote
Old 02-05-2011, 01:37 PM   #27
John M.
Drives: 2010 Camaro
Send a message via AIM to John M.
There looks like an awful lot of material missing. The MORE slots and holes you have the LESS braking surface you actually have in contact with the pads.
These are GM rotors, custom slotted by frozen Rotors, then cryogentically frozen, then heat treated. I used DTC-30s in all four corners. At night, during spirited driving and aggressive braking sparks shoot out of all four wheels. I am shedding speed REALLY FAST.... from 120/125mph to 35/40mph inside 200 feet with Nitto NT05 (275 front & 315 rear). Stainless Steel lines and Castrol SRF fluid.
My set-up is NOISY. But that is from the PAD selection... not the rotor.
Pfadt springs, bars, strut tower brace. CCW: SP16a 20x10 front 20x11 rear. Nitto: NT05 275/35 F 315/35 R. Hawk: DTC30 F/R. Stainless Steel Brake Lines. MBRP cat back. VARARAM air box. Custom front brake cooling system. Speedware Motorsports Harness Bar and Tank Plates. Schroth Hybrid-II 6-point HANS belts. TORQ Custom Dyno Tune. Frozen Rotors Discs. NOWEEDS 3" Diverters. AMSOIL Synthetic Racing Oil and Coolant. Scorpion 1.8 Rockers. Custom/Modified Exhaust and Side Pipes. E3 Spark Plugs. Arrington Customized Catch Can. MORE TO COME LATER...
John M. is offline   Reply With Quote
Old 02-05-2011, 09:07 PM   #28
united1
united1's Avatar
Drives: slpzl585vert.
brakeperformance.com $169 a set best price I've seen
united1 is offline   Reply With Quote
Brembo 2SS Brake rotors Front and Rear Complete with Pads 55Designs Suspension / Chassis / Brakes 4 06-07-2011 02:58 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 03:57 PM
2-piece rotors for all 4 corners group buy Doc Suspension / Chassis / Brakes 96 12-31-2009 03:18 PM
Warping brake rotors Angrybird 12 Suspension / Brakes / Chassis 13 12-18-2009 02:45 PM
2010 Camaro SS Brembo Heavy Duty Cross Drilled Brake Rotors In Stock Ready To Ship Tim@Lingenfelter Suspension / Chassis / Brakes 4 12-07-2009 08:26 PM
